Feil ved brenning! Brenneren?
I det siste så har det blitt bare flere og flere feil brenninger når jeg skal brenne dvd'er.
Her er loggen fra en av feilbrenningene vis noen fortår seg på slikt:
Windows XP 5.1
IA32
WinAspi: -
ahead WinASPI: File 'C:\Program Files\Nero\Nero 7\Core\Wnaspi32.dll': Ver=2.0.1.74, size=164112 bytes, created 02.11.2004 12:54:32
NT-SPTI used
Nero Version: 7.0.8.2
Internal Version: 7, 0, 8, 2
Recorder: <HL-DT-ST DVDRAM GSA-4084N>Version: KQ09 - HA 1 TA 0 - 7.0.8.2
Adapter driver: <IDE> HA 1
Drive buffer : 2048kB
Bus Type : default (0) -> ATAPI, detected: ?
CD-ROM: <GLUZA AJ8LUNS >Version: 1.03 - HA 1 TA 1 - 7.0.8.2
=== Scsi-Device-Map ===
CdRomPeripheral : HL-DT-ST DVDRAM GSA-4084N atapi Port 0 ID 0 DMA: On
DiskPeripheral : ST9120821AS iaStor Port 1 ID 0 DMA: On
CdRomPeripheral : GLUZA AJ8LUNS 1.03 azyu0qha Port 2 ID 0 DMA: Off
=== CDRom-Device-Map ===
HL-DT-ST DVDRAM GSA-4084N E: CDRom0
GLUZA AJ8LUNS F: CDRom1
AutoRun : 1
Excluded drive IDs:
WriteBufferSize: 83886080 (0) Byte
BUFE : 0
Physical memory : 1021MB (1046508kB)
Free physical memory: 356MB (365144kB)
Memory in use : 65 %
Uncached PFiles: 0x0
Use Inquiry : 1
Global Bus Type: default (0)
Check supported media : Disabled (0)
24.11.2008
Brenn DVD-Image
14:43:41 #1 Text 0 File ThreadedTransfer.cpp, Line 531
ReadBuffer-Pipe got 262144KB of Memory
14:43:41 #2 Text 0 File Reader.cpp, Line 124
Reader running
14:43:41 #3 Text 0 File Writer.cpp, Line 113
Writer E: HL-DT-ST DVDRAM GSA-4084N running
14:43:42 #4 Text 0 File Burncd.cpp, Line 3353
Turn on Disc-At-Once, using DVD media
14:43:42 #5 Text 0 File DlgWaitCD.cpp, Line 289
Last possible write address on media: 2298495 (510:46.45, 4489MB)
Last address to be written: 2270343 (504:31.18, 4434MB)
14:43:42 #6 Text 0 File DlgWaitCD.cpp, Line 301
Write in overburning mode: NO (enabled: CD)
14:43:42 #7 Text 0 File DlgWaitCD.cpp, Line 2715
Recorder: HL-DT-ST DVDRAM GSA-4084N, Media type: DVD-R
Disc Manufacturer: MCC 03 - RG20
Disc Application Code: 64, Disc Physical Code: 193
14:43:42 #8 Text 0 File DlgWaitCD.cpp, Line 473
>>> Protocol of DlgWaitCD activities: <<<
14:43:42 #9 Text 0 File ThreadedTransferInterface.cpp, Line 847
Setup items (after recorder preparation)
0: TRM_DATA_MODE1 (2 - CD-ROM-Modus 1, ISO 9660)
2 indices, index0 (150) not provided
original disc pos #0 + 2270344 (2270344) = #2270344/504:31.19
not relocatable, disc pos for caching/writing not required/not required, no patch infos
-> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 2270344 blocks [E: HL-DT-ST DVDRAM GSA-4084N]
14:43:42 #10 Text 0 File ThreadedTransferInterface.cpp, Line 1059
Prepare recorder [E: HL-DT-ST DVDRAM GSA-4084N] for write in CUE-sheet-DAO
DAO infos:
MCN: ""
TOCType: 0x00; Session Closed, disc not fixated
Tracks 1 to 1:
1: TRM_DATA_MODE1, 2048/0x00, FilePos 0 0 4649664512, ISRC ""
DAO layout:
__Start_|____Track_|_Idx_|_CtrlAdr_|_RecDep__________
0 | lead-in | 0 | 0x41 | 0x00
0 | 1 | 0 | 0x41 | 0x00
0 | 1 | 1 | 0x41 | 0x00
2270344 | lead-out | 1 | 0x41 | 0x00
14:43:42 #11 Text 0 File SCSIPassThrough.cpp, Line 39
SPTILockVolume - completed successfully for FCTL_LOCK_VOLUME
14:43:42 #12 Text 0 File SCSIPassThrough.cpp, Line 84
SPTIDismountVolume - completed successfully for FSCTL_DISMOUNT_VOLUME
14:43:42 #13 Phase 24 File dlgbrnst.cpp, Line 1730
Caching of files started
14:43:42 #14 Text 0 File Burncd.cpp, Line 4187
Cache writing successful.
14:43:42 #15 Phase 25 File dlgbrnst.cpp, Line 1730
Caching of files completed
14:43:42 #16 Phase 36 File dlgbrnst.cpp, Line 1730
Burn process started at 8x (11 080 KB/s)
14:43:42 #17 Text 0 File ThreadedTransferInterface.cpp, Line 2707
Verifying disc position of item 0 (not relocatable, no disc pos, no patch infos, orig at #0): write at #0
14:43:42 #18 Text 0 File DVDR.cpp, Line 2760
Recording mode: Sequential Recording Mode for Multisession
14:43:42 #19 Text 0 File DVDR.cpp, Line 2916
Start write address at LBA 0
DVD high compatibility mode: Yes
14:43:42 #20 Text 0 File Cdrdrv.cpp, Line 8661
---- DVD Structure: Physical Format Information (00h) ----
Media Type: 0, Layer: 0, Address: 0 (0 h), AGID: 0; Length: 2050
Book Type: DVD-R (2), Part Version: 2.0x (5), Extended Part Version: 2.1 (33)
Disc Size: 120 mm, Maximum Rate: <not specified> (F h)
Number of Layers: 1, Track Path: Parallel Track Path (PTP), Layer Type: recordable
Linear Density: 0,267 um/bit, Track Density: 0,74 um/track
Starting Physical Sector Number of Data Area: 30000 h (DVD-ROM, DVD-R/-RW, DVD+R/+RW)
End Physical Sector Number of Data Area: 26127F h
End Sector Number in Layer 0: 0 h (LBN: FFFD0000 h, 4193920 MB)
Data in Burst Cutting Area (BCA) does not exist
Start sector number of the current Border-Out: 2FE10 h
Start sector number of the next Border-In: 2FFA0 h
Media Specific [16..63]:
00 60 00 10 20 30 40 50 - 00 00 00 21 00 00 00 00 .`...0@P...!....
00 02 FE 10 00 02 FF A0 - 00 00 00 00 00 00 00 00 ..þ...ÿ.........
00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 ................
14:45:44 #21 SPTI -1061 File SCSIPassThrough.cpp, Line 290
E: CdRom0: SCSIStatus(x02) WinError(0) NeroError(-1061)
Sense Key: 0x04 (KEY_HARDWARE_ERROR)
Sense Code: 0x44
Sense Qual: 0x86
CDB Data: 0x2A 00 00 03 8B A0 00 00 20 00 00 00
Sense Area: 0x70 00 04 00 00 00 00 10 32 24 04 0C 44 86
Buffer x04f60000: Len x10000
0x00 00 01 BA 44 3B 84 B4 BC 07 01 89 C3 F8 00 00
0x01 E0 07 EC 81 00 00 46 77 04 EF FD 64 11 34 18
0x4D 3F A8 12 40 0C A2 10 1D 8D 1A 84 00 40 56 F8
14:45:44 #22 CDR -1061 File Writer.cpp, Line 302
Internal target failure
14:45:45 #23 Text 0 File ThreadedTransfer.cpp, Line 228
all writers idle, stopping conversion
14:45:45 #24 Text 0 File ThreadedTransfer.cpp, Line 222
conversion idle, stopping reader
14:45:45 #25 Text 0 File DVDR.cpp, Line 3156
EndDAO: Last written address was 232351
14:45:45 #26 Phase 133 File dlgbrnst.cpp, Line 1730
Writing short lead-out
14:50:51 #27 SPTI -1080 File SCSIPassThrough.cpp, Line 290
E: CdRom0: SCSIStatus(x02) WinError(0) NeroError(-1080)
Sense Key: 0x02 (KEY_NOT_READY)
Sense Code: 0x3A
Sense Qual: 0x00
CDB Data: 0x52 01 00 00 00 02 00 00 24 00 00 00
Sense Area: 0x70 00 02 00 00 00 00 10 00 00 00 00 3A
Buffer x034b5e00: Len x24
14:50:51 #28 SPTI -1080 File SCSIPassThrough.cpp, Line 290
Sense Code: 0x3A
Sense Qual: 0x00
CDB Data: 0x5B 01 02 00 00 03 00 00 00 00 00 00
14:50:51 #29 SPTI -1080 File SCSIPassThrough.cpp, Line 290
Sense Code: 0x3A
Sense Qual: 0x00
CDB Data: 0x51 00 00 00 00 00 00 00 20 00 00 00
Buffer x034efe00: Len x20
14:50:52 #30 CDR -1061 File WriterStatus.cpp, Line 167
14:50:52 #31 TRANSFER -24 File WriterStatus.cpp, Line 167
Could not perform end of Disc-at-once
14:50:52 #32 SPTI -1033 File SCSIPassThrough.cpp, Line 290
E: CdRom0: SCSIStatus(x02) WinError(0) NeroError(-1033)
Sense Code: 0x04
Sense Qual: 0x01
CDB Data: 0x55 10 00 00 00 00 00 00 3C 00 00 00
Sense Area: 0x70 00 02 00 00 00 00 10 00 00 00 00 04 01
Buffer x0348c800: Len x3c
0x00 00 00 00 00 00 00 00 05 32 01 C4 08 00 00 00
0x00 00 00 00 00 00 00 96 00 00 00 00 00 00 00 00
0x00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
14:50:52 #33 Phase 38 File dlgbrnst.cpp, Line 1730
Burn process failed at 8x (11 080 KB/s)
Existing drivers:
File 'Drivers\ADPU160M.SYS': Ver=v3.60a (Lab01_N(johnstra).010529-2218), size=101888 bytes, created 18.08.2001 04:07:32
File 'Drivers\PXHELP20.SYS': Ver=2.03.32a, size=20640 bytes, created 25.04.2005 16:03:00 (Prassi/Veritas driver for win 2K)
Registry Keys:
HKLM\Software\Microsoft\Windows NT\CurrentVersion\WinLogon\AllocateCDROMs : 0 (Security Option)
Men jeg lurte på om det kan være brenneren/dvd'rommen som begynner å ta kveld.
Den har blitt treg i det siste når det gjelder å lese plater, kan ta noen minutter fra jeg setter i en cd'e til den begynner å lese cd'en.
Av og til kommer ikke cd'en ut når jeg trykker på knappen.
