[Løst]Trenger hjelp til tyde memory.dmp fil
Har en 2003 server som vi kjører PS4.0 på. Denne har en uvane med restarte i utide. Etter disse restartene genereres det en memory.dmp fil. Denne har jeg fått åpnet med Windows Debugger. Er det noen som kan tyde akkurat hva som generer disse restartene utifra denne rapporten?
Slik jeg leser meldingen ser det ut til å være minnerelatert, og det er Word som utløser restarten...
Microsoft ® Windows Debugger Version 6.9.0003.113 X86
Copyright © Microsoft Corporation. All rights reserved.
Loading Dump File [C:\WINDOWS\MEMORY.DMP]
Kernel Summary Dump File: Only kernel address space is available
Symbol search path is: SRV*c:\symcache*http://msdl.microsoft.com/download/symbols;C:\WINDOWS\symbols
Executable search path is:
Windows Server 2003 Kernel Version 3790 MP (4 procs) Free x86 compatible
Product: Server, suite: TerminalServer
Built by: 3790.srv03_rtm.030324-2048
Kernel base = 0x804de000 PsLoadedModuleList = 0x8057b6a8
Debug session time: Thu Oct 30 07:15:00.364 2008 (GMT+1)
System Uptime: 6 days 14:25:15.135
Loading Kernel Symbols
Loading User Symbols
PEB is paged out (Peb.Ldr = 7ffdf00c). Type ".hh dbgerr001" for details
Loading unloaded module list
* Bugcheck Analysis *
Use !analyze -v to get detailed debugging information.
BugCheck 50, {bc5ea000, 0, 804e7b03, 1}
Page b81d not present in the dump file. Type ".hh dbgerr004" for details
Probably caused by : win32k.sys ( win32k!vSrcCopyS16D16Identity+56 )
Followup: MachineOwner
0: kd> !analyze -v
PAGE_FAULT_IN_NONPAGED_AREA (50)
Invalid system memory was referenced. This cannot be protected by try-except,
it must be protected by a Probe. Typically the address is just plain bad or it
is pointing at freed memory.
Arguments:
Arg1: bc5ea000, memory referenced.
Arg2: 00000000, value 0 = read operation, 1 = write operation.
Arg3: 804e7b03, If non-zero, the instruction address which referenced the bad memory
address.
Arg4: 00000001, (reserved)
Debugging Details:
READ_ADDRESS: bc5ea000 Paged session pool
FAULTING_IP:
nt!memmove+33
804e7b03 f3a5 rep movs dword ptr es:[edi],dword ptr [esi]
MM_INTERNAL_CODE: 1
DEFAULT_BUCKET_ID: DRIVER_FAULT
BUGCHECK_STR: 0x50
PROCESS_NAME: WINWORD.EXE
CURRENT_IRQL: 1
TRAP_FRAME: 966b07f0 -- (.trap 0xffffffff966b07f0)
ErrCode = 00000000
eax=bc5ea008 ebx=bc216094 ecx=00000002 edx=00000000 esi=bc5ea000 edi=bc2160ac
eip=804e7b03 esp=966b0864 ebp=966b086c iopl=0 nv up ei pl zr na pe nc
cs=0008 ss=0010 ds=0023 es=0023 fs=0030 gs=0000 efl=00010246
nt!memmove+0x33:
Resetting default scope
LAST_CONTROL_TRANSFER: from 8052f640 to 805435b9
STACK_TEXT:
966b0788 8052f640 00000050 bc5ea000 00000000 nt!KeBugCheckEx+0x19
966b07d8 804e2dfc 00000000 bc5ea000 00000000 nt!MmAccessFault+0x796
966b07d8 804e7b03 00000000 bc5ea000 00000000 nt!KiTrap0E+0xc8
966b086c bf86768b bc216094 bc5e9fe8 00000020 nt!memmove+0x33
966b0890 bf8ec8b6 00000010 966b0b74 966b0acc win32k!vSrcCopyS16D16Identity+0x56
966b0aa0 bf8a7f3b bc216028 00000000 966b0acc win32k!EngCopyBits+0x4d8
966b0be0 bf88628f 00000001 bc3571c0 00000000 win32k!GreSetDIBitsToDeviceInternal+0x919
966b0c4c bf959808 0d0507db 0d0507db 00000000 win32k!GreSetDIBitsInternal+0x107
966b0c88 bf91bb7f 260107d5 0d0507db 00000000 win32k!GreSetDIBits+0x5a
966b0cc4 bf91c0bf 00000010 00000000 966b0d30 win32k!DIBtoBMP+0xe3
966b0ce8 bf85f798 8785b080 00000228 8785b080 win32k!xxxGetDummyBitmap+0xbe
966b0d04 bf85f72e 8785b080 00000002 966b0d30 win32k!xxxGetClipboardData+0xb2
966b0d54 804dfd24 00000002 0012ed78 00000000 win32k!NtUserGetClipboardData+0x72
966b0d54 7ffe0304 00000002 0012ed78 00000000 nt!KiSystemService+0xd0
0012eda4 00000000 00000000 00000000 00000000 SharedUserData!SystemCallStub+0x4
STACK_COMMAND: kb
FOLLOWUP_IP:
bf86768b 83c40c add esp,0Ch
SYMBOL_STACK_INDEX: 4
SYMBOL_NAME: win32k!vSrcCopyS16D16Identity+56
FOLLOWUP_NAME: MachineOwner
MODULE_NAME: win32k
IMAGE_NAME: win32k.sys
DEBUG_FLR_IMAGE_TIMESTAMP: 3e801611
FAILURE_BUCKET_ID: 0x50_win32k!vSrcCopyS16D16Identity+56
  • 3 uker senere...
Nå har vi oppdatert med siste servicepacks på serveren og vi får en ny feilmelding i memorydumpen, se under. Noen som har et forslag til løsning?
Windows Server 2003 Kernel Version 3790 (Service Pack 2) MP (4 procs) Free x86 compatible
Built by: 3790.srv03_sp2_gdr.080813-1204
Kernel base = 0x80800000 PsLoadedModuleList = 0x808af9c8
Debug session time: Tue Nov 18 10:30:15.826 2008 (GMT+1)
System Uptime: 0 days 0:03:20.828
BugCheck 8E, {c0000005, f3fb2666, f3deeac0, 0}
Page d3b85 not present in the dump file. Type ".hh dbgerr004" for details
Page d3af4 not present in the dump file. Type ".hh dbgerr004" for details
*** ERROR: Module load completed but symbols could not be loaded for WDICA.SYS
Probably caused by : WDICA.SYS ( WDICA+13666 )
0: kd> !analyze -v
KERNEL_MODE_EXCEPTION_NOT_HANDLED (8e)
This is a very common bugcheck. Usually the exception address pinpoints
the driver/function that caused the problem. Always note this address
as well as the link date of the driver/image that contains this address.
Some common problems are exception code 0x80000003. This means a hard
coded breakpoint or assertion was hit, but this system was booted
/NODEBUG. This is not supposed to happen as developers should never have
hardcoded breakpoints in retail code, but ...
If this happens, make sure a debugger gets connected, and the
system is booted /DEBUG. This will let us see why this breakpoint is
happening.
Arguments:
Arg1: c0000005, The exception code that was not handled
Arg2: f3fb2666, The address that the exception occurred at
Arg3: f3deeac0, Trap Frame
Arg4: 00000000
Debugging Details:
EXCEPTION_CODE: (NTSTATUS) 0xc0000005 - The instruction at "0x%08lx" referenced memory at "0x%08lx". The memory could not be "%s".
FAULTING_IP:
WDICA+13666
f3fb2666 f3a5 rep movs dword ptr es:[edi],dword ptr [esi]
TRAP_FRAME: f3deeac0 -- (.trap 0xfffffffff3deeac0)
ErrCode = 00000000
eax=0000000d ebx=893b0958 ecx=00000003 edx=00000000 esi=00000000 edi=88fbe9e8
eip=f3fb2666 esp=f3deeb34 ebp=f3deeb50 iopl=0 nv up ei pl nz na pe nc
cs=0008 ss=0010 ds=0023 es=0023 fs=0030 gs=0000 efl=00010206
WDICA+0x13666:
BUGCHECK_STR: 0x8E
PROCESS_NAME: svchost.exe
CURRENT_IRQL: 0
LAST_CONTROL_TRANSFER: from 8085bba7 to 8087c4a0
STACK_TEXT:
f3dee68c 8085bba7 0000008e c0000005 f3fb2666 nt!KeBugCheckEx+0x1b
f3deea50 808346c4 f3deea6c 00000000 f3deeac0 nt!KiDispatchException+0x3a2
f3deeab8 80834678 f3deeb50 f3fb2666 badb0d00 nt!CommonDispatchException+0x4a
f3deeacc 80a8256d 8083e450 00000000 893b98f4 nt!KiExceptionExit+0x186
f3deead0 8083e450 00000000 893b98f4 893b0901 hal!KeReleaseQueuedSpinLock+0x2d
f3deeb50 f3fb7fd1 00000000 f3deebcc 893b98e0 nt!ExAcquireResourceExclusiveLite+0x66
WARNING: Stack unwind information not available. Following frames may be wrong.
f3deeb70 f71381c7 893a6000 f3deebcc 893bf610 WDICA+0x18fd1
f3deeb8c f71385a3 893b98e0 00000005 f3deebcc termdd!_IcaCallSd+0x35
f3deebac f7138a10 893bf608 00000005 f3deebcc termdd!_IcaCallStack+0x55
f3deebf4 f7136bcc 893bf608 8924c850 8924c8c0 termdd!IcaDeviceControlStack+0x414
f3deec24 f7136d20 8924c850 8924c8c0 8924c850 termdd!IcaDeviceControl+0x4e
f3deec3c 80840153 8a6de9f8 8924c850 8a17afb8 termdd!IcaDispatch+0x12a
f3deec50 8092b50f 8924c8c0 894f4f90 8924c850 nt!IofCallDriver+0x45
f3deec64 8092b444 8a6de9f8 8924c850 894f4f90 nt!IopSynchronousServiceTail+0x10b
f3deed00 8092b564 000007ec 00000000 00000000 nt!IopXxxControlFile+0x60f
f3deed34 80833bef 000007ec 00000000 00000000 nt!NtDeviceIoControlFile+0x2a
f3deed34 7c8285ec 000007ec 00000000 00000000 nt!KiFastCallEntry+0xfc
02e5ef88 00000000 00000000 00000000 00000000 0x7c8285ec
STACK_COMMAND: kb
FOLLOWUP_IP:
WDICA+13666
SYMBOL_STACK_INDEX: 0
SYMBOL_NAME: WDICA+13666
MODULE_NAME: WDICA
IMAGE_NAME: WDICA.SYS
DEBUG_FLR_IMAGE_TIMESTAMP: 401206d2
FAILURE_BUCKET_ID: 0x8E_WDICA+13666
  • 3 uker senere...
