Radeon 8500 fra Amraam
labri
Hadde nettopp en samtale med Amraam. Jeg fikk en del oppklarende info. Eldre powerstrip-versjoner viser visstnok 230 MHz på korta som egentlig er 250. Dette skal være fixa i Powerstrip 3.12 tror jeg det var. I den nyeste versjonen ihvertfall.
Ellers var de 98% sikre på at alle korta de sendte ut med 4ns minne gikk på 250. Hvis kortet mot formodning skulle ha 230, får du pengene tilbake.
Slik jeg forstod det, hadde amraam bestilt 4ns 250 fra Club3D. Og derfor var de selv litt forvirret over oppstyret.
Jeg er ihvertfall lettet. Kortet er antagelig her om få dager. Da får vi se. Det er jo snakk om en del penger her :smile:
Club 3d var ikke klar over 4 ns greien før jeg gjorde dem klar over det. Har er noe mailer jeg hat fått av dem.
I am glad that you are providing us the right information in your country,
can you let us know where are the users getting this information? We are not
selling these cards with 4n/s memory for your information. The 8500 comes
with 3,6 n/s memory which is the first standard card that comes with it. We
know that some other manufacturers are putting the 4 n/s memory to decrease
the cost and make the product more attractive to the purchaser which usually
is the distributor. We do not do that because it does not benefit the user.
If you can provide us this information it will be great help.
Sincerely,
Paul Ma
Club3D
Sales Manager
Så fikk jeg dette:
I am afraid to confirm this. We had a batch that came with 4n/s memory, the
core is 250 and the memory is 239 which is a slight difference.
We apologize for this because we just checked our goods. I have spoken to
the company which distributes the cards to apologize as well as do the
necessary arrangements. We believe that this slight difference will not
really affect the card but instead we have seen that the performance is even
better which we cannot explain under the same setup.
If you have any comments please let us know, we are glad to receive these
news from you and sad that we have given the wrong cards.
Best regards,
Paul
Er det virkelig mulig å få kontakt med den forretningen da?
Jeg har bestilt bl.a. et radeon kort derifra, og har aldri opplevd maken til dårlig service og brutte løfter.
Siste nytt derfra i dag er en telefonsvarer i åpningstida, som gjør at en må bruke tellerskritt hver gang en prøver på nytt. Genialt!!
Styr unna alle som ikke har tålmodighet som en engel.
Dette virker som en bedrift som er tuftet rundt kjøkkenbordet! Fri og bevare meg vel!
Høres jeg frustrert ut?? Ja, jeg er det!!
Leffie:
Jeg synger med på det der! Jeg har blitt
lovet to ganger nå at "pakken skal være i
posten i morgen". Men det er lenge siden
nå! Og skjer d noe...? neida.
Siste gang jeg handler der ja!
Cent~
På min bestilling så skrev jeg ganske enkelt at har de ikke radeon kort inne med 3,6 ns minne på så skal de vente med å sende varene jeg bestilte til de har dette på lager.
Ps. regner med at jeg får det da jeg kjøpte en flatskjerm i tillegg til skjermkortet og de vil vel ha sine 8600 temmelig raskt går eg ut i fra. De taper jo penger jo lengre varene ligger så....
