Sammen skal vi lage: Gjestebok
<?php
class Guestbook {
private $numEntriesPerPage = 10;
private $connection;
private $entries;
public function __construct(PDO $connection) {
	$this->connection = $connection;
public function addEntry(GuestbookEntry $entry) {
public function fetchEntries(array $options = array()) {
	$stmt = $this->connection->prepare($sql);
class GuestbookEntry {
public $author		= '';
public $message;
public $createdAt;
public $ip;
public function __set($key, $value) {
	if (isset($this->$key)) {
		$this->$key = $value;
Fikset Guestbook::addEntry().
<?php
class Guestbook {
private $entries;
	$this->entries[] = $entry;
public $message;
public $createdAt;
public $ip;
Edit @ Josh Homme: Gjør ting i riktig rekkefølge? $stmt = $this->connection->prepare($sql); - Hvor kommer $sql fra? Hva har koden med resten av klassen å gjøre?
Endret av Lokaltog
Ryddet opp.
<?php
class Guestbook {
private $entries;
	$sql = "SELECT * FROM guestbook;";
public $message;
public $createdAt;
public $ip;
EDIT: glemte et semikolon.
Endret av LarsAndre
CREATE  TABLE `guestbook` (
  `id` INT NOT  NULL  AUTO_INCREMENT ,
   `name` VARCHAR( 255  )  NOT  NULL ,
   `email` VARCHAR( 255  )  NOT  NULL ,
   `website` VARCHAR( 255  )  NOT  NULL ,
   `comment` TEXT NOT  NULL ,
   `date` VARCHAR( 255  )  NOT  NULL ,
   `ip` VARCHAR( 255  )  NOT  NULL ,
PRIMARY  KEY (  `id`  ) ) ENGINE  = InnoDB
Endret Guestbook::fetchEntries().
<?php
class Guestbook {
private $entries;
	$stmt->execute();
public $message;
public $createdAt;
public $ip;
Langt fra noen ekspert i mysql, men her er et forslag til tabellen:
 `id` SMALLINT UNSIGNED NOT NULL AUTO_INCREMENT,
 `author` VARCHAR(100) NOT NULL,
 `email` VARCHAR(100) NOT NULL,
 `website` VARCHAR(100),
 `message` TEXT NOT NULL,
 `date` INT UNSIGNED NOT NULL,
 `ip` INT UNSIGNED NOT NULL,
 PRIMARY KEY (`id`)
CHARACTER SET utf8;
PS! Bruker INET_ATON og INET_NTOA for lagre IP i tabellen.
Endret av LarsAndre
Har alltid brukt å lagre UNIX timestamp i databasen, men når en bruker TIMESTAMP-datatypen blir det lagret i dette formatet "1970-01-01 00:00:01" i stedet for sekunder etter 1.1.1970. UNIX-timestampet, altså sekunder etter 1.1.1970, brukes for så vidt i alle datofunksjonene til PHP. Mulig jeg tar feil her, men er ganske sikker på dette.
<?php
class Guestbook {
private $entries;
	$stmt->execute();
	$this->entries = $stmt->fetchAll();
public $message;
public $createdAt;
public $ip;
Endret av Eirikkkkkk
Endret: La til PDO::FETCH_CLASS.
<?php
class Guestbook {
private $entries;
	$stmt->execute();
	$this->entries = $stmt->fetchAll(PDO::FETCH_CLASS, 'GuestbookEntry');
public $id;
public $author;
public $message;
public $date;
public $ip;
Endret av LarsAndre
For å svare deg, LarsAndre:
Du kan enkelt hente ut UNIX-timestampet fra et TIMESTAMP-felt i en MySQL-tabell ved å bruke funksjonen UNIX_TIMESTAMP. Du kan sette inn timestamps ved å bruke FROM_UNIXTIME(). Eksempler:
SELECT UNIX_TIMESTAMP(date) timestamp FROM table
INSERT INTO table SET date = FROM_UNIXTIME(4372548957)
Fordelen med å bruke et TIMESTAMP-felt eller et annet felt som er beregnet på tid er at det funker fint sammen med tids-funksjonene i MySQL.
La til $mail.
<?php
class Guestbook {
private $entries;
	$stmt->execute();
public $id;
public $author;
public $mail;
public $message;
public $date;
public $ip;
La til __destruct. (Ideen er å lagre entries som kan ha blitt lagt til, noe man f.eks. kan se ved at elementet ikke har en ID)
<?php
class Guestbook {
private $entries;
	$stmt->execute();
public function __destruct () {}
public $id;
public $author;
public $mail;
public $message;
public $date;
public $ip;
Jeg har ingen aning hva en guestbook er engang (er det slik som var vanlig på hjemmesider på nittitallet som bare er en lang rekke oppføringer listet kronologisk?), så jeg vet ikke hvordan strukturen bør være, jeg bare endret LarsAndres litt. Jeg regner med at registrerte brukere og søking utgår?
CREATE DATABASE `guestbook` DEFAULT CHARACTER SET utf8 COLLATE utf8_swedish_ci;
CREATE TABLE `entries` (
 `created` datetime NOT NULL default '0000-00-00 00:00:00',
 `deleted` datetime NOT NULL default '0000-00-00 00:00:00',
 PRIMARY KEY (`id`)
) ENGINE=InnoDB;
Jeg tar meg friheten til å poste en gang til siden forige var SQL og bare en endring av eksisterende kode. :)
Siden denne galmannsgjesteboken objektifiserer hver oppføring vil jeg legge til litt cache slik at serveren ikke brekker etter et par titalls requests i sekundet.
<?php
class Guestbook {
private $entries;
private $memcacheConnection;
	$stmt->execute();
public $id;
public $author;
public $mail;
public $message;
public $date;
public $ip;
La til en for-løkke i __destruct.
<?php
class Guestbook {
private $entries;
	$stmt->execute();
	for ( $i = 0; $i < count ( $this->entries ); $i++ ) {}
public $id;
public $author;
public $mail;
public $message;
public $date;
public $ip;
Forbedret for-løkken i __destruct.
<?php
class Guestbook {
private $entries;
	$stmt->execute();
	for ( $i = 0, $iMax = count ( $this->entries ); $i < $iMax; $i++ ) {}
public $id;
public $author;
public $mail;
public $message;
public $date;
public $ip;
La til en linje under for-løkken i __destruct.
<?php
class Guestbook {
private $entries;
	$stmt->execute();
	for ( $i = 0, $iMax = count ( $this -> entries ); $i < $iMax; $i++ ) {
		if ( empty ( $this -> entries[$i] -> id ) ) {}
public $id;
public $author;
public $mail;
public $message;
public $date;
public $ip;
Endret av Jonas
La til en MC-relatert test.
<?php
class Guestbook {
private $entries;
	if ( $this->mcConnected ) {}
	$stmt->execute();
public $id;
public $author;
public $mail;
public $message;
public $date;
public $ip;
Har egentlig alltid brukt min egen databaseklasse, er dette korrekt utførelse med PDO?
<?php
class Guestbook {
private $entries;
	$stmt->execute();
			$sql = sprintf ( "INSERT INTO entries (author, email, website, message, ip) VALUES('%s', '%s', '%s', '%s', INET_ATON('%s'))",
							 $this -> connection -> quote ( $this -> entries[$i] -> author ),
							 $this -> connection -> quote ( $this -> entries[$i] -> email ),
							 $this -> connection -> quote ( $this -> entries[$i] -> website ),
							 $this -> connection -> quote ( $this -> entries[$i] -> message ),
							 $this -> connection -> quote ( $_SERVER['REMOTE_ADDR'] ) );
public $id;
public $author;
public $mail;
public $message;
public $date;
public $ip;
