Mrpain Skrevet 7. november 2008 Rapporter Del Skrevet 7. november 2008 Har kjøpt Alone in the Dark, DVD ikke Download, har instalert spillet men det vil ikke starte, trykker på Launch men ingenting skjer, ingen blinking eller noe som helst. Kjører Vista 32bit, nVidia GeForce 8600GT, 2,4x2Ghz 2GB RAM. Hva skal jeg gjøre? Lenke til kommentar
Mrpain Skrevet 9. november 2008 Forfatter Rapporter Del Skrevet 9. november 2008 Er det ingen som har samme problem eller har hatt samme problem? Lenke til kommentar
Mann_Av_Gull Skrevet 9. november 2008 Rapporter Del Skrevet 9. november 2008 (endret) Er det ingen som har samme problem eller har hatt samme problem? Fant noe på google http://www.ataricommunity.com/forums/showthread.php?t=648442 'Then I though on the first line... sound... sound... could it be my turtle beach montego dll soundcard? I tried changing from 5.1 speaker to stereo and voila! The game start! As long as you are under 48khz it seems to work! Hope that it help you all and have fun Im finaly gona try it now! yay!' Edit: En kar som skriver at han fikk det til å starte ved å legge inn SP1 til Vista 'hi im a vista user and had the same problem. everything downloaded normally and the serial number was also accepted. when i clicked on the game to run, it wouldnt open up. i tried downloading the game again, but it still wouldnt work. i even downloaded the latest drivers for my pc, still the same problem, even tried to find a solution out of a forum! i contacted atari and they asked for my pc details, so i gave it to them and didnt hear from them again! about a week later i downloaded the latest update for windows vista - service pack 1. ever since then, the game has been able to play! fancy that! my only suggestion would be to make sure everything is up to date, including drivers for sound and graphics, etc, not to mention having the minimum system requirements for the game!' Link: http://forums.atari.com.au/index.php?showt...w=&st=& Endret 9. november 2008 av OcMax Lenke til kommentar
Mrpain Skrevet 9. november 2008 Forfatter Rapporter Del Skrevet 9. november 2008 Er det ingen som har samme problem eller har hatt samme problem? Fant noe på google http://www.ataricommunity.com/forums/showthread.php?t=648442 'Then I though on the first line... sound... sound... could it be my turtle beach montego dll soundcard? I tried changing from 5.1 speaker to stereo and voila! The game start! As long as you are under 48khz it seems to work! Hope that it help you all and have fun Im finaly gona try it now! yay!' Edit: En kar som skriver at han fikk det til å starte ved å legge inn SP1 til Vista 'hi im a vista user and had the same problem. everything downloaded normally and the serial number was also accepted. when i clicked on the game to run, it wouldnt open up. i tried downloading the game again, but it still wouldnt work. i even downloaded the latest drivers for my pc, still the same problem, even tried to find a solution out of a forum! i contacted atari and they asked for my pc details, so i gave it to them and didnt hear from them again! about a week later i downloaded the latest update for windows vista - service pack 1. ever since then, the game has been able to play! fancy that! my only suggestion would be to make sure everything is up to date, including drivers for sound and graphics, etc, not to mention having the minimum system requirements for the game!' Link: http://forums.atari.com.au/index.php?showt...w=&st=& Fikk SP1 for 2 veker sia(reinstalerte PC) det kan neppe vere mitt problem da... Lenke til kommentar
