Problemer med Compiz.
Gjest Slettet+oiasdf79
Heisann
Jeg tenkte jeg skulle teste ut snø-plugin-effekten til Compiz, men jeg får den bare ikke til å virke. Noen forslag?..:)
Fra Terminal:
aleksander@Aleksander-Ubuntu:~$ compiz --replace
Checking for Xgl: not present.
Detected PCI ID for VGA:
Checking for texture_from_pixmap: not present.
Trying again with indirect rendering:
Checking for texture_from_pixmap: present.
Checking for non power of two support: present.
Checking for Composite extension: present.
Comparing resolution (1280x800) to maximum 3D texture size (2048): Passed.
Checking for Software Rasterizer: Not present.
Checking for nVidia: not present.
Checking for FBConfig: present.
/usr/bin/compiz.real (video) - Warn: No 8 bit GLX pixmap format, disabling YV12 image format
/usr/bin/compiz.real (core) - Error: Plugin 'core' has ABI version '20080828', expected ABI version '20080401'.
/usr/bin/compiz.real (snow) - Error: InitObject failed
/usr/bin/compiz.real (core) - Error: Couldn't activate plugin 'snow'
Jeg finner faktisk ikke ut hvilket skjermkort jeg har.. :huh: Det er Intel something. Pc'n er en Acer Aspire 5610Z og jeg bruker standard drivere i Ubuntu.
Endret av Slettet+oiasdf79
Etter litt knoting i terminalen fant jeg ut at Intel driverne ser ut til å være riktig installert?
aleksander@Aleksander-Ubuntu:~$ lspci
00:00.0 Host bridge: Intel Corporation Mobile 945GM/PM/GMS, 943/940GML and 945GT Express Memory Controller Hub (rev 03)
00:02.0 VGA compatible controller: Intel Corporation Mobile 945GM/GMS, 943/940GML Express Integrated Graphics Controller (rev 03)
00:02.1 Display controller: Intel Corporation Mobile 945GM/GMS/GME, 943/940GML Express Integrated Graphics Controller (rev 03)
00:1b.0 Audio device: Intel Corporation 82801G (ICH7 Family) High Definition Audio Controller (rev 02)
00:1c.0 PCI bridge: Intel Corporation 82801G (ICH7 Family) PCI Express Port 1 (rev 02)
00:1c.1 PCI bridge: Intel Corporation 82801G (ICH7 Family) PCI Express Port 2 (rev 02)
00:1c.2 PCI bridge: Intel Corporation 82801G (ICH7 Family) PCI Express Port 3 (rev 02)
00:1c.3 PCI bridge: Intel Corporation 82801G (ICH7 Family) PCI Express Port 4 (rev 02)
00:1d.0 USB Controller: Intel Corporation 82801G (ICH7 Family) USB UHCI Controller #1 (rev 02)
00:1d.1 USB Controller: Intel Corporation 82801G (ICH7 Family) USB UHCI Controller #2 (rev 02)
00:1d.2 USB Controller: Intel Corporation 82801G (ICH7 Family) USB UHCI Controller #3 (rev 02)
00:1d.3 USB Controller: Intel Corporation 82801G (ICH7 Family) USB UHCI Controller #4 (rev 02)
00:1d.7 USB Controller: Intel Corporation 82801G (ICH7 Family) USB2 EHCI Controller (rev 02)
00:1e.0 PCI bridge: Intel Corporation 82801 Mobile PCI Bridge (rev e2)
00:1f.0 ISA bridge: Intel Corporation 82801GBM (ICH7-M) LPC Interface Bridge (rev 02)
00:1f.2 IDE interface: Intel Corporation 82801GBM/GHM (ICH7 Family) SATA IDE Controller (rev 02)
00:1f.3 SMBus: Intel Corporation 82801G (ICH7 Family) SMBus Controller (rev 02)
05:00.0 Network controller: Broadcom Corporation BCM4311 802.11b/g WLAN (rev 01)
06:01.0 Ethernet controller: Broadcom Corporation BCM4401-B0 100Base-TX (rev 02)
06:04.0 CardBus bridge: ENE Technology Inc CB-712/4 Cardbus Controller (rev 10)
06:04.1 FLASH memory: ENE Technology Inc ENE PCI Memory Stick Card Reader Controller (rev 01)
06:04.2 SD Host controller: ENE Technology Inc ENE PCI Secure Digital Card Reader Controller (rev 01)
06:04.3 FLASH memory: ENE Technology Inc FLASH memory: ENE Technology Inc: (rev 01)
06:04.4 FLASH memory: ENE Technology Inc SD/MMC Card Reader Controller (rev 01)
lspci sier bare noe om hva slags hardware som sitter i maskinen, uavhengig av hva som er installert (eller i bruk) av drivere.
For å se om du har 3d-akselerasjon kan du kjøre "glxinfo | grep direct". Sjekk også etter noe ala følgende i /etc/X11/xorg.conf
Section "Device"
 Driver	   "intel"
EndSection
Glxinfo | grep direct:
aleksander@Aleksander-Ubuntu:~$ glxinfo | grep direct
direct rendering: Yes
Glxinfo:
name of display: :0.0
display: :0 screen: 0
server glx vendor string: SGI
server glx version string: 1.2
server glx extensions:
GLX_ARB_multisample, GLX_EXT_import_context, GLX_EXT_texture_from_pixmap,
GLX_EXT_visual_info, GLX_EXT_visual_rating, GLX_MESA_copy_sub_buffer,
GLX_OML_swap_method, GLX_SGI_swap_control, GLX_SGIS_multisample,
GLX_SGIX_fbconfig, GLX_SGIX_visual_select_group
client glx vendor string: SGI
client glx version string: 1.4
client glx extensions:
GLX_ARB_get_proc_address, GLX_ARB_multisample, GLX_EXT_import_context,
GLX_EXT_visual_info, GLX_EXT_visual_rating, GLX_MESA_allocate_memory,
GLX_MESA_copy_sub_buffer, GLX_MESA_swap_control,
GLX_MESA_swap_frame_usage, GLX_OML_swap_method, GLX_OML_sync_control,
GLX_SGI_make_current_read, GLX_SGI_swap_control, GLX_SGI_video_sync,
GLX_SGIS_multisample, GLX_SGIX_fbconfig, GLX_SGIX_pbuffer,
GLX_SGIX_visual_select_group, GLX_EXT_texture_from_pixmap
GLX version: 1.2
GLX extensions:
GLX_EXT_visual_info, GLX_EXT_visual_rating, GLX_MESA_swap_control,
GLX_MESA_swap_frame_usage, GLX_OML_swap_method, GLX_SGI_swap_control,
GLX_SGI_video_sync, GLX_SGIS_multisample, GLX_SGIX_fbconfig,
OpenGL vendor string: Tungsten Graphics, Inc
OpenGL renderer string: Mesa DRI Intel® 945GM 20061102 x86/MMX/SSE2
OpenGL version string: 1.4 Mesa 7.2
OpenGL extensions:
GL_ARB_depth_texture, GL_ARB_fragment_program, GL_ARB_multisample,
GL_ARB_multitexture, GL_ARB_point_parameters, GL_ARB_shadow,
GL_ARB_texture_border_clamp, GL_ARB_texture_compression,
GL_ARB_texture_cube_map, GL_ARB_texture_env_add,
GL_ARB_texture_env_combine, GL_ARB_texture_env_crossbar,
GL_ARB_texture_env_dot3, GL_ARB_texture_mirrored_repeat,
GL_ARB_texture_non_power_of_two, GL_ARB_texture_rectangle,
GL_ARB_transpose_matrix, GL_ARB_vertex_buffer_object,
GL_ARB_vertex_program, GL_ARB_window_pos, GL_EXT_abgr, GL_EXT_bgra,
GL_EXT_blend_color, GL_EXT_blend_equation_separate,
GL_EXT_blend_func_separate, GL_EXT_blend_logic_op, GL_EXT_blend_minmax,
GL_EXT_blend_subtract, GL_EXT_clip_volume_hint, GL_EXT_cull_vertex,
GL_EXT_compiled_vertex_array, GL_EXT_copy_texture,
GL_EXT_draw_range_elements, GL_EXT_fog_coord, GL_EXT_multi_draw_arrays,
GL_EXT_packed_depth_stencil, GL_EXT_packed_pixels,
GL_EXT_point_parameters, GL_EXT_polygon_offset, GL_EXT_rescale_normal,
GL_EXT_secondary_color, GL_EXT_separate_specular_color,
GL_EXT_shadow_funcs, GL_EXT_stencil_wrap, GL_EXT_subtexture,
GL_EXT_texture, GL_EXT_texture3D, GL_EXT_texture_edge_clamp,
GL_EXT_texture_env_add, GL_EXT_texture_env_combine,
GL_EXT_texture_env_dot3, GL_EXT_texture_filter_anisotropic,
GL_EXT_texture_lod_bias, GL_EXT_texture_object, GL_EXT_texture_rectangle,
GL_EXT_vertex_array, GL_3DFX_texture_compression_FXT1,
GL_APPLE_client_storage, GL_APPLE_packed_pixels,
GL_ATI_blend_equation_separate, GL_ATI_separate_stencil,
GL_IBM_rasterpos_clip, GL_IBM_texture_mirrored_repeat,
GL_INGR_blend_func_separate, GL_MESA_pack_invert, GL_MESA_ycbcr_texture,
GL_MESA_window_pos, GL_NV_blend_square, GL_NV_light_max_exponent,
GL_NV_point_sprite, GL_NV_texture_rectangle, GL_NV_texgen_reflection,
GL_NV_vertex_program, GL_NV_vertex_program1_1, GL_OES_read_format,
GL_SGIS_generate_mipmap, GL_SGIS_texture_border_clamp,
GL_SGIS_texture_edge_clamp, GL_SGIS_texture_lod, GL_SGIX_depth_texture,
GL_SUN_multi_draw_arrays
3 GLX Visuals
visual x bf lv rg d st colorbuffer ax dp st accumbuffer ms cav
id dep cl sp sz l ci b ro r g b a bf th cl r g b a ns b eat
0x21 24 tc 0 32 0 r y . 8 8 8 8 0 24 8 0 0 0 0 0 0 None
0x22 24 dc 0 32 0 r y . 8 8 8 8 0 24 8 0 0 0 0 0 0 None
0x55 32 tc 0 32 0 r . . 8 8 8 8 0 0 0 0 0 0 0 0 0 None
36 GLXFBConfigs:
0x56 0 tc 0 32 0 r . . 8 8 8 8 0 0 0 0 0 0 0 0 0 None
0x57 0 tc 0 32 0 r . . 8 8 8 8 0 0 0 16 16 16 16 0 0 Slow
0x58 0 tc 0 32 0 r y . 8 8 8 8 0 0 0 0 0 0 0 0 0 None
0x59 0 tc 0 32 0 r y . 8 8 8 8 0 0 0 16 16 16 16 0 0 Slow
0x5a 0 tc 0 32 0 r y . 8 8 8 8 0 0 0 0 0 0 0 0 0 None
0x5b 0 tc 0 32 0 r y . 8 8 8 8 0 0 0 16 16 16 16 0 0 Slow
0x5c 0 tc 0 32 0 r . . 8 8 8 8 0 24 8 0 0 0 0 0 0 None
0x5d 0 tc 0 32 0 r . . 8 8 8 8 0 24 8 16 16 16 16 0 0 Slow
0x5e 0 tc 0 32 0 r y . 8 8 8 8 0 24 8 0 0 0 0 0 0 None
0x5f 0 tc 0 32 0 r y . 8 8 8 8 0 24 8 16 16 16 16 0 0 Slow
0x60 0 tc 0 32 0 r y . 8 8 8 8 0 24 8 0 0 0 0 0 0 None
0x61 0 tc 0 32 0 r y . 8 8 8 8 0 24 8 16 16 16 16 0 0 Slow
0x62 0 tc 0 32 0 r . . 8 8 8 8 0 24 8 0 0 0 0 0 0 None
0x63 0 tc 0 32 0 r . . 8 8 8 8 0 24 8 16 16 16 16 0 0 Slow
0x64 0 tc 0 32 0 r y . 8 8 8 8 0 24 8 0 0 0 0 0 0 None
0x65 0 tc 0 32 0 r y . 8 8 8 8 0 24 8 16 16 16 16 0 0 Slow
0x66 0 tc 0 32 0 r y . 8 8 8 8 0 24 8 0 0 0 0 0 0 None
0x67 0 tc 0 32 0 r y . 8 8 8 8 0 24 8 16 16 16 16 0 0 Slow
0x68 0 dc 0 32 0 r . . 8 8 8 8 0 0 0 0 0 0 0 0 0 None
0x69 0 dc 0 32 0 r . . 8 8 8 8 0 0 0 16 16 16 16 0 0 Slow
0x6a 0 dc 0 32 0 r y . 8 8 8 8 0 0 0 0 0 0 0 0 0 None
0x6b 0 dc 0 32 0 r y . 8 8 8 8 0 0 0 16 16 16 16 0 0 Slow
0x6c 0 dc 0 32 0 r y . 8 8 8 8 0 0 0 0 0 0 0 0 0 None
0x6d 0 dc 0 32 0 r y . 8 8 8 8 0 0 0 16 16 16 16 0 0 Slow
0x6e 0 dc 0 32 0 r . . 8 8 8 8 0 24 8 0 0 0 0 0 0 None
0x6f 0 dc 0 32 0 r . . 8 8 8 8 0 24 8 16 16 16 16 0 0 Slow
0x70 0 dc 0 32 0 r y . 8 8 8 8 0 24 8 0 0 0 0 0 0 None
0x71 0 dc 0 32 0 r y . 8 8 8 8 0 24 8 16 16 16 16 0 0 Slow
0x72 0 dc 0 32 0 r y . 8 8 8 8 0 24 8 0 0 0 0 0 0 None
0x73 0 dc 0 32 0 r y . 8 8 8 8 0 24 8 16 16 16 16 0 0 Slow
0x74 0 dc 0 32 0 r . . 8 8 8 8 0 24 8 0 0 0 0 0 0 None
0x75 0 dc 0 32 0 r . . 8 8 8 8 0 24 8 16 16 16 16 0 0 Slow
0x76 0 dc 0 32 0 r y . 8 8 8 8 0 24 8 0 0 0 0 0 0 None
0x77 0 dc 0 32 0 r y . 8 8 8 8 0 24 8 16 16 16 16 0 0 Slow
0x78 0 dc 0 32 0 r y . 8 8 8 8 0 24 8 0 0 0 0 0 0 None
0x79 0 dc 0 32 0 r y . 8 8 8 8 0 24 8 16 16 16 16 0 0 Slow
Jeg har også sjekket xorg, men det som er så rart er at jeg har lest at det skal stå Intel der, men det gjør det ikke:
Section "Device"
Identifier "Configured Video Device"
EndSection
Xorg er i det siste blitt ganske flink til å finne ut av hvilke drivere som skal brukes selv, og siden direct rendering er på plass ser det ut til at det er tilfelle her også, så problemet ligger nok et annet sted. Det er dog mulig at det er relatert til Xorg likevel, så det hadde kanskje vært greit med en titt på loggen: "cat /var/log/Xorg.0.log"
Aha..
X.Org X Server 1.5.2
Release Date: 10 October 2008
X Protocol Version 11, Revision 0
Build Operating System: Linux 2.6.24-19-server i686 Ubuntu
Current Operating System: Linux Aleksander-Ubuntu 2.6.27-7-generic #1 SMP Tue Nov 4 19:33:20 UTC 2008 i686
Build Date: 24 October 2008 08:00:16AM
xorg-server 2:1.5.2-2ubuntu3 ([email protected])
Before reporting problems, check http://wiki.x.org
to make sure that you have the latest version.
Module Loader present
Markers: (--) probed, (**) from config file, (==) default setting,
(++) from command line, (!!) notice, (II) informational,
(WW) warning, (EE) error, (NI) not implemented, (??) unknown.
(==) Log file: "/var/log/Xorg.0.log", Time: Thu Nov 20 22:03:32 2008
(==) Using config file: "/etc/X11/xorg.conf"
(==) No Layout section. Using the first Screen section.
(**) |-->Screen "Default Screen" (0)
(**) | |-->Monitor "Configured Monitor"
(**) | |-->Device "Configured Video Device"
(==) Automatically adding devices
(==) Automatically enabling devices
(==) No FontPath specified. Using compiled-in default.
(WW) The directory "/usr/share/fonts/X11/cyrillic" does not exist.
Entry deleted from font path.
(==) FontPath set to:
/usr/share/fonts/X11/misc,
/usr/share/fonts/X11/100dpi/:unscaled,
/usr/share/fonts/X11/75dpi/:unscaled,
/usr/share/fonts/X11/Type1,
/usr/share/fonts/X11/100dpi,
/usr/share/fonts/X11/75dpi,
/var/lib/defoma/x-ttcidfont-conf.d/dirs/TrueType
(==) ModulePath set to "/usr/lib/xorg/modules"
(II) Cannot locate a core pointer device.
(II) Cannot locate a core keyboard device.
(II) The server relies on HAL to provide the list of input devices.
If no devices become available, reconfigure HAL or disable AllowEmptyInput.
(II) Open ACPI successful (/var/run/acpid.socket)
(II) Loader magic: 0x81d9a40
(II) Module ABI versions:
X.Org ANSI C Emulation: 0.4
X.Org Video Driver: 4.1
X.Org XInput driver : 2.1
X.Org Server Extension : 1.1
X.Org Font Renderer : 0.6
(II) Loader running on linux
(++) using VT number 7
(--) PCI:*(0@0:2:0) Intel Corporation Mobile 945GM/GMS, 943/940GML Express Integrated Graphics Controller rev 3, Mem @ 0xd0200000/0, 0xc0000000/0, 0xd0300000/0, I/O @ 0x00005088/0
(--) PCI: (0@0:2:1) Intel Corporation Mobile 945GM/GMS/GME, 943/940GML Express Integrated Graphics Controller rev 3, Mem @ 0xd0280000/0
(II) System resource ranges:
[0] -1 0 0xffffffff - 0xffffffff (0x1) MX
[1] -1 0 0x000f0000 - 0x000fffff (0x10000) MX
[2] -1 0 0x000c0000 - 0x000effff (0x30000) MX
[3] -1 0 0x00000000 - 0x0009ffff (0xa0000) MX
[4] -1 0 0x0000ffff - 0x0000ffff (0x1) IX
[5] -1 0 0x00000000 - 0x00000000 (0x1) IX
(II) LoadModule: "extmod"
(II) Loading /usr/lib/xorg/modules/extensions//libextmod.so
(II) Module extmod: vendor="X.Org Foundation"
compiled for 1.5.2, module version = 1.0.0
Module class: X.Org Server Extension
ABI class: X.Org Server Extension, version 1.1
(II) Loading extension SHAPE
(II) Loading extension MIT-SUNDRY-NONSTANDARD
(II) Loading extension BIG-REQUESTS
(II) Loading extension SYNC
(II) Loading extension MIT-SCREEN-SAVER
(II) Loading extension XC-MISC
(II) Loading extension XFree86-VidModeExtension
(II) Loading extension XFree86-Misc
(II) Loading extension XFree86-DGA
(II) Loading extension DPMS
(II) Loading extension TOG-CUP
(II) Loading extension Extended-Visual-Information
(II) Loading extension XVideo
(II) Loading extension XVideo-MotionCompensation
(II) Loading extension X-Resource
(II) LoadModule: "dbe"
(II) Loading /usr/lib/xorg/modules/extensions//libdbe.so
(II) Module dbe: vendor="X.Org Foundation"
(II) Loading extension DOUBLE-BUFFER
(II) LoadModule: "glx"
(II) Loading /usr/lib/xorg/modules/extensions//libglx.so
(II) Module glx: vendor="X.Org Foundation"
(==) AIGLX enabled
(==) Exporting typical set of GLX visuals
(II) Loading extension GLX
(II) LoadModule: "freetype"
(II) Loading /usr/lib/xorg/modules//fonts/libfreetype.so
(II) Module freetype: vendor="X.Org Foundation & the After X-TT Project"
compiled for 1.5.2, module version = 2.1.0
Module class: X.Org Font Renderer
ABI class: X.Org Font Renderer, version 0.6
(II) Loading font FreeType
(II) LoadModule: "record"
(II) Loading /usr/lib/xorg/modules/extensions//librecord.so
(II) Module record: vendor="X.Org Foundation"
compiled for 1.5.2, module version = 1.13.0
(II) Loading extension RECORD
(II) LoadModule: "dri"
(II) Loading /usr/lib/xorg/modules/extensions//libdri.so
(II) Module dri: vendor="X.Org Foundation"
(II) Loading extension XFree86-DRI
(II) Scanning /usr/share/xserver-xorg/pci directory for additional PCI ID's supported by the drivers
(II) Matched intel from file name intel.ids
(==) Matched intel for the autoconfigured driver
(==) Assigned the driver to the xf86ConfigLayout
(II) LoadModule: "intel"
(II) Loading /usr/lib/xorg/modules/drivers//intel_drv.so
(II) Module intel: vendor="X.Org Foundation"
compiled for 1.5.2, module version = 2.4.1
Module class: X.Org Video Driver
ABI class: X.Org Video Driver, version 4.1
(II) intel: Driver for Intel Integrated Graphics Chipsets: i810,
i810-dc100, i810e, i815, i830M, 845G, 852GM/855GM, 865G, 915G,
E7221 (i915), 915GM, 945G, 945GM, 945GME, 965G, G35, 965Q, 946GZ,
965GM, 965GME/GLE, G33, Q35, Q33,
Mobile Intel® GM45 Express Chipset,
Intel Integrated Graphics Device, G45/G43, Q45/Q43
(II) Primary Device is: PCI 00@00:02:0
(II) resource ranges after xf86ClaimFixedResources() call:
(II) resource ranges after probing:
[4] 0 0 0x000a0000 - 0x000affff (0x10000) MS
[5] 0 0 0x000b0000 - 0x000b7fff (0x8000) MS
[6] 0 0 0x000b8000 - 0x000bffff (0x8000) MS
[7] -1 0 0x0000ffff - 0x0000ffff (0x1) IX
[8] -1 0 0x00000000 - 0x00000000 (0x1) IX
[9] 0 0 0x000003b0 - 0x000003bb (0xc) IS
[10] 0 0 0x000003c0 - 0x000003df (0x20) IS
(II) Loading sub module "int10"
(II) LoadModule: "int10"
(II) Loading /usr/lib/xorg/modules//libint10.so
(II) Module int10: vendor="X.Org Foundation"
(II) Loading sub module "vbe"
(II) LoadModule: "vbe"
(II) Loading /usr/lib/xorg/modules//libvbe.so
(II) Module vbe: vendor="X.Org Foundation"
compiled for 1.5.2, module version = 1.1.0
(II) Loading sub module "vgahw"
(II) LoadModule: "vgahw"
(II) Loading /usr/lib/xorg/modules//libvgahw.so
(II) Module vgahw: vendor="X.Org Foundation"
compiled for 1.5.2, module version = 0.1.0
(II) intel(0): Creating default Display subsection in Screen section
"Default Screen" for depth/fbbpp 24/32
(==) intel(0): Depth 24, (==) framebuffer bpp 32
(==) intel(0): RGB weight 888
(==) intel(0): Default visual is TrueColor
(II) intel(0): Integrated Graphics Chipset: Intel® 945GM
(--) intel(0): Chipset: "945GM"
(--) intel(0): Linear framebuffer at 0xC0000000
(--) intel(0): IO registers at addr 0xD0200000
(II) intel(0): 2 display pipes available.
(==) intel(0): Using EXA for acceleration
(II) Reloading /usr/lib/xorg/modules//libint10.so
(II) intel(0): initializing int10
(WW) intel(0): Bad V_BIOS checksum
(II) intel(0): Primary V_BIOS segment is: 0xc000
(II) intel(0): VESA BIOS detected
(II) intel(0): VESA VBE Version 3.0
(II) intel(0): VESA VBE Total Mem: 7872 kB
(II) intel(0): VESA VBE OEM: Intel® 82945GM Chipset Family Graphics Chip Accelerated VGA BIOS
(II) intel(0): VESA VBE OEM Software Rev: 1.0
(II) intel(0): VESA VBE OEM Vendor: Intel Corporation
(II) intel(0): VESA VBE OEM Product: Intel® 82945GM Chipset Family Graphics Controller
(II) intel(0): VESA VBE OEM Product Rev: Hardware Version 0.0
(II) Loading sub module "ddc"
(II) LoadModule: "ddc"
(II) Module "ddc" already built-in
(II) Loading sub module "i2c"
(II) LoadModule: "i2c"
(II) Module "i2c" already built-in
(II) intel(0): Output VGA using monitor section Configured Monitor
(II) intel(0): I2C bus "CRTDDC_A" initialized.
(II) intel(0): Output LVDS has no monitor section
(II) intel(0): I2C bus "LVDSDDC_C" initialized.
(II) intel(0): Attempting to determine panel fixed mode.
(II) intel(0): I2C device "LVDSDDC_C:ddc2" registered at address 0xA0.
(II) intel(0): EDID vendor "LPL", prod id 51712
(II) intel(0): Output TV has no monitor section
(II) intel(0): Output VGA disconnected
(II) intel(0): Output LVDS connected
(II) intel(0): Output TV disconnected
(II) intel(0): Using exact sizes for initial modes
(II) intel(0): Output LVDS using initial mode 1280x800
(II) intel(0): Monitoring connected displays enabled
(II) intel(0): detected 256 kB GTT.
(II) intel(0): detected 7932 kB stolen memory.
(==) intel(0): video overlay key set to 0x101fe
(==) intel(0): Will not try to enable page flipping
(==) intel(0): Triple buffering disabled
(==) intel(0): Intel XvMC decoder disabled
(==) intel(0): Using gamma correction (1.0, 1.0, 1.0)
(==) intel(0): DPI set to (96, 96)
(II) Loading sub module "fb"
(II) LoadModule: "fb"
(II) Loading /usr/lib/xorg/modules//libfb.so
(II) Module fb: vendor="X.Org Foundation"
ABI class: X.Org ANSI C Emulation, version 0.4
(II) Loading sub module "exa"
(II) LoadModule: "exa"
(II) Loading /usr/lib/xorg/modules//libexa.so
(II) Module exa: vendor="X.Org Foundation"
compiled for 1.5.2, module version = 2.4.0
(II) Loading sub module "ramdac"
(II) LoadModule: "ramdac"
(II) Module "ramdac" already built-in
(II) intel(0): Comparing regs from server start up to After PreInit
(WW) intel(0): Register 0x61200 (PP_STATUS) changed from 0xc0000008 to 0xd000000a
(WW) intel(0): PP_STATUS before: on, ready, sequencing idle
(WW) intel(0): PP_STATUS after: on, ready, sequencing on
(WW) intel(0): Register 0x70024 (PIPEASTAT) changed from 0x80000203 to 0x00000000
(WW) intel(0): PIPEASTAT before: status: FIFO_UNDERRUN VSYNC_INT_STATUS VBLANK_INT_STATUS OREG_UPDATE_STATUS
(WW) intel(0): PIPEASTAT after: status:
(WW) intel(0): Register 0x68000 (TV_CTL) changed from 0x10000000 to 0x000c0000
(WW) intel(0): Register 0x68010 (TV_CSC_Y) changed from 0x00000000 to 0x0332012d
(WW) intel(0): Register 0x68014 (TV_CSC_Y2) changed from 0x00000000 to 0x07d30104
(WW) intel(0): Register 0x68018 (TV_CSC_U) changed from 0x00000000 to 0x0733052d
(WW) intel(0): Register 0x6801c (TV_CSC_U2) changed from 0x00000000 to 0x05c70200
(WW) intel(0): Register 0x68020 (TV_CSC_V) changed from 0x00000000 to 0x0340030c
(WW) intel(0): Register 0x68024 (TV_CSC_V2) changed from 0x00000000 to 0x06d00200
(WW) intel(0): Register 0x68028 (TV_CLR_KNOBS) changed from 0x00000000 to 0x00606000
(WW) intel(0): Register 0x6802c (TV_CLR_LEVEL) changed from 0x00000000 to 0x010b00e1
(WW) intel(0): Register 0x68030 (TV_H_CTL_1) changed from 0x00000000 to 0x00400359
(WW) intel(0): Register 0x68034 (TV_H_CTL_2) changed from 0x00000000 to 0x80480022
(WW) intel(0): Register 0x68038 (TV_H_CTL_3) changed from 0x00000000 to 0x007c0344
(WW) intel(0): Register 0x6803c (TV_V_CTL_1) changed from 0x00000000 to 0x00f01415
(WW) intel(0): Register 0x68040 (TV_V_CTL_2) changed from 0x00000000 to 0x00060607
(WW) intel(0): Register 0x68044 (TV_V_CTL_3) changed from 0x00000000 to 0x80120001
(WW) intel(0): Register 0x68048 (TV_V_CTL_4) changed from 0x00000000 to 0x000900f0
(WW) intel(0): Register 0x6804c (TV_V_CTL_5) changed from 0x00000000 to 0x000a00f0
(WW) intel(0): Register 0x68050 (TV_V_CTL_6) changed from 0x00000000 to 0x000900f0
(WW) intel(0): Register 0x68054 (TV_V_CTL_7) changed from 0x00000000 to 0x000a00f0
(WW) intel(0): Register 0x68060 (TV_SC_CTL_1) changed from 0x00000000 to 0xc1710088
(WW) intel(0): Register 0x68064 (TV_SC_CTL_2) changed from 0x00000000 to 0x4e2d1dc8
(WW) intel(0): Register 0x68070 (TV_WIN_POS) changed from 0x00000000 to 0x00360024
(WW) intel(0): Register 0x68074 (TV_WIN_SIZE) changed from 0x00000000 to 0x02640198
(WW) intel(0): Register 0x68080 (TV_FILTER_CTL_1) changed from 0x00000000 to 0x800010bb
(WW) intel(0): Register 0x68084 (TV_FILTER_CTL_2) changed from 0x00000000 to 0x00028283
(WW) intel(0): Register 0x68088 (TV_FILTER_CTL_3) changed from 0x00000000 to 0x00014141
(WW) intel(0): Register 0x68100 (TV_H_LUMA_0) changed from 0x00000000 to 0xb1403000
(WW) intel(0): Register 0x681ec (TV_H_LUMA_59) changed from 0x00000000 to 0x0000b060
(WW) intel(0): Register 0x68200 (TV_H_CHROMA_0) changed from 0x00000000 to 0xb1403000
(WW) intel(0): Register 0x682ec (TV_H_CHROMA_59) changed from 0x00000000 to 0x0000b060
(==) Depth 24 pixmap format is 32 bpp
(II) do I need RAC? No, I don't.
(II) resource ranges after preInit:
[4] 0 0 0x000a0000 - 0x000affff (0x10000) MS(OprD)
[5] 0 0 0x000b0000 - 0x000b7fff (0x8000) MS(OprD)
[6] 0 0 0x000b8000 - 0x000bffff (0x8000) MS(OprD)
[9] 0 0 0x000003b0 - 0x000003bb (0xc) IS(OprU)
[10] 0 0 0x000003c0 - 0x000003df (0x20) IS(OprU)
(II) intel(0): Kernel reported 488960 total, 1 used
(II) intel(0): I830CheckAvailableMemory: 1955836 kB available
drmOpenDevice: node name is /dev/dri/card0
drmOpenDevice: open result is -1, (No such device or address)
drmOpenDevice: Open failed
drmOpenByBusid: Searching for BusID pci:0000:00:02.0
drmOpenDevice: open result is 11, (OK)
drmOpenByBusid: drmOpenMinor returns 11
drmOpenByBusid: drmGetBusid reports pci:0000:00:02.0
(II) [drm] loaded kernel module for "i915" driver.
(II) [drm] DRM interface version 1.3
(II) [drm] DRM open master succeeded.
(II) intel(0): [drm] Using the DRM lock SAREA also for drawables.
(II) intel(0): [drm] framebuffer mapped by ddx driver
(II) intel(0): [drm] added 1 reserved context for kernel
(II) intel(0): X context handle = 0x1
(II) intel(0): [drm] installed DRM signal handler
(**) intel(0): Framebuffer compression enabled
(**) intel(0): Tiling enabled
(==) intel(0): VideoRam: 262144 KB
(II) intel(0): Attempting memory allocation with tiled buffers.
(II) intel(0): Tiled allocation successful.
(II) intel(0): [drm] Registers = 0xd0200000
(II) intel(0): [drm] ring buffer = 0xc0000000
(II) intel(0): [drm] mapped front buffer at 0xc1000000, handle = 0xc1000000
(II) intel(0): [drm] mapped back buffer at 0xc4000000, handle = 0xc4000000
(II) intel(0): [drm] mapped depth buffer at 0xc5000000, handle = 0xc5000000
(II) intel(0): [drm] mapped classic textures at 0xc6000000, handle = 0xc6000000
(II) intel(0): [drm] Initialized kernel agp heap manager, 33554432
(II) intel(0): [dri] visual configs initialized
(II) intel(0): Page Flipping disabled
(II) intel(0): vgaHWGetIOBase: hwp->IOBase is 0x03d0, hwp->PIOOffset is 0x0000
(II) EXA(0): Offscreen pixmap area of 31457280 bytes
(II) EXA(0): Driver registered support for the following operations:
(II) Solid
(II) Copy
(II) Composite (RENDER acceleration)
(==) intel(0): Backing store disabled
(==) intel(0): Silken mouse enabled
(II) intel(0): Initializing HW Cursor
(II) intel(0): [DRI] installation complete
(II) intel(0): xf86BindGARTMemory: bind key 0 at 0x01000000 (pgoffset 4096)
(II) intel(0): xf86BindGARTMemory: bind key 1 at 0x02000000 (pgoffset 8192)
(II) intel(0): xf86BindGARTMemory: bind key 2 at 0x04000000 (pgoffset 16384)
(II) intel(0): xf86BindGARTMemory: bind key 3 at 0x05000000 (pgoffset 20480)
(II) intel(0): xf86BindGARTMemory: bind key 4 at 0x06000000 (pgoffset 24576)
(II) intel(0): Fixed memory allocation layout:
(II) intel(0): 0x00000000-0x0001ffff: ring buffer (128 kB)
(II) intel(0): 0x00020000-0x0061ffff: compressed frame buffer (6144 kB, 0x000000007f820000 physical
(II) intel(0): 0x00620000-0x00620fff: compressed ll buffer (4 kB, 0x000000007fe20000 physical
(II) intel(0): 0x00621000-0x0062afff: HW cursors (40 kB, 0x000000007fe21000 physical
(II) intel(0): 0x0062b000-0x00632fff: logical 3D context (32 kB)
(II) intel(0): 0x00633000-0x00633fff: overlay registers (4 kB, 0x000000007fe33000 physical
(II) intel(0): 0x007bf000: end of stolen memory
(II) intel(0): 0x01000000-0x01ffffff: front buffer (10240 kB) X tiled
(II) intel(0): 0x02000000-0x03dfffff: exa offscreen (30720 kB)
(II) intel(0): 0x04000000-0x04ffffff: back buffer (10240 kB) X tiled
(II) intel(0): 0x05000000-0x05ffffff: depth buffer (10240 kB) X tiled
(II) intel(0): 0x06000000-0x07ffffff: classic textures (32768 kB)
(II) intel(0): 0x10000000: end of aperture
(II) intel(0): Selecting standard 18 bit TMDS pixel format.
(II) intel(0): Output configuration:
(II) intel(0): Pipe A is off
(II) intel(0): Display plane A is now disabled and connected to pipe A.
(II) intel(0): Pipe B is on
(II) intel(0): Display plane B is now enabled and connected to pipe B.
(II) intel(0): Output VGA is connected to pipe none
(II) intel(0): Output LVDS is connected to pipe B
(II) intel(0): Output TV is connected to pipe none
(II) intel(0): [drm] dma control initialized, using IRQ 16
(II) intel(0): RandR 1.2 enabled, ignore the following RandR disabled message.
(II) intel(0): DPMS enabled
(II) intel(0): Set up textured video
(II) intel(0): Set up overlay video
(II) intel(0): direct rendering: Enabled
(--) RandR disabled
(II) Initializing built-in extension MIT-SHM
(II) Initializing built-in extension XInputExtension
(II) Initializing built-in extension XTEST
(II) Initializing built-in extension XKEYBOARD
(II) Initializing built-in extension XC-APPGROUP
(II) Initializing built-in extension SECURITY
(II) Initializing built-in extension XINERAMA
(II) Initializing built-in extension XFIXES
(II) Initializing built-in extension RENDER
(II) Initializing built-in extension RANDR
(II) Initializing built-in extension COMPOSITE
(II) Initializing built-in extension DAMAGE
(II) Initializing built-in extension XEVIE
drmOpenDevice: open result is 12, (OK)
drmOpenByBusid: drmOpenMinor returns 12
(II) AIGLX: enabled GLX_MESA_copy_sub_buffer
(II) AIGLX: enabled GLX_SGI_swap_control and GLX_MESA_swap_control
(II) AIGLX: enabled GLX_texture_from_pixmap with driver support
(II) AIGLX: Loaded and initialized /usr/lib/dri/i915_dri.so
(II) GLX: Initialized DRI GL provider for screen 0
(II) intel(0): Setting screen physical size to 331 x 207
(II) config/hal: Adding input device Macintosh mouse button emulation
(II) LoadModule: "evdev"
(II) Loading /usr/lib/xorg/modules/input//evdev_drv.so
(II) Module evdev: vendor="X.Org Foundation"
compiled for 1.5.2, module version = 2.0.99
Module class: X.Org XInput Driver
ABI class: X.Org XInput driver, version 2.1
(**) Macintosh mouse button emulation: always reports core events
(**) Macintosh mouse button emulation: Device: "/dev/input/event0"
(II) Macintosh mouse button emulation: Found x and y relative axes
(II) Macintosh mouse button emulation: Found 3 mouse buttons
(II) Macintosh mouse button emulation: Configuring as mouse
(II) XINPUT: Adding extended input device "Macintosh mouse button emulation" (type: MOUSE)
(**) Macintosh mouse button emulation: YAxisMapping: buttons 4 and 5
(**) Macintosh mouse button emulation: EmulateWheelButton: 4, EmulateWheelInertia: 10, EmulateWheelTimeout: 200
(II) config/hal: Adding input device SynPS/2 Synaptics TouchPad
(II) LoadModule: "synaptics"
(II) Loading /usr/lib/xorg/modules/input//synaptics_drv.so
(II) Module synaptics: vendor="X.Org Foundation"
compiled for 1.5.2, module version = 0.15.2
(II) Synaptics touchpad driver version 0.15.2
(II) SynPS/2 Synaptics TouchPad: x-axis range 1472 - 5472
(II) SynPS/2 Synaptics TouchPad: y-axis range 1408 - 4448
(**) Option "Device" "/dev/input/event7"
(--) SynPS/2 Synaptics TouchPad touchpad found
(**) SynPS/2 Synaptics TouchPad: always reports core events
(II) XINPUT: Adding extended input device "SynPS/2 Synaptics TouchPad" (type: TOUCHPAD)
(II) config/hal: Adding input device AT Translated Set 2 keyboard
(**) AT Translated Set 2 keyboard: always reports core events
(**) AT Translated Set 2 keyboard: Device: "/dev/input/event1"
(II) AT Translated Set 2 keyboard: Found keys
(II) AT Translated Set 2 keyboard: Configuring as keyboard
(II) XINPUT: Adding extended input device "AT Translated Set 2 keyboard" (type: KEYBOARD)
(**) Option "xkb_rules" "evdev"
(**) AT Translated Set 2 keyboard: xkb_rules: "evdev"
(**) Option "xkb_model" "pc105"
(**) AT Translated Set 2 keyboard: xkb_model: "pc105"
(**) Option "xkb_layout" "no"
(**) AT Translated Set 2 keyboard: xkb_layout: "no"
(II) config/hal: Adding input device Logitech USB Receiver
(**) Logitech USB Receiver: always reports core events
(**) Logitech USB Receiver: Device: "/dev/input/event11"
(II) Logitech USB Receiver: Found 1 mouse buttons
(II) Logitech USB Receiver: Found keys
(II) Logitech USB Receiver: Configuring as keyboard
(II) XINPUT: Adding extended input device "Logitech USB Receiver" (type: KEYBOARD)
(**) Logitech USB Receiver: xkb_rules: "evdev"
(**) Logitech USB Receiver: xkb_model: "pc105"
(**) Logitech USB Receiver: xkb_layout: "no"
(**) Logitech USB Receiver: YAxisMapping: buttons 4 and 5
(**) Logitech USB Receiver: EmulateWheelButton: 4, EmulateWheelInertia: 10, EmulateWheelTimeout: 200
(**) Logitech USB Receiver: Device: "/dev/input/event10"
(II) Logitech USB Receiver: Found x and y relative axes
(II) Logitech USB Receiver: Found 16 mouse buttons
(II) Logitech USB Receiver: Configuring as mouse
(II) XINPUT: Adding extended input device "Logitech USB Receiver" (type: MOUSE)
(II) config/hal: Adding input device Video Bus
(**) Video Bus: always reports core events
(**) Video Bus: Device: "/dev/input/event9"
(II) Video Bus: Found keys
(II) Video Bus: Configuring as keyboard
(II) XINPUT: Adding extended input device "Video Bus" (type: KEYBOARD)
(**) Video Bus: xkb_rules: "evdev"
(**) Video Bus: xkb_model: "pc105"
(**) Video Bus: xkb_layout: "no"
(**) Video Bus: Device: "/dev/input/event8"
(II) intel(0): Printing DDC gathered Modelines:
(II) intel(0): Modeline "1280x800"x0.0 73.50 1280 1312 1352 1464 800 804 808 837 -hsync -vsync (50.2 kHz)
(EE) intel(0): underrun on pipe B!
AUDIT: Thu Nov 20 22:03:41 2008: 5345 X: client 4 rejected from local host ( uid=0 gid=0 pid=5583 )
AUDIT: Thu Nov 20 22:03:47 2008: 5345 X: client 4 rejected from local host ( uid=1000 gid=1000 pid=5643 )
AUDIT: Thu Nov 20 22:03:47 2008: 5345 X: client 4 rejected from local host ( uid=1000 gid=1000 pid=5644 )
AUDIT: Thu Nov 20 22:03:47 2008: 5345 X: client 4 rejected from local host ( uid=1000 gid=1000 pid=5645 )
