Do0z Skrevet 21. november 2008 Del Skrevet 21. november 2008 Hei alle sammen , jeg sliter litt med pc'en etter jeg byttet ut rammen. Jeg oppgraderte mine; Kingstone 2x512mb (266mhz) ram brikker mot; Mushkin 2x2048mb ram (800mhz). Etter byttet fikk jeg konstant blå crash skjerm , system kresj hver gang jeg skulle kopiere filer over 1gb. Pc'en frøys hele tiden vist jeg behandlet tunge oppgaver. det innebygde lydkortet i HK mitt forsvant ved bytte uansett hvor mange ganger jeg installerte driveren på nytt , så ville det ikke komme tilbake. Hva er galt her? :S Her er pc'spec's; #1 HK ( Hovedkortet ) General Information : Manufacturer : MICRO-STAR INTERNATIONAL CO., LTD (MSI) Product : K9VGM-V Model : MS-7253 Version : 1.0 Serial Number : Unspecified Support MP : Yes, 2 CPU(s) Version MPS : 1.4 Chassis Information : Manufacturer : MICRO-STAR INTERNATIONAL CO., LTD Type : Desktop Version : Unspecified Serial Number : Unspecified Asset : Unspecified Sensor Information : Hardware Monitoring : Winbond W83627EHF/EHG On-Board Device Information : Embedded Controller : Yes Slots Information : Slot PCI : Available (32-bit) 5.0v Slot PCI : Available (32-bit) 5.0v Slot PCI-Express : In Use (32-bit) 5.0v Slot PCI : Available (32-bit) 5.0v Slot AGP : Available (32-bit) 5.0v External Connectors : Serial 16450 Compatible : DB-9 male Serial 16450 Compatible : DB-9 male Parallel ECP/EPP : DB25 female Keyboard : PS/2 Mouse : PS/2 Internal Connectors : PRIMARY IDE : On Board IDE SECONDARY IDE : On Board IDE FDD : On Board Floppy COM1 : 9 Pin Dual Inline (pin 10 cut) COM2 : 9 Pin Dual Inline (pin 10 cut) LPT1 : DB25 female Keyboard : PS/2 PS/2 Mouse : PS/2 #2 CPU ( Prosessor ) General Information : Type : AMD Athlon 64 X2 Internal Specification : AMD Athlon 64 X2 Dual Core Processor 4400+ Model Number : 4400+ Codename : Brisbane Revision : BH-G2 Technology : 0.065µ CPU ID : F.B.2 CPU IDEx : F.6B.2 Brand ID : 4 Microcode : MU0FB20 K8 Revision : 6.0 Instructions : IA-64 Technology : No X86-64 Technology : Yes AVX : No FPU128 : No SSE5 : No SSE4a : No SSE4.2 : No SSE4.1 : No S-SSE3 : No SSE3 : Yes SSE2 : Yes SSE : Yes Extended 3DNow! Technology : Yes 3DNow! Technology : Yes 3DNOW Prefetch : No 3DNow! Pro Technology : Yes AMD MMX Technology : Yes MMX Technology : Yes Cyrix MMX Technology : Yes FMA : No AES : No OSXSAVE : No MOVBE : No PCLMULQDQ : No CLF - Cache Line Flush : Yes CX8 - CMPXCHG8B : Yes CX16 - CMPXCHG16B : Yes CMOV - Conditionnal Move Inst. : Yes MON - Monitor/Mwait : No POPCNT : No RDTSCP : Yes SEP - Fast System Call : Yes #3 Skjermkort General Information : Manufacturer : Nvidia Corp (Pine Technology Ltd) Model : NVIDIA GeForce 8400 GS Bus Type : PCI-Express Total Memory : 512 MB Texture Memory : 620 MB Processor : GeForce 8400 GS Converter : Integrated RAMDAC Refresh Rate (min/max) : 60/75 Hz Codename : G86 Revision : A2 Bus : 128-bit Memory Type : GDDR3 GPU Frequency : 459 MHz - [initial : 459 MHz] Shader Clock : 1836 MHz - [initial : 918 MHz] Memory Frequency GPU : 399.6 MHz - [initial : 400 MHz] DirectX Support : 10 Pixel Shader Version : 3.0 nForceware Configuration : Standard 2D : GPU: 459 MHz - Memory: 400 MHz 3D Performance : GPU: 459 MHz - Memory: 400 MHz 3D Low Power : GPU: 459 MHz - Memory: 400 MHz ForceWare Version : 6.14.11.5827 GPU Configuration : Technology SLi : No AA Mode : 2X Frame Buffered : 3 Video Bios Information : Date : 11/05/07 Version : Version 60.86.4A.00.30 Forceware : 6.14.11.5827 i2C Bus Information : Number of Bus : 4 General Features : Width : 375 mm Height : 300 mm Pixel per inch : 96x96 dpi bits per pixel : 32 Colour Bits/Planes : 1 Brushes : 4294967295 Pens : 4294967295 Markers : 0 Device Fonts : 0 Device Colours : 4294967295 Clip Output to Rectangle : Yes Hardware Acceleration : Yes #4 Kingstone rammen jeg hadde. ( har byttet tilbake til Kingstone rammen foreløpig) General Information : A0 (RAS 0, RAS 1) : 1024 (Double Bank) A1 (RAS 2, RAS 3) : 1024 (Double Bank) Information SPD EEPROM (A0) : Manufacturer : Kingston Part Number : 99U5316-002.A02LF Serial Number : 6C31EC58 Type : DDR2-SDRAM PC2-4300 (266 MHz) - [DDR2-533] Format : Regular UDIMM (133.35 x 3) Size : 1024 MB (2 ranks, 4 banks) Module Buffered : No Module Registered : No Module SLi Ready (EPP) : No Width : 64-bit Error Correction Capability : No Max. Burst Length : 8 Refresh : Reduced (.5x)7.8 µs, Self Refresh Voltage : SSTL 1.8v Prefetch Buffer : 4-bit Manufacture : Week 34 of 2007 Supported Frequencies : 200 MHz, 266 MHz, 266 MHz CAS Latency (tCL) : 3 clocks @200 MHz, 4 clocks @266 MHz, 5 clocks @266 MHz RAS to CAS (tRCD) : 3 clocks @200 MHz, 4 clocks @266 MHz, 4 clocks @266 MHz RAS Precharge (tRP) : 3 clocks @200 MHz, 4 clocks @266 MHz, 4 clocks @266 MHz Cycle Time (tRAS) : 9 clocks @200 MHz, 12 clocks @266 MHz, 12 clocks @266 MHz Min TRC : 12 clocks @200 MHz, 16 clocks @266 MHz, 16 clocks @266 MHz Information SPD EEPROM (A1) : Manufacturer : Kingston Part Number : 99U5316-002.A02LF Serial Number : 6531F558 Type : DDR2-SDRAM PC2-4300 (266 MHz) - [DDR2-533] Format : Regular UDIMM (133.35 x 3) Size : 1024 MB (2 ranks, 4 banks) Module Buffered : No Module Registered : No Module SLi Ready (EPP) : No Width : 64-bit Error Correction Capability : No Max. Burst Length : 8 Refresh : Reduced (.5x)7.8 µs, Self Refresh Voltage : SSTL 1.8v Prefetch Buffer : 4-bit Manufacture : Week 34 of 2007 Supported Frequencies : 200 MHz, 266 MHz, 266 MHz CAS Latency (tCL) : 3 clocks @200 MHz, 4 clocks @266 MHz, 5 clocks @266 MHz RAS to CAS (tRCD) : 3 clocks @200 MHz, 4 clocks @266 MHz, 4 clocks @266 MHz RAS Precharge (tRP) : 3 clocks @200 MHz, 4 clocks @266 MHz, 4 clocks @266 MHz Cycle Time (tRAS) : 9 clocks @200 MHz, 12 clocks @266 MHz, 12 clocks @266 MHz Min TRC : 12 clocks @200 MHz, 16 clocks @266 MHz, 16 clocks @266 MHz Memory Controller Information : Memory Controller : Standard, DIMM Number of connectors : 2 Supported Speed : 70ns, 60ns, 50ns Supported Voltages : 2.9v Error Detection Method : 64-bit ECC Error Correction Capability : None Current/Supported Interleave : 1-way/1-way ############################################### Trenger dere noe mere? Om dere trenger noe mer infor om hardwaren så bare spør. Jeg blir veldig takknemmelig for konkrete & gode forklaringer. MvH Newbie Lenke til kommentar
Mark 9 Skrevet 21. november 2008 Del Skrevet 21. november 2008 Se i denne tråden: https://www.diskusjon.no/index.php?showtopic=1037761 Lenke til kommentar
persistent Skrevet 21. november 2008 Del Skrevet 21. november 2008 Hei Såvidt jeg kan se er det ikke et nForce-kort du har men derimot et Via. Jeg sjekket dette kortet på sidene til komplett; http://www.komplett.no/k/ki.aspx?sku=321979 og dersom du ser her står det at kortet støtter kun 2GB RAM. Ettersom dette er et micro ATX kort med kun 2 RAM-plasser vil det si at det støtter kun 2x1GB RAM... Lenke til kommentar
trondtang Skrevet 21. november 2008 Del Skrevet 21. november 2008 FLashebios? ta ut cmos batteriet? Lenke til kommentar
Do0z Skrevet 22. november 2008 Forfatter Del Skrevet 22. november 2008 Okei , takk for alle de flotte svarene. Lenke til kommentar
