[Løst]Maskinen starter ikke etter at jeg installerte et spill.
Hei. Jeg innstallerte nettopp inn et spill (Rainbow Six: Lockdown) og når jeg skulle starte det måtte jeg installere et program som visstnok skulle forhindre piratvirksomhet. Etter det måtte jeg starte PC'n på nytt. Så kom problemet. Det kommer opp en melding om at det er noe problemer med en systemfil, \Windows\System32\drivers\sfsync02.sys (status: 0xc0000428 - kan ikke bekrefte den digitale signaturen), og at jeg skal sette inn Vista-installasjons-CD'n, for så å gå inn på Språkinnstillinger, klikke på neste også "Reparer datamaskinen". Men når jeg da setter inn Vista-CD'n og starter maskinen på nytt, kommer jeg til en annen meny der det står at det er problemer med noe. Noen som kan hjelpe meg?
Klipp&Lim:
"Do-it-yourself StarForce Removal
Even if you uninstall a StarForce-dependent game, the StarForce device
driver itself stays on your system. Here's a handy three-step guide to
removing all traces of the StarForce software (special thanks to the astute
folks at the glop.org forums for documenting this procedure).
Remove the device drivers. Select the System icon in your Windows Control
Panel. Click the Device Manager button in the hardware tab and then select
"Show Hidden Devices" from the View menu. Now check the Non-Plug and Play
Drivers device tree, and you should find a few StarForce entries. Uninstall
these and reboot your PC.
Delete the system files. Browse to your C:\Windows\system32\drivers folder
and look for a trio of files called sfdrv01.sys, sfhlp02.sys, and
sfsync02.sys (the actual numbers on the files may be different for you).
Delete 'em.
Clean your registry. While this isn't a very difficult step, it does involve
tinkering with your Windows registry-so be careful here, as damaging your
registry could cause serious system problems. Now that you've been properly
warned, type "regedit" into the Run dialog box from your start menu. Once
the Registry Editor opens, select the Find option from the Edit menu. Now
search your registry for all instances of "sfdrv," "sfhlp," and "sfsync,"
deleting the offending registry keys as they turn up. Once that's done,
close the Registry Editor and reboot your PC-which should now be StarForce
free."
