Systemkræsj - Hardware / Softwarefeil ?
Buddy
Systemet mitt krasjer konstant for tiden, nekter å kjøre CC general, PowerDVD krasjer et par ganger pr film, og selv IE er ustabilt.
Slik er systemet mitt
Gigabyte 7VRXP KT1333
Amdxp2000 paemino
512 DDR ram pc2700
chiftect kabinettt, m 300 w enermax
60 GB baracudaIV
Hercules radeon 8500 le 64 mb
windows 2000 profesinal, alle oppdatering foretatt.
Dette er forsøkt
Reinstallering og formatering av hd og OS
Biosoppdateringer og
masse både kristelige og ukristlige besvergelser :-?
Når jeg kjører testprogrammet prime65 får jeg dette resultat :
FATAL ERROR: Rounding was 0.4998369217, expected less than 0.4
Hardware failure detected, consult stress.txt file.
Compare your results to other computers at http://www.mersenne.org/bench.htm
That web page also contains instructions on how your results can be included.
AMD Athlon XP 2000+
CPU speed: 1666.48 MHz
CPU features: RDTSC, CMOV, PREFETCH, MMX, SSE
L1 cache size: 64 KB
L2 cache size: 256 KB
L1 cache line size: 64 bytes
L2 cache line size: 64 bytes
L1 TLBS: 32
L2 TLBS: 256
Prime95 version 22.12, RdtscTiming=1
Best time for 256K FFT length: 34.162 ms.
Best time for 320K FFT length: 44.121 ms.
Best time for 384K FFT length: 63.504 ms.
Best time for 448K FFT length: 64.425 ms.
Best time for 512K FFT length: 70.686 ms.
Best time for 640K FFT length: 95.688 ms.
Best time for 768K FFT length: 117.456 ms.
Best time for 896K FFT length: 138.860 ms.
Best time for 1024K FFT length: 160.688 ms.
Best time for 1280K FFT length: 222.073 ms.
Best time for 1536K FFT length: 269.197 ms.
Best time for 1792K FFT length: 323.638 ms.
[Mon Mar 31 01:14:15 2003]
FATAL ERROR: Resulting sum was 5.909660958092493e+016, expected: 2.628639474840295e+016
[Mon Mar 31 14:29:39 2003]
OSV
Noen Forslag, og ikke aprisnarrer takk :-?
Buddy
"Hardware failure detected" formater så røsker du ut alt av ting og tank du har stående i pci-slotene..kun ha det mest nødvendige koblet til hovedkortet..som feks skjermkort, cd-rom etc..så prøver du deg fram, hvis det da er en hardware-feil :roll:
Utenom radeonkortet, er kun en dvdbrenner, dvdspiller, floppy og en hardiskskuff tilkoblet. :-?
Hadde ute alt av utstyr, støvsugde og skina, la in den såkalte safe 4 in 1 for via chipset iflg cc general 4.38, hjalp litt, kan nesten fullføre en trenigsøkt på geral, hrmf. Og har satt alt i bios på såkalt failsafe, somsagt det hjelper litt, men men, pussig nok har ikke ie crasja mens jeg skrev denne meldingen.
chipsettet var kt333, noen skrivefeil blir det i irritasjonen.
:x :-? :evil: , viser til tidliger forklaring, fikk skiten til å gå stabilt med å sette FSB til 100, hrmf, og cpu går da på kun 1250 mhz,
Noen Forslag til hva som er galt. kjøpte også ny versjoin av winxp, gjalp ikkje en skit.
Kan det være dårlig minne. er vel noname PC2700 DDR ??
Dette ser veldig mye ut som en minnefeil... Hvis du har flere brikker så ta ut en om gangen å se om det blir bedre. hvis ikke så lån en brikke.
Hvis du ikke har satt CL-verdien bedre enn den takler så kan dette være grunnen.
Ellers så er det ikke at den er for dårlig men at du har en defekt minnebrikke.
Morten
