hvordan mounte cdrom?
merklig problem, jeg kjører mandrake 9.1
skal installere unreal tournament, cden er inni (orginal ut (totally unreal)) jeg kan se filene på cdrom i filbehandling, men når jeg kjører install så får jeg opp meldingen "please mount the unreal t cdrom for linux, choose yes to retry..
Mandrake 9.0 hadde også noen problemer med CRRom-en, se http://www.mandrakelinux.com/en/90errata.php3 .
commandline to rewrite the boot information.
Error scenario: When using urpmi or rpmdrake, there is an error about package not found before accessing the CD-ROM. Another possible error message is "Everything already installed."
Why: The installer misconfigured the medium description of Contribution packages.
Solution: Insert the Installation CD (CD-ROM #1) and issue the command "urpmi.update cdrom8" as root.
Hjalp dette?
