Myrsve Skrevet 22. desember 2008 Del Skrevet 22. desember 2008 (endret) Hei har installert ubuntu 8.10 på min aopen 1557, problemet er at det trådløse netverkortet ser ikke ut til å fungere. har prøvd å søke på HW- og ubuntu-forumene om de samme problemene, men fant ingen svar. har sett in system > administrator > hardware drivers den finner ingenting. her er en printout fra lspci myrsve@myrsve-laptop:~$ lspci 00:00.0 Host bridge: Intel Corporation 82855PM Processor to I/O Controller (rev 21) 00:01.0 PCI bridge: Intel Corporation 82855PM Processor to AGP Controller (rev 21) 00:1d.0 USB Controller: Intel Corporation 82801DB/DBL/DBM (ICH4/ICH4-L/ICH4-M) USB UHCI Controller #1 (rev 03) 00:1d.1 USB Controller: Intel Corporation 82801DB/DBL/DBM (ICH4/ICH4-L/ICH4-M) USB UHCI Controller #2 (rev 03) 00:1d.2 USB Controller: Intel Corporation 82801DB/DBL/DBM (ICH4/ICH4-L/ICH4-M) USB UHCI Controller #3 (rev 03) 00:1d.7 USB Controller: Intel Corporation 82801DB/DBM (ICH4/ICH4-M) USB2 EHCI Controller (rev 03) 00:1e.0 PCI bridge: Intel Corporation 82801 Mobile PCI Bridge (rev 83) 00:1f.0 ISA bridge: Intel Corporation 82801DBM (ICH4-M) LPC Interface Bridge (rev 03) 00:1f.1 IDE interface: Intel Corporation 82801DBM (ICH4-M) IDE Controller (rev 03) 00:1f.3 SMBus: Intel Corporation 82801DB/DBL/DBM (ICH4/ICH4-L/ICH4-M) SMBus Controller (rev 03) 00:1f.5 Multimedia audio controller: Intel Corporation 82801DB/DBL/DBM (ICH4/ICH4-L/ICH4-M) AC'97 Audio Controller (rev 03) 01:00.0 VGA compatible controller: ATI Technologies Inc RV350 [Mobility Radeon 9600 M10] 02:05.0 Ethernet controller: Broadcom Corporation BCM4401 100Base-T (rev 01) 02:06.0 Network controller: Intel Corporation PRO/Wireless 2200BG [Calexico2] Network Connection (rev 05) 02:09.0 CardBus bridge: Ricoh Co Ltd RL5c476 II (rev ac) 02:09.1 CardBus bridge: Ricoh Co Ltd RL5c476 II (rev ac) 02:09.2 FireWire (IEEE 1394): Ricoh Co Ltd R5C552 IEEE 1394 Controller (rev 04) er litt grønn på linux så vær så snill og hjelp meg. alt av hjelp godtas. -myrsve Edit. lspci -v 02:06.0 Network controller: Intel Corporation PRO/Wireless 2200BG [Calexico2] Network Connection (rev 05) Subsystem: Intel Corporation Device 2702 Flags: bus master, medium devsel, latency 64, IRQ 10 Memory at d0202000 (32-bit, non-prefetchable) Capabilities: <access denied> Kernel driver in use: ipw2200 Kernel modules: ipw2200 Endret 22. desember 2008 av Myrsve Lenke til kommentar
Smif Skrevet 22. desember 2008 Del Skrevet 22. desember 2008 Hmm.. 2200BG skal da ha støtte i kjernen. Du beviser jo også at den er i bruk, ipw2200. Hva får du av "ifconfig" og "iwconfig"? trådløse netverkortet ser ikke ut til å fungere Kan du beskrive dette litt mer? Hvordan ser du det? feilmelding? Lenke til kommentar
Myrsve Skrevet 22. desember 2008 Forfatter Del Skrevet 22. desember 2008 Hmm.. 2200BG skal da ha støtte i kjernen. Du beviser jo også at den er i bruk, ipw2200. Hva får du av "ifconfig" og "iwconfig"? trådløse netverkortet ser ikke ut til å fungere Kan du beskrive dette litt mer? Hvordan ser du det? feilmelding? det jeg mente med at kortet ikke fungerer er at i system tray får jeg ikke tilgang til wierless connection delen. kansje dette hjelper. når jeg bruker win xp. så må jeg bruke en "HOTKEY" på venstre side av pcen til å aktivere det trådløse kortet. men vet ikke om dette har noen invirkning in linux. Lenke til kommentar
Smif Skrevet 22. desember 2008 Del Skrevet 22. desember 2008 Høyreklikk på tray iconet og aktiver? Men kommer wlan0 el. opp i ifconfig og/eller iwconfig? Lenke til kommentar
jonnor Skrevet 22. desember 2008 Del Skrevet 22. desember 2008 Driveren er lastet, ergo er kortet aktivert. Du kan forsøke å høyreklikke på ikonet i system tray og se om ikke muligens wireless er deaktivert der. Mulig wired connection må være av, husker ikke helt. Dersom ikke dette fungerer, post output av iwconfig/ifconfig. Lenke til kommentar
Myrsve Skrevet 22. desember 2008 Forfatter Del Skrevet 22. desember 2008 (endret) Driveren er lastet, ergo er kortet aktivert. Du kan forsøke å høyreklikke på ikonet i system tray og se om ikke muligens wireless er deaktivert der. Mulig wired connection må være av, husker ikke helt. Dersom ikke dette fungerer, post output av iwconfig/ifconfig. myrsve@myrsve-laptop:~$ ifconfig eth0 Link encap:Ethernet HWaddr 00:0a:e4:54:d7:f4 UP BROADCAST MULTICAST MTU:1500 Metric:1 RX packets:0 errors:0 dropped:0 overruns:0 frame:0 TX packets:0 errors:0 dropped:0 overruns:0 carrier:0 collisions:0 txqueuelen:1000 RX bytes:0 (0.0 B) TX bytes:0 (0.0 B) Interrupt:10 eth1 Link encap:Ethernet HWaddr 00:0e:35:6f:f2:4e UP BROADCAST MULTICAST MTU:1500 Metric:1 RX packets:0 errors:0 dropped:0 overruns:0 frame:0 TX packets:0 errors:0 dropped:0 overruns:0 carrier:0 collisions:0 txqueuelen:1000 RX bytes:0 (0.0 B) TX bytes:0 (0.0 B) Interrupt:10 Base address:0xc000 Memory:d0202000-d0202fff lo Link encap:Local Loopback inet addr:127.0.0.1 Mask:255.0.0.0 UP LOOPBACK RUNNING MTU:16436 Metric:1 RX packets:12 errors:0 dropped:0 overruns:0 frame:0 TX packets:12 errors:0 dropped:0 overruns:0 carrier:0 collisions:0 txqueuelen:0 RX bytes:752 (752.0 B) TX bytes:752 (752.0 B) myrsve@myrsve-laptop:~$ iwconfig lo no wireless extensions. eth0 no wireless extensions. eth1 radio off ESSID:off/any Mode:Managed Channel:0 Access Point: Not-Associated Bit Rate:0 kb/s Tx-Power=off Sensitivity=8/0 Retry limit:7 RTS thr:off Fragment thr:off Power Management:off Link Quality:0 Signal level:0 Noise level:0 Rx invalid nwid:0 Rx invalid crypt:0 Rx invalid frag:0 Tx excessive retries:0 Invalid misc:0 Missed beacon:0 pan0 no wireless extensions. har høyre klikket på netverk ikonet. jeg har ikke muligheten å velge wierless connection hvordan slår jeg på radion? I winxp må jeg bruke hotkay for å slå den på Endret 22. desember 2008 av Myrsve Lenke til kommentar
Smif Skrevet 22. desember 2008 Del Skrevet 22. desember 2008 Du har ikke en sånn knapp på tastaturet også? Fn+F2 eller noe sånt? Finner ikke i farta en kommando for å skru den på.. Men den burde jo egentlig vært på som standard. Er ikke en innstilling i bios da? start som på eller noe? Lenke til kommentar
Myrsve Skrevet 22. desember 2008 Forfatter Del Skrevet 22. desember 2008 Du har ikke en sånn knapp på tastaturet også? Fn+F2 eller noe sånt? Finner ikke i farta en kommando for å skru den på.. Men den burde jo egentlig vært på som standard. Er ikke en innstilling i bios da? start som på eller noe? jeg har en sån knapp på siden. fant dette på ubuntu forum josergc Re: HW RF Kill switch doesn't work in 8.10 Intrepid Ibex -------------------------------------------------------------------------------- Hi all, I have discovered that if I press the radio kill button to turn on it when the splash screen with the logo of Ubuntu and the loading bar appears, the wireless is indeed turned on, but I cannot turn on when I am running in X already. There is one thing more, with the wireless turned on in X, if I turn off it pressing the radio kill button, this works, but I am not able to turn on the wireless again. The only solution is reboot the computer again. Any suggestion?? Thank you in advance, Kind regard, skal prøve dette Lenke til kommentar
Myrsve Skrevet 22. desember 2008 Forfatter Del Skrevet 22. desember 2008 Du har ikke en sånn knapp på tastaturet også? Fn+F2 eller noe sånt? Finner ikke i farta en kommando for å skru den på.. Men den burde jo egentlig vært på som standard. Er ikke en innstilling i bios da? start som på eller noe? jeg har en sån knapp på siden. fant dette på ubuntu forum josergc Re: HW RF Kill switch doesn't work in 8.10 Intrepid Ibex -------------------------------------------------------------------------------- Hi all, I have discovered that if I press the radio kill button to turn on it when the splash screen with the logo of Ubuntu and the loading bar appears, the wireless is indeed turned on, but I cannot turn on when I am running in X already. There is one thing more, with the wireless turned on in X, if I turn off it pressing the radio kill button, this works, but I am not able to turn on the wireless again. The only solution is reboot the computer again. Any suggestion?? Thank you in advance, Kind regard, skal prøve dette dette fungerte ikke Lenke til kommentar
Myrsve Skrevet 22. desember 2008 Forfatter Del Skrevet 22. desember 2008 fikk det til gikk nøye gjennom BIOSen og fant et alternativ til å slå på wlan ved oppstart. dette løste problemet mitt. takk for all hjelpen God Jul all sammen Lenke til kommentar
Kagee Skrevet 22. desember 2008 Del Skrevet 22. desember 2008 Akkurat det jeg skulle til å foreslå :!: Lenke til kommentar
