rocknrolf77 Skrevet 23. desember 2008 Del Skrevet 23. desember 2008 Oppdater gjerne første posten i tråden med denne linken. En sinnnsyk stor tråd med conkyrc og screenshots. Lenke til kommentar
Kakebakelate Skrevet 23. desember 2008 Del Skrevet 23. desember 2008 background no font Sans:size=8 #xftfont Sans:size=10 use_xft yes xftalpha 0.9 update_interval 3.0 total_run_times 0 own_window yes own_window_type normal own_window_transparent yes own_window_hints undecorated,below,sticky,skip_taskbar,skip_pager double_buffer yes minimum_size 220 5 maximum_width 220 draw_shades yes draw_outline no draw_borders no draw_graph_borders yes default_color white default_shade_color black default_outline_color green alignment bottom_right gap_x 12 gap_y 35 no_buffers yes uppercase no cpu_avg_samples 2 override_utf8_locale no uppercase yes # set to yes if you want all text to be in uppercase TEXT ${color white}SYSTEM ${hr 1}${color} Hostname: $alignr$nodename Kernel: $alignr$kernel Uptime: $alignr$uptime ${color white}Banshee${hr 2}${color white} ${exec banshee-1 --query-artist} ${exec banshee-1 --query-title} ${exec banshee-1 --query-track-number} ${exec banshee-1 --query-album} CPU: ${alignr}${freq} MHz Processes: ${alignr}$processes ($running_processes running) Load: ${alignr}$loadavg CPU1 ${alignr}${cpu cpu1}% ${cpubar 4 cpu1} CPU2 ${alignr}${cpu cpu2}% ${cpubar 4 cpu2} Ram ${alignr}$mem / $memmax ($memperc%) ${membar 4} swap ${alignr}$swap / $swapmax ($swapperc%) ${swapbar 4} Highest CPU $alignr CPU% MEM% ${top name 1}$alignr${top cpu 1}${top mem 1} ${top name 2}$alignr${top cpu 2}${top mem 2} ${top name 3}$alignr${top cpu 3}${top mem 3} Highest MEM $alignr CPU% MEM% ${top_mem name 1}$alignr${top_mem cpu 1}${top_mem mem 1} ${top_mem name 2}$alignr${top_mem cpu 2}${top_mem mem 2} ${top_mem name 3}$alignr${top_mem cpu 3}${top_mem mem 3} ${color white}Filesystem ${hr 1}${color} Root: ${alignr}${fs_free /} / ${fs_size /} ${fs_bar 4 /} Home: ${alignr}${fs_free /home} / ${fs_size /home} ${fs_bar 4 /home} Windows: ${alignr}${fs_free /media/sda3} / ${fs_size /media/sda3} ${fs_bar 4 /media/sda3} Film og serier: ${alignr}${fs_free /media/sdb1} / ${fs_size /media/sdb1} ${fs_bar 4 /media/sdb1} ${color white}NETWORK ${hr 1}${color} Down ${downspeed wlan0} k/s ${alignr}Up ${upspeed wlan0} k/s ${downspeedgraph wlan0 25,107} ${alignr}${upspeedgraph wlan0 25,107} Total ${totaldown wlan0} ${alignr}Total ${totalup wlan0} Lenke til kommentar
indietrash Skrevet 23. desember 2008 Del Skrevet 23. desember 2008 Oppdater gjerne første posten i tråden med denne linken.En sinnnsyk stor tråd med conkyrc og screenshots. ikke-medlemmer kan ikke se vedlegg som f.eks bilder. Lenke til kommentar
ole_marius Skrevet 23. desember 2008 Del Skrevet 23. desember 2008 noen som har en fin guide til å sette opp conky? fant engelsk som ikke funket og en norsk som var enda verre Lenke til kommentar
indietrash Skrevet 23. desember 2008 Del Skrevet 23. desember 2008 noen som har en fin guide til å sette opp conky? fant engelsk som ikke funket og en norsk som var enda verre sette den opp hvordan? for bare generelt oppsett av de tinga du vil ha med er man conky å anbefale. Lenke til kommentar
ole_marius Skrevet 23. desember 2008 Del Skrevet 23. desember 2008 noen som har en fin guide til å sette opp conky? fant engelsk som ikke funket og en norsk som var enda verre sette den opp hvordan? for bare generelt oppsett av de tinga du vil ha med er man conky å anbefale. har lyst på den Runarbs har, men vet ikke fremgangsmåten Lenke til kommentar
indietrash Skrevet 23. desember 2008 Del Skrevet 23. desember 2008 ctrl+c & ctrl+v Lenke til kommentar
ole_marius Skrevet 23. desember 2008 Del Skrevet 23. desember 2008 gjorde som du sa og antokk i terminalen, og det skjedde ikke noe, uansett så her er min conky (vist på bilde) denne skal jeg gå bort fra Lenke til kommentar
indietrash Skrevet 23. desember 2008 Del Skrevet 23. desember 2008 du må lime det inn i din conky-konfigurasjonsfil. Lenke til kommentar
ole_marius Skrevet 23. desember 2008 Del Skrevet 23. desember 2008 føler meg veldig dum nå... men hvor er denne konfigurasjons filen, og kan jeg redigere den gjennom terminalen? ps. (hvis du lurer har jeg ubuntu 8.10) Lenke til kommentar
indietrash Skrevet 23. desember 2008 Del Skrevet 23. desember 2008 i hjemmemappa har du en fil som heter .conkyrc. hvis ikke får du bare opprette den. lim alt inn i den fila. Lenke til kommentar
ole_marius Skrevet 23. desember 2008 Del Skrevet 23. desember 2008 takker og bukker, men er det mulig å gjøre slik at den ikke detter ut når jeg trykker på hvis skrivebord? den forsviner og den eneste måten å få den frem igjen er å trykke på hvis skrivenord, litt irriterende egentlig Lenke til kommentar
indietrash Skrevet 23. desember 2008 Del Skrevet 23. desember 2008 window rules. aner ikke hvilken vindusbehandler du bruker. anbefaler deg å lage ny tråd Lenke til kommentar
ole_marius Skrevet 23. desember 2008 Del Skrevet 23. desember 2008 ok, skal gjøre det. takk for at du tok deg tid Lenke til kommentar
molland Skrevet 23. desember 2008 Forfatter Del Skrevet 23. desember 2008 Hei Nå kopierte jeg inn Smif sin config her i min .conkyrc mappe, men det eneste som skjer er att skjermen blir hvit og ikke noe som helst info. Alt det som står med # først skal de fortsatt være med i den mappa, eller kan de fjernes? Frode Lenke til kommentar
Smif Skrevet 23. desember 2008 Del Skrevet 23. desember 2008 Hei Nå kopierte jeg inn Smif sin config her i min .conkyrc mappe, men det eneste som skjer er att skjermen blir hvit og ikke noe som helst info. Alt det som står med # først skal de fortsatt være med i den mappa, eller kan de fjernes? Frode .conkyrc er ingen mappe, det er en fil. Altså configfila du skal lime alt inn i. Lenke til kommentar
molland Skrevet 23. desember 2008 Forfatter Del Skrevet 23. desember 2008 jaja, fil da Henger litt windows igjen Men jeg kopierte over alt som du hadde her, og la det under (erstattet den teksten) linjene med # foran. Men ikke noen forandringen utenom att det ble hvitt Frode Lenke til kommentar
jonnor Skrevet 23. desember 2008 Del Skrevet 23. desember 2008 molland: .conkyrc er en fil, ikke en mappe. Og du må fjerne det du hadde der fra før når du kopierer inn noe nytt, ellers er det store sannsynligheter for konflikter, ihvertfall når du bare kopierer inn blindt. Det som står med # og over seksjonen TEXT er kommentert bort og har dermed ingen effekt. Og folkens, vennligst les dokumentasjoen til et program før dere kommer hit og spør om det. Sett dere litt inn i ting så får vi en mye mer produktiv diskusjon. http://conky.sourceforge.net/documentation.html Lenke til kommentar
Smif Skrevet 23. desember 2008 Del Skrevet 23. desember 2008 (endret) Du kan også prøve å starte conky fra terminalen med conky --config=/home/bruker/.conkyrc dette tvinger conky til å bruke den gitte configfila, altså du er sikker på hva som blir brukt. Edit: Hvilket grafikkort bruker du forresten. Jeg prøvde conky på et ati 4870 med ati sine nyeste drivere og compiz, noe som gjorde conky buggete.. jeg la da veldig lite forskning i det, men mulig du merker noe av det samme?` Endret 23. desember 2008 av Smif Lenke til kommentar
molland Skrevet 23. desember 2008 Forfatter Del Skrevet 23. desember 2008 (endret) [frode@localhost ~]$ conky --config=/home/frode/.conkyrc Conky: use_spacer should have an argument of left, right, or none. 'yes' seems to be some form of 'true', so defaulting to right. Conky: unknown variable wireless_essid Conky: unknown variable wireless_link_qual_perc Conky: unknown variable wireless_bitrate Conky: forked to background, pid is 8161 [frode@localhost ~]$ Conky: desktop window (1e00034) is subwindow of root window (67) Conky: drawing to desktop window Conky: drawing to double buffer Conky: can't open /sys/class/power_supply/C137/uevent: No such file or directory Conky: can't open /proc/acpi/battery/C137/state: No such file or directory Conky: can't open /sys/class/power_supply/C137/uevent: No such file or directory Conky: can't open /proc/acpi/battery/C137/state: No such file or directory Conky: can't open /proc/apm: No such file or directory X Error of failed request: BadMatch (invalid parameter attributes) Major opcode of failed request: 156 (RENDER) Minor opcode of failed request: 4 (RenderCreatePicture) Serial number of failed request: 280 Current serial number in output stream: 287 Dette kommer når jeg skrev conky i terminal.. i oppstarten står det att files ikke finnes. Men det gjør den jo Frode EDIT, usikker på skjermkort, har en compaq nc6220 laptop Endret 23. desember 2008 av molland Lenke til kommentar
