V?rbris Skrevet 1. desember 2008 Del Skrevet 1. desember 2008 Hei Trenge litt hjelp til oppdatering av ei datamaskin. Hovedkortet er ett ASUS P5B socket LGA775 Legger her noen krav jeg har. Må ha 4 GB minne, Har nå 2 GB Bedre lagringskapasitet - + 250 GB - har nå 150 GB pluss ett par mindre disker Bedre skjermkort har nå ATI Radeon HT 2600XT. Bedre/større prossessor har nå Intel core duo 6300 1,86Ghz Minnet jeg har er DDR2 pc2-5300 , men kan jeg bruke annet f.eks pc6400? Legger ved ett masinvareinfo: CPU-Z 1.48 report file Processor(s) Number of processors 1 Number of cores 2 per processor Number of threads 2 per processor Name Intel Core 2 Duo E6300 Code Name Conroe Specification Intel® Core2 CPU 6300 @ 1.86GHz Package Socket 775 LGA Family/Model/Stepping 6.F.6 Extended Family/Model 6.F Core Stepping B2 Technology 65 nm Core Speed 1601.3 MHz Multiplier x Bus speed 6.0 x 266.9 MHz Rated Bus speed 1067.6 MHz Stock frequency 1866 MHz Instruction sets MMX, SSE, SSE2, SSE3, SSSE3, EM64T L1 Data cache (per processor) 2 x 32 KBytes, 8-way set associative, 64-byte line size L1 Instruction cache (per processor) 2 x 32 KBytes, 8-way set associative, 64-byte line size L2 cache (per processor) 2048 KBytes, 8-way set associative, 64-byte line size Chipset & Memory Northbridge Intel P965/G965 rev. C2 Southbridge Intel 82801HB/HR (ICH8/R) rev. 02 Graphic Interface PCI-Express PCI-E Link Width x16 PCI-E Max Link Width x16 Memory Type DDR2 Memory Size 2048 MBytes Memory Frequency 333.6 MHz (4:5) CAS# Latency (tCL) 5.0 clocks RAS# to CAS# (tRCD) 5 clocks RAS# Precharge (tRP) 5 clocks Cycle Time (tRAS) 15 clocks Command Rate (CR) 2T System System Manufacturer System manufacturer System Name System Product Name System S/N System Serial Number Mainboard Vendor ASUSTeK Computer INC. Mainboard Model P5B BIOS Vendor American Megatrends Inc. BIOS Version 1604 BIOS Date 07/13/2007 Memory SPD Module 1 DDR2, PC2-5300 (333 MHz), 1024 MBytes, Transcend Information Module 2 DDR2, PC2-5300 (333 MHz), 1024 MBytes, Transcend Information Software Windows Version Microsoft Windows XP Professional Service Pack 3 (Build 2600) DirectX Version 9.0c Er det noe som har gode oppgraderingsforslag? Vil en større prossessor gi stor forskjell, eller er det mere å hente ved å sette inn 2+2GB minne og oppnå 6 GB ( forutsatt det er 4 minnebanker på kortet ). Spiller på maskinen svært sjelden, men bruker den mye til video og bilderedigering, hva gjør susen angående skjermkort? Kjører gjerne flere program samtidig også, tildels tunge program. Sist, og kanskje ikke minst, strømforsyning, der vet jeg ikke helt hva som er montert. Forslag taes i mot med takk, også ting som jeg må være oppmerksom på, f.eks. mulig oppgradering av bios ved cpu bytte. Lenke til kommentar
Pastafarian Skrevet 1. desember 2008 Del Skrevet 1. desember 2008 Kan alltids investere i en Quad. Velg etter budsjett. Samme hvilke DDR2 brikker du velger. PC6400 brikker skal i utgangspunktet fungere fint, men vil gå på hastigheten til de tregeste brikkene uten at det har noe særlig å si. Du trenger 64-bit OS for å utnytte noe mer enn ca 3,5GB minne. Om du ikke spiller ser jeg ikke noen særlig grunn til å oppdatere skjermkortet. Lenke til kommentar
V?rbris Skrevet 1. desember 2008 Forfatter Del Skrevet 1. desember 2008 (endret) Kan alltids investere i en Quad. Velg etter budsjett. Samme hvilke DDR2 brikker du velger. PC6400 brikker skal i utgangspunktet fungere fint, men vil gå på hastigheten til de tregeste brikkene uten at det har noe særlig å si. Du trenger 64-bit OS for å utnytte noe mer enn ca 3,5GB minne. Om du ikke spiller ser jeg ikke noen særlig grunn til å oppdatere skjermkortet. Takk Jeg forstår det slik at det er forskjell på en core2 duo og Quad CPU? Lurte på dette angående minnebrikke, da jeg har fått forskjellige svar fra dataselgere. Noen mente jeg burde holde meg til type DDR2 PC5300, mens andre anbefalte PC6400, og noen mente mitt kort muligens støttet PC8500. Nei jeg spiller svært sjeldent, men det har også bakgrunn i svakt integrert skjermkort i en tidligere maskin. Kanskje en ide å bruke disse penger i en kraftigere cpu? Har også sett på nettet at man ikke får utnyttet særlig mere enn 4 gb minne med 32-bit OS. Vet ikke helt om dette lar seg oppgradere fra 32 OS bit til 64 bit OS. Har også minst ett program som bare lar seg kombinere med 32 bit OS ( Malwarebytes kjøpeprogram). Fikk denne anbefaling fra ett firma: Prosessor: Intel Core 2 Duo E8400 3.0GHz - Pris: 1549 kr Med denne tilleggsmelding: Prosessoren er kompatibel, men det er mulig du må oppdatere til en nyere BIOS versjon. Dette må gjøres før du installerer den nye prosessoren. Har denne biosversjon som også er gjengitt ovenfor: System Manufacturer System manufacturer System Name System Product Name System S/N System Serial Number Mainboard Vendor ASUSTeK Computer INC. Mainboard Model P5B BIOS Vendor American Megatrends Inc. BIOS Version 1604 BIOS Date 07/13/2007 Endret 1. desember 2008 av ulfjoh01 Lenke til kommentar
Pastafarian Skrevet 1. desember 2008 Del Skrevet 1. desember 2008 Ser nå egentlig ut som du finner ut av dette selv. Ja, du vil ganske sikkert måtte oppdatere bios. Quad gir bare gevinst over duo i apps som støtter mer enn to tråder, sjekk om du til vanlig kjører slike. Eller om du driver med tung multitasking. Du skal kunne kombinere DDR2 minne fritt, men ser ikke helt poenget med raskere brikker enn de du har om du ikke overklokker. Rådet er derfor kjøp det billigste PC6400 settet du finner evt et PC5300 sett. Skjermkort som gir mye ytelse for kronene er f.eks ATI4850. Lenke til kommentar
Skagen Skrevet 2. desember 2008 Del Skrevet 2. desember 2008 Tråden var feilpostet og har blitt flyttet til riktig kategori. (Vennligst ikke kommenter dette innlegget. Reaksjoner på moderering gjøres pr. PM/melding) Lenke til kommentar
