rstrr Skrevet 16. november 2008 Rapporter Del Skrevet 16. november 2008 (endret) * Trend Micro HijackThis v2.0.2 * See bottom for version history. The different sections of hijacking possibilities have been separated into the following groups. You can get more detailed information about an item by selecting it from the list of found items OR highlighting the relevant line below, and clicking 'Info on selected item'. R - Registry, StartPage/SearchPage changes R0 - Changed registry value R1 - Created registry value R2 - Created registry key R3 - Created extra registry value where only one should be F - IniFiles, autoloading entries F0 - Changed inifile value F1 - Created inifile value F2 - Changed inifile value, mapped to Registry F3 - Created inifile value, mapped to Registry N - Netscape/Mozilla StartPage/SearchPage changes N1 - Change in prefs.js of Netscape 4.x N2 - Change in prefs.js of Netscape 6 N3 - Change in prefs.js of Netscape 7 N4 - Change in prefs.js of Mozilla O - Other, several sections which represent: O1 - Hijack of auto.search.msn.com with Hosts file O2 - Enumeration of existing MSIE BHO's O3 - Enumeration of existing MSIE toolbars O4 - Enumeration of suspicious autoloading Registry entries O5 - Blocking of loading Internet Options in Control Panel O6 - Disabling of 'Internet Options' Main tab with Policies O7 - Disabling of Regedit with Policies O8 - Extra MSIE context menu items O9 - Extra 'Tools' menuitems and buttons O10 - Breaking of Internet access by New.Net or WebHancer O11 - Extra options in MSIE 'Advanced' settings tab O12 - MSIE plugins for file extensions or MIME types O13 - Hijack of default URL prefixes O14 - Changing of IERESET.INF O15 - Trusted Zone Autoadd O16 - Download Program Files item O17 - Domain hijack O18 - Enumeration of existing protocols and filters O19 - User stylesheet hijack O20 - AppInit_DLLs autorun Registry value, Winlogon Notify Registry keys O21 - ShellServiceObjectDelayLoad (SSODL) autorun Registry key O22 - SharedTaskScheduler autorun Registry key O23 - Enumeration of NT Services O24 - Enumeration of ActiveX Desktop Components Command-line parameters: * /autolog - automatically scan the system, save a logfile and open it * /ihatewhitelists - ignore all internal whitelists * /uninstall - remove all HijackThis Registry entries, backups and quit * /silentautuolog - the same as /autolog, except with no required user intervention * Version history * [v2.00.0] * AnalyzeThis added for log file statistics * Recognizes Windows Vista and IE7 * Fixed a few bugs in the O23 method * Fixed a bug in the O22 method (SharedTaskScheduler) * Did a few tweaks on the log format * Fixed and improved ADS Spy * Improved Itty Bitty Procman (processes are frozen before they are killed) * Added listing of O4 autoruns from other users * Added listing of the Policies Run items in O4 method, used by SmitFraud trojan * Added /silentautolog parameter for system admins * Added /deleteonreboot [file] parameter for system admins * Added O24 - ActiveX Desktop Components enumeration * Added Enhanced Security Confirguration (ESC) Zones to O15 Trusted Sites check [v1.99.1] * Added Winlogon Notify keys to O20 listing * Fixed crashing bug on certain Win2000 and WinXP systems at O23 listing * Fixed lots and lots of 'unexpected error' bugs * Fixed lots of inproper functioning bugs (i.e. stuff that didn't work) * Added 'Delete NT Service' function in Misc Tools section * Added ProtocolDefaults to O15 listing * Fixed MD5 hashing not working * Fixed 'ISTSVC' autorun entries with garbage data not being fixed * Fixed HijackThis uninstall entry not being updated/created on new versions * Added Uninstall Manager in Misc Tools to manage 'Add/Remove Software' list * Added option to scan the system at startup, then show results or quit if nothing found [v1.99] * Added O23 (NT Services) in light of newer trojans * Integrated ADS Spy into Misc Tools section * Added 'Action taken' to info in 'More info on this item' [v1.98] * Definitive support for Japanese/Chinese/Korean systems * Added O20 (AppInit_DLLs) in light of newer trojans * Added O21 (ShellServiceObjectDelayLoad, SSODL) in light of newer trojans * Added O22 (SharedTaskScheduler) in light of newer trojans * Backups of fixed items are now saved in separate folder * HijackThis now checks if it was started from a temp folder * Added a small process manager (Misc Tools section) [v1.96] * Lots of bugfixes and small enhancements! Among others: * Fix for Japanese IE toolbars * Fix for searchwww.com fake CLSID trick in IE toolbars and BHO's * Attributes on Hosts file will now be restored when scanning/fixing/restoring it. * Added several files to the LSP whitelist * Fixed some issues with incorrectly re-encrypting data, making R0/R1 go undetected until a restart * All sites in the Trusted Zone are now shown, with the exception of those on the nonstandard but safe domain list [v1.95] * Added a new regval to check for from Whazit hijack (Start Page_bak). * Excluded IE logo change tweak from toolbar detection (BrandBitmap and SmBrandBitmap). * New in logfile: Running processes at time of scan. * Checkmarks for running StartupList with /full and /complete in HijackThis UI. * New O19 method to check for Datanotary hijack of user stylesheet. * Google.com IP added to whitelist for Hosts file check. [v1.94] * Fixed a bug in the Check for Updates function that could cause corrupt downloads on certain systems. * Fixed a bug in enumeration of toolbars (Lop toolbars are now listed!). * Added imon.dll, drwhook.dll and wspirda.dll to LSP safelist. * Fixed a bug where DPF could not be deleted. * Fixed a stupid bug in enumeration of autostarting shortcuts. * Fixed info on Netscape 6/7 and Mozilla saying '%shitbrowser%' (oops). * Fixed bug where logfile would not auto-open on systems that don't have .log filetype registered. * Added support for backing up F0 and F1 items (d'oh!). [v1.93] * Added mclsp.dll (McAfee), WPS.DLL (Sygate Firewall), zklspr.dll (Zero Knowledge) and mxavlsp.dll (OnTrack) to LSP safelist. * Fixed a bug in LSP routine for Win95. * Made taborder nicer. * Fixed a bug in backup/restore of IE plugins. * Added UltimateSearch hijack in O17 method (I think). * Fixed a bug with detecting/removing BHO's disabled by BHODemon. * Also fixed a bug in StartupList (now version 1.52.1). [v1.92] * Fixed two stupid bugs in backup restore function. * Added DiamondCS file to LSP files safelist. * Added a few more items to the protocol safelist. * Log is now opened immediately after saving. * Removed rd.yahoo.com from NSBSD list (spammers are starting to use this, no doubt spyware authors will follow). * Updated integrated StartupList to v1.52. * In light of SpywareNuker/BPS Spyware Remover, any strings relevant to reverse-engineers are now encrypted. * Rudimentary proxy support for the Check for Updates function. [v1.91] * Added rd.yahoo.com to the Nonstandard But Safe Domains list. * Added 8 new protocols to the protocol check safelist, as well as showing the file that handles the protocol in the log (O18). * Added listing of programs/links in Startup folders (O4). * Fixed 'Check for Update' not detecting new versions. [v1.9] * Added check for Lop.com 'Domain' hijack (O17). * Bugfix in URLSearchHook (R3) fix. * Improved O1 (Hosts file) check. * Rewrote code to delete BHO's, fixing a really nasty bug with orphaned BHO keys. * Added AutoConfigURL and proxyserver checks (R1). * IE Extensions (Button/Tools menuitem) in HKEY_CURRENT_USER are now also detected. * Added check for extra protocols (O18). [v1.81] * Added 'ignore non-standard but safe domains' option. * Improved Winsock LSP hijackers detection. * Integrated StartupList updated to v1.4. [v1.8] * Fixed a few bugs. * Adds detecting of free.aol.com in Trusted Zone. * Adds checking of URLSearchHooks key, which should have only one value. * Adds listing/deleting of Download Program Files. * Integrated StartupList into the new 'Misc Tools' section of the Config screen! [v1.71] * Improves detecting of O6. * Some internal changes/improvements. [v1.7] * Adds backup function! Yay! * Added check for default URL prefix * Added check for changing of IERESET.INF * Added check for changing of Netscape/Mozilla homepage and default search engine. [v1.61] * Fixes Runtime Error when Hosts file is empty. [v1.6] * Added enumerating of MSIE plugins * Added check for extra options in 'Advanced' tab of 'Internet Options'. [v1.5] * Adds 'Uninstall & Exit' and 'Check for update online' functions. * Expands enumeration of autoloading Registry entries (now also scans for .vbs, .js, .dll, rundll32 and service) [v1.4] * Adds repairing of broken Internet access (aka Winsock or LSP fix) by New.Net/WebHancer * A few bugfixes/enhancements [v1.3] * Adds detecting of extra MSIE context menu items * Added detecting of extra 'Tools' menu items and extra buttons * Added 'Confirm deleting/ignoring items' checkbox [v1.2] * Adds 'Ignorelist' and 'Info' functions [v1.1] * Supports BHO's, some default URL changes [v1.0] * Original release A good thing to do after version updates is clear your Ignore list and re-add them, as the format of detected items sometimes changes. ComboFix.txt Endret 18. november 2008 av rstrr Lenke til kommentar
raWrz Skrevet 16. november 2008 Rapporter Del Skrevet 16. november 2008 er dette en sjekk eller hvet du at du har virus? men kan du ta en scann med Mbam: http://www.malwarebytes.org/mbam.php og gi meg en ny combofix logg? Lenke til kommentar
rstrr Skrevet 16. november 2008 Forfatter Rapporter Del Skrevet 16. november 2008 Problemet er at jeg kommer dårligt til internett. Live messenger virker ellers men kan ikke vise e-post. kommer ikke til den siden som du gav med den maskinen men kommer fex til ABCStartsiden lett. Kommer ikke heller mer til Diskusjon.no. Mestparten av siden er utilgjengelige. mvh Lenke til kommentar
raWrz Skrevet 16. november 2008 Rapporter Del Skrevet 16. november 2008 (endret) har du en annen data som du kan laste ned combofix på og legge på en minnepen? og kansje legge mbam innstalasjonen på? Endret 16. november 2008 av Submit Lenke til kommentar
rstrr Skrevet 16. november 2008 Forfatter Rapporter Del Skrevet 16. november 2008 Fikk det til hijackthis_16.11.08.txt log_Combofix_16.11.08.txt Lenke til kommentar
raWrz Skrevet 16. november 2008 Rapporter Del Skrevet 16. november 2008 fikk du kjørt mbam? Lenke til kommentar
rstrr Skrevet 16. november 2008 Forfatter Rapporter Del Skrevet 16. november 2008 (endret) fikk du kjørt mbam? Ja. den fant ingen malware. Vil du se den uansett? Adaware fant noen MRU som C:\Documents and Settings\Administrator\Siste count 3. ogen Registry key S-1-5-21-619312312-1406994346-2946018520-500\Softare\Microsoft\Int. Explorer Men ca. fredag fant jeg på delte mappene mine logger på tre dager for IE og Messenger, som jeg ikke vet hvorfor var der. Noen sjekker maskinen min? Endret 16. november 2008 av rstrr Lenke til kommentar
raWrz Skrevet 16. november 2008 Rapporter Del Skrevet 16. november 2008 hadde vært fint med mbam loggen ja Lenke til kommentar
rstrr Skrevet 16. november 2008 Forfatter Rapporter Del Skrevet 16. november 2008 Her er en som blev laget no mbam_log_2008_11_16__22_58_56_.txt Lenke til kommentar
rstrr Skrevet 18. november 2008 Forfatter Rapporter Del Skrevet 18. november 2008 (endret) Uten at ha gjort noenting virker maskinen perfekt! Takk for sympati Endret 18. november 2008 av rstrr Lenke til kommentar
r2d290 Skrevet 18. november 2008 Rapporter Del Skrevet 18. november 2008 Fint å høre Kom tilbake hvis det er no mer Lenke til kommentar
rstrr Skrevet 19. november 2008 Forfatter Rapporter Del Skrevet 19. november 2008 (endret) Lit usikker men det ser bra ut så. Ser ikke saken LØST (blå tekst)men ser ikke heller noen vei ellers heller. Blev skremt av det som skedde. mvh Edit: sender min takk til Submit og r2d290 her og kommer tilbake hvis det sker noe mer Endret 21. november 2008 av rstrr Lenke til kommentar
