Finner ikke ext2 partisjonen i Vista
Ståle
Du må ha ett program som støtter LVM, dette er den måten Redhat hånterer diskvolumer:
LVM (Logical Volume Management) partitions provide a number of advantages over standard partitions. LVM partitions are formatted as physical volumes. One or more physical volumes are combined to form a volume group. Each volume group's total storage is then divided into one or more logical volumes. The logical volumes function much like standard data partitions. They have a file system type, such as ext3, and a mount point.
An administrator may grow or shrink logical volumes without destroying data, unlike standard disk partitions. If the physical volumes in a volume group are on separate drives then administrators may also spread a logical volume across multiple disks and RAID arrays.
