WinMgmt.exe
Fant dette på et dansk forum, (hvis nokken skulle være interessert):
I er galt på den. Her er den rigtige forklaring:
YMPTOMS
When you start your computer, you may receive the following error message:
Winmgmt.exe has generated errors and will be closed by Windows. You will need to restart the program. An error log is being created.
The error message appears approximately every 30 seconds.
CAUSE
This behavior can occur if files in the %SystemRoot%System32WbemRepository folder become corrupted. The error message appears repeatedly because Winmgmt.exe polls the files every 30 to 60 seconds.
RESOLUTION
To resolve this behavior, delete and then re-create the files in the %SystemRoot%System32WbemRepository folder:
On the Desktop, right-click My Computer, and then click Manage.
Under Services and Applications, click Services, and then turn off and stop the Windows Management Instrumentation service.
Delete all of the files that are in the %SystemRoot%System32WbemRepository folder. (Make a backup copy before you delete the files.)
Open Services and Applications, click Services, and then turn on and start the Windows Management Instrumentation service. The files are recreated when the service restarts based on the information provided in the following registry key:
HKEY_LOCAL_MACHINESOFTWAREMicrosoftWBEMCIMOMAutorecover MOFs
NOTE: Some programs will not add their Managed Object Format (MOF) files to this list, in this case, rebuilding the WMI database may cause those programs to generate errors or fail and may require more troubleshooting of their specific WMI requirements.
Wonka
  • 4 måneder senere...
