Post din XF86Config her!
Jeg har lyst å prøve å finne litt ut av hvordan denne fila egentlig virker, og har derfor lyst til å få se forskjellige varianter. Denne tråden kan også bli en fin referanse til seinere.
Ta med hvilken OS, skjermkort og skjerm du har.
Her er mitt bidrag:
Matrox G450 16 mb, 21" hp 1100. OS-et er FreeBSD, men det er en lett modifisert versjon av den som kom med Mandrake 9.0,
Section "ServerLayout"
Identifier "XFree86 Configured"
Screen 0 "Screen0" 0 0
InputDevice "Mouse0" "CorePointer"
InputDevice "Keyboard0" "CoreKeyboard"
EndSection
Section "Files"
RgbPath "/usr/X11R6/lib/X11/rgb"
ModulePath "/usr/X11R6/lib/modules"
FontPath "/usr/X11R6/lib/X11/fonts/misc/:unscaled"
FontPath "/usr/X11R6/lib/X11/fonts/75dpi/:unscaled"
FontPath "/usr/X11R6/lib/X11/fonts/100dpi/:unscaled"
FontPath "/usr/X11R6/lib/X11/fonts/Type1/"
FontPath "/usr/X11R6/lib/X11/fonts/webfonts"
FontPath "/usr/X11R6/lib/X11/fonts/windows"
FontPath "/usr/X11R6/lib/X11/fonts/TTF"
FontPath "/usr/X11R6/lib/X11/fonts/TrueType"
FontPath "/usr/X11R6/lib/X11/fonts/mozilla"
FontPath "/usr/X11R6/lib/X11/fonts/misc/"
FontPath "/usr/X11R6/lib/X11/fonts/Speedo/"
FontPath "/usr/X11R6/lib/X11/fonts/75dpi/"
FontPath "/usr/X11R6/lib/X11/fonts/100dpi/"
FontPath "/usr/X11R6/lib/X11/fonts/URW"
FontPath "/usr/X11R6/lib/X11/fonts/artwixz-fonts"
FontPath "/usr/X11R6/lib/X11/fonts/cyrillic"
FontPath "/usr/X11R6/lib/X11/fonts/freefont"
FontPath "/usr/X11R6/lib/X11/fonts/jmk"
FontPath "/usr/X11R6/lib/X11/fonts/koi8-u-gemini"
FontPath "/usr/X11R6/lib/X11/fonts/lfpfonts-fix"
FontPath "/usr/X11R6/lib/X11/fonts/lfpfonts-var"
FontPath "/usr/X11R6/lib/X11/fonts/local"
EndSection
Section "Module"
Load "dbe"
Load "dri"
Load "extmod"
Load "glx"
Load "pex5"
Load "record"
Load "xie"
Load "xtrap"
Load "speedo"
Load "type1"
Load "freetype"
EndSection
Section "InputDevice"
Identifier "Keyboard0"
Driver "keyboard"
Option "XkbRules" "xfree86"
Option "XkbModel" "logicordless"
Option "XkbLayout" "no"
EndSection
Identifier "Mouse0"
Driver "mouse"
Option "Protocol" "ps/2"
Option "Device" "/dev/psm0"
Option "ZAxisMapping" "4 5"
EndSection
Section "Monitor"
DisplaySize 400 300 # mm
Identifier "Monitor0"
VendorName "HWP"
ModelName "HP P1100"
HorizSync 30 - 107
VertRefresh 50.0 - 160.0
Option "DPMS"
Gamma 0.9
EndSection
Section "Device"
### Available Driver options are:-
### Values: <i>: integer, <f>: float, <bool>: "True"/"False",
### <string>: "String", <freq>: "<f> Hz/kHz/MHz"
### [arg]: arg optional
#Option "SWcursor" # [<bool>]
#Option "HWcursor" # [<bool>]
#Option "PciRetry" # [<bool>]
#Option "SyncOnGreen" # [<bool>]
#Option "NoAccel" # [<bool>]
#Option "ShowCache" # [<bool>]
#Option "Overlay" # [<str>]
#Option "MGASDRAM" # [<bool>]
#Option "ShadowFB" # [<bool>]
#Option "UseFBDev" # [<bool>]
#Option "ColorKey" # <i>
#Option "SetMclk" # <freq>
#Option "OverclockMem" # [<bool>]
#Option "VideoKey" # <i>
#Option "Rotate" # [<str>]
#Option "TexturedVideo" # [<bool>]
#Option "Crtc2Half" # [<bool>]
#Option "Crtc2Ram" # <i>
#Option "Int10" # [<bool>]
#Option "AGPMode" # <i>
#Option "DigitalScreen" # [<bool>]
#Option "TV" # [<bool>]
#Option "TVStandard" # [<str>]
#Option "CableType" # [<str>]
#Option "NoHal" # [<bool>]
#Option "SwappedHead" # [<bool>]
#Option "DRI" # [<bool>]
Identifier "Card0"
Driver "mga"
VendorName "Matrox"
BoardName "MGA G450 AGP"
BusID "PCI:1:0:0"
EndSection
Section "Screen"
Identifier "Screen0"
Device "Card0"
Monitor "Monitor0"
DefaultDepth 24
Subsection "Display"
Depth 8
Modes "1024x768" "800x600" "640x480"
EndSubsection
Depth 15
EndSubsection
Depth 16
EndSubsection
Depth 24
EndSubsection
EndSection
Her er en til, tatt fra FreeBSD live-cd prosjektet FreeSBIE. Den burde virke på alt untatt steingamle PC-er. Kun vesa-driver!
Identifier "Layout0"
EndSection
Section "Files"
EndSection
Section "Module"
Load "xie"
Load "pex5"
Load "glx"
Load "dri"
Load "dbe"
Load "record"
Load "extmod"
Load "type1"
EndSection
Identifier "Mouse0"
Driver "mouse"
Option "Protocol" "Auto"
Option "Device" "/dev/sysmouse"
Option "Buttons" "5"
EndSection
Driver "keyboard"
Option "XkbModel" "pc105"
Option "XkbLayout" "it"
EndSection
Section "Monitor"
HorizSync 31.5 - 48.5
VertRefresh 50.0 - 90.0
EndSection
Section "Device"
Identifier "Card0"
Driver "vesa"
EndSection
Section "Screen"
Device "Card0"
Monitor "Monitor0"
DefaultDepth 16
SubSection "Display"
Depth 16
Modes "800x600" "1024x768"
EndSubSection
EndSection
Kult og se hvordan andre sin XF86Config-fil er satt opp. Siden jeg akkurat nå bruker Windows, og fordi jeg sliter med å få X "up and running" (ifølge log-fila så er det noe kødd med hsync...Rart da jeg har fulgt skjermens manual). Kanskje kan noen si hva som er galt?
Section "Module"
Load "dbe" # Double buffer extension
SubSection "extmod"
Option "omit xfree86-dga" # don't initialise the DGA extension
EndSubSection
Load "type1"
Load "freetype"
Load "speedo"
Load "glx"
EndSection
Section "Files"
FontPath "/usr/X11R6/lib/X11/fonts/local/"
# The module search path. The default path is shown here.
# ModulePath "/usr/X11R6/lib/modules"
EndSection
# Server flags section.
Section "ServerFlags"
EndSection
Identifier "Keyboard1"
Driver "Keyboard"
Option "AutoRepeat" "500 30"
EndSection
# Identifier and driver
Identifier "Mouse1"
Driver "mouse"
Option "Protocol" "MouseSystems"
Option "Device" "/dev/mouse"
EndSection
# Monitor section
Section "Monitor"
Identifier "cm771"
HorizSync 31.0 - 50.0
VertRefresh 50-85
EndSection
# Graphics device section
# Standard VGA Device:
Section "Device"
Identifier "Standard VGA"
VendorName "Unknown"
BoardName "Unknown"
EndSection
Section "Device"
Identifier "Nvidia Geforce 4 Ti4200"
Driver "nvidia"
EndSection
# Screen sections
Section "Screen"
Identifier "Screen 1"
Device "Nvidia Geforce 4 Ti4200"
Monitor "cm771"
DefaultDepth 16
Depth 8
Modes "640x480" "800x600" "1024x768" "1280x1024"
ViewPort 0 0
EndSubsection
Depth 16
ViewPort 0 0
EndSubsection
Depth 24
ViewPort 0 0
EndSubsection
EndSection
Identifier "Simple Layout"
Screen "Screen 1"
InputDevice "Mouse1" "CorePointer"
InputDevice "Keyboard1" "CoreKeyboard"
EndSection
Jeg kjører Red Hat 7.2, men kjernen bruker en av de nyeste kjerneversjonene (husker ikke hvilken :roll: ) for å få lyden på HKet til å virke (har ikke testet det duh ^^) og for å hindre komplikasjoner (nforce 2...). Jeg valgte å droppe konfigureringen av X siden jeg ikke fant skjermkortet på listen. Driverne lastes finfint, ingen trøbbel under kompileringen, men da jeg starter X Windows, så synes bare en liten del av skrivebordet og det går ikke å bevege musen (å Ctrl+Alt+Shift+F1 ut i kommandolinjen går fint). Det eneste direkte feilen jeg kan se i loggfilen er at den klager over hsyncen og bruker derfor en "virtuell oppløsning" som er høyere enn den reele (er vel kanskje derfor jeg bare ser en liten del av skrivebordet, men jeg burde da kunne flytte musen eller se NOE aktivitet når jeg hamrer løs på tastaturet?). Får prøve å eksperimentere med ulike verdier :grumpy:
Gentoo linux, 17" Tandberg Display (statoil) skjerm, gammelt 8mb nvidia skjermkort (støtter ikke opengl) og psaux mus (med scroll knapp). Enkel og grei config :)
EndSection
Section "Files"
EndSection
Section "Module"
Load "xie"
Load "pex5"
# Load "glx"
Load "dri"
Load "dbe"
Load "record"
Load "extmod"
Load "type1"
EndSection
Identifier "Mouse0"
Driver "mouse"
Option "Protocol" "imps/2"
Option "Device" "/dev/psaux"
EndSection
Driver "keyboard"
Option "XkbModel" "pc101"
EndSection
Section "Monitor"
HorizSync 37.5 - 64.0
VertRefresh 60.0 - 75.0
EndSection
Section "Device"
Identifier "Card0"
Driver "nv"
EndSection
Section "Screen"
Device "Card0"
Monitor "Monitor0"
DefaultDepth 15
Depth 15
Modes "1280x1024" "1280x960" "1152x864" "1024x768" "800x600" "640x480"
EndSubSection
EndSection
Er det noen som vet hvor jeg kan finne informasjon og dokumentasjon på moduler?
Fra min fil:
Section "Module"
Load "dbe"
Load "dri"
Load "extmod"
Load "glx"
Load "pex5"
Load "record"
Load "xie"
Load "xtrap"
Load "speedo"
Load "type1"
Load "freetype"
EndSection
Og et annet eksempel:
SubSection "extmod"
EndSubSection
Hva gjør alle disse modulene? Hvilke andre finnes? Hvilke justeringsmuligheter finnes for de enkelte modulene, jmf. "dbe" over?
Jeg las litt på man-sidene på XFree86.org i går. Det meste er greit å finne ut av, men ikke disse modulene.
Vurdert å oppgradere til en nyere versjon av RedHat? Jeg kjører 9.0 nå, og har gjort det en uke, og den har tatt all hardware'n min automatisk; t.o.m. lydkortet som er et kjent problem med Linux at kan være problematisk.....
Jeg kjører Red Hat 7.2, men bruker en av de nyeste kjerneversjonene (husker ikke hvilken :roll: ) for å få lyden på HKet til å virke (har ikke testet det duh ^^) og for å hindre komplikasjoner (nforce 2...). Jeg valgte å droppe konfigureringen av X siden jeg ikke fant skjermkortet på listen. Driverne lastes finfint, ingen trøbbel under kompileringen, men da jeg starter X Windows, så synes bare en liten del av skrivebordet og det går ikke å bevege musen (å Ctrl+Alt+Shift+F1 ut i kommandolinjen går fint). Det eneste direkte feilen jeg kan se i loggfilen er at den klager over hsyncen og bruker derfor en "virtuell oppløsning" som er høyere enn den reele (er vel kanskje derfor jeg bare ser en liten del av skrivebordet, men jeg burde da kunne flytte musen eller se NOE aktivitet når jeg hamrer løs på tastaturet?). Får prøve å eksperimentere med ulike verdier :grumpy:
Hele vitsen var at jeg skulle lære mer om Linux, og det gjør man ikke hvis man velger den mest lettvinte løsningen - oppgradere til den nyeste distroen. Nå vet jeg mye mer om hvordan config-filene er satt opp, hvordan man installerer drivere, kompilering (før så fikk jeg alltid trøbbel og måtte gi opp :-) ), oppgradering av kjernen.... Dette ville jeg ikke ha visst noe om, hvis jeg "bare" hadde skiftet distrubsjon (hvor går grensen? Jeg har den nyeste kjernen og skal installere nyeste versjon av X...).
jeg har størst..
voodoo 5500 agp, med en nokia 20 tommers skjerm på. 2, matrox mustiqe (eller hvordan det skrives) med en 17 tommers skjerm på..
filen er litt homemade men funker :)
# File generated by XFdrake.
# Refer to the XF86Config man page for details about the format of
# this file.
Section "Files"
# Multiple FontPath entries are allowed (they are concatenated together)
# By default, Mandrake 6.0 and later now use a font server independent of
# the X server to render fonts.
FontPath "unix/:-1"
EndSection
#DontZap # disable <Crtl><Alt><BS> (server abort)
#DontZoom # disable <Crtl><Alt><KP_+>/<KP_-> (resolution switching)
AllowMouseOpenFail # allows the server to start up even if the mouse doesn't work
EndSection
Section "Module"
Load "dbe" # Double-Buffering Extension
Load "v4l" # Video for Linux
Load "extmod"
Load "type1"
Load "freetype"
Load "glx" # 3D layer
Load "dri" # direct rendering
EndSection
Section "DRI"
Mode 0666
EndSection
Driver "Keyboard"
Option "XkbCompat" ""
Option "XkbOptions" ""
EndSection
Identifier "Mouse1"
Driver "mouse"
Option "Protocol" "ExplorerPS/2"
Option "ZAxisMapping" "6 7"
EndSection
Section "Monitor"
Identifier "monitor1"
VendorName "Plug'n Play"
HorizSync 30-96
VertRefresh 50-160
# Sony Vaio C1(X,XS,VE,VN)?
# 1024x480 @ 85.6 Hz, 48 kHz hsync
ModeLine "1024x480" 65.00 1024 1032 1176 1344 480 488 494 563 -hsync -vsync
# TV fullscreen mode or DVD fullscreen output.
# 768x576 @ 79 Hz, 50 kHz hsync
ModeLine "768x576" 50.00 768 832 846 1000 576 590 595 630
# 768x576 @ 100 Hz, 61.6 kHz hsync
ModeLine "768x576" 63.07 768 800 960 1024 576 578 590 616
EndSection
Section "Monitor"
Identifier "monitor2"
ModelName "TVM TCO6S Model"
HorizSync 30.0-69.0
VertRefresh 50.0-120.0
EndSection
Section "Device"
Identifier "device1"
VendorName "3Dfx Interactive, Inc."
BoardName "Voodoo5 (generic)"
Driver "tdfx"
Screen 0
BusID "PCI:1:0:0"
Option "DPMS"
EndSection
Section "Device"
Identifier "device2"
VendorName "Matrox"
BoardName "Matrox Mystique"
Driver "mga"
Screen 0
BusID "PCI:2:1:0"
Option "DPMS"
EndSection
Section "Screen"
Identifier "screen1"
Device "device1"
Monitor "monitor1"
DefaultColorDepth 24
Depth 8
EndSubsection
Depth 15
EndSubsection
Depth 16
EndSubsection
Depth 24
EndSubsection
EndSection
Section "Screen"
Identifier "screen2"
Device "device2"
Monitor "monitor2"
Depth 8
EndSubsection
Depth 15
EndSubsection
Depth 16
EndSubsection
Depth 24
EndSubsection
EndSection
Identifier "layout1"
Screen "screen1"
Screen "screen2" RightOf "screen1"
#Option "Xinerama"
EndSection
