firmware crack til BDP-S550?
  • 1 måned senere...
Scotty has passed on to me the following confirmed working instructions (I have been advised that this is the same for the 550 and 5000ES).
Programming the 7040 OneforAll remote to enable region free playback of DVD’s on the Sony BDP-S350
Quote:
1. Press DVD
2. Hold the magic button until the DVD button flashes twice.
3. Press 0533
4. Hold the magic button until the DVD button flashes twice.
5. Press 994
6. Press Magic Key (don't hold)
7. Press 1891 (this sets key 1 – the DVD button flashes twice)
8. Hold the magic button until the DVD button flashes twice.
9. Press 994
10. Press Magic Key (don't hold)
11. Press 2552 (this sets key 2 – the DVD button flashes twice)
12. Hold the magic button until the DVD button flashes twice.
13. Press 994
14. Press Magic Key (don't hold)
15. Press 0953 (this sets key 3 – the DVD button flashes twice)
16. Hold the magic button until the DVD button flashes twice.
17. Press 994
18. Press Magic Key (don't hold)
19. Press 2214 (this sets key 4 – the DVD button flashes twice)
20. Hold the magic button until the DVD button flashes twice. .
21. Press 994
22. Press Magic Key (don't hold)
23. Press 0795 (this sets key 5 – the DVD button flashes twice)
Done - the remote is now programmed and ready to use
Quote:
1. Now to make your player region free use the Sony remote that came with the player to bring it out of standby and wait while HOME is displayed
2. Make sure there isn't a disc in the machine.
3. Now on the OneforAll remote press 1, 2, 3, 4, 5 (The blue 24p light on the player will start flashing)
4. Put the player back into standby with the Sony remote
5. That’s it, the next time you turn on the player it will be region free for DVD playback
If the blue 24p light doesn’t flash then it hasn’t worked, try a new set of batteries and start a fresh
avforums.com | multiregion
Trenger remote for å gjøre det though. All info står i tråden I guess
  • 4 måneder senere...
noen som vei hvor man får tak på firmware til BDP-S550 slik den blir regions fri?
/E
Jeg ett sett igjen, settet krever meget gode loddekunnskaper men utførlig veiledninger med bilder og alt er veldig bra.
Har ett sett til 550 og ett sett til 350.
Pris er 900stk inkl forsendelse.
Firmware for og gjøre dette er IKKE mulig.
DETTE GJELDER ALTSÅ SONEFRI PÅ BD SONE A+B samt ABC
De andre forlkaringene her ang. remote\fjernkontroll gjør IKKE din spiller sonefri på BD, men kun dvd.
Endret av hexman
