For høy oppløsning i GDM
Loff1
Problemstillingen beskrevet i emnetittel har altså vedvart siden Ubuntu ble installert på maskinen. Under følger min xorg.conf.
# xorg.conf (X.Org X Window System server configuration file)
# This file was generated by dexconf, the Debian X Configuration tool, using
# values from the debconf database.
# Edit this file with caution, and see the xorg.conf manual page.
# (Type "man xorg.conf" at the shell prompt.)
# This file is automatically updated on xserver-xorg package upgrades *only*
# if it has not been modified since the last upgrade of the xserver-xorg
# package.
# If you have edited this file but would like it to be automatically updated
# again, run the following command:
# sudo dpkg-reconfigure -phigh xserver-xorg
Section "InputDevice"
Identifier "Generic Keyboard"
Driver "kbd"
Option "XkbRules" "xorg"
Option "XkbModel" "pc105"
Option "XkbLayout" "no"
EndSection
Identifier "Configured Mouse"
Driver "mouse"
Option "CorePointer"
EndSection
Identifier "Synaptics Touchpad"
Driver "synaptics"
Option "SendCoreEvents" "true"
Option "Device" "/dev/psaux"
Option "Protocol" "auto-dev"
Option "HorizEdgeScroll" "0"
EndSection
Section "Device"
Identifier "Configured Video Device"
EndSection
Section "Monitor"
Identifier "Configured Monitor"
EndSection
Section "Screen"
Identifier "Default Screen"
Monitor "Configured Monitor"
Device "Configured Video Device"
EndSection
Section "ServerLayout"
Identifier "Default Layout"
Screen "Default Screen"
InputDevice "Synaptics Touchpad"
EndSection
Nyeste Xorg er visstnok blitt mye flinkere til å kjøre uten xorg.conf og vil derfor gjøre det i en del tilfeller. Men tydeligvis fungerer det ikke bra nok, med tanke på at skjermoppløsning blir feildetektert :p
X.org har kunnet kjøre uten xorg.conf siden 7.1, faktisk veldig bra også, jeg har kjørt uten siden 7.2. X.org vil alltid starte i den høyeste oppløsning skjermen din påstår den takler.
X -configure genererer en xorg.conf slik X.org mener ting skal være, rediger så denne og erstatt med den som ligger i /etc/X11.
Endret av olear
Henger meg på her siden jeg har et problem som ligner veldig.
Hadde for høy oppløsning da jeg installerte 8.10 fra scratch. Har klart å få oppløsningen som inlogget bruker ned til riktig nivå, men GDM er fortsatt stor i kjeften.
Den oprinnelige oppløsningen var på 1400x1050, den riktige er på 1280x1024.
Orginal xorg.conf:
# package.
# Note that some configuration settings that could be done previously
# in this file, now are automatically configured by the server and settings
# here are ignored.
Section "Device"
EndSection
Section "Monitor"
EndSection
Section "Screen"
EndSection
xorg.conf fra X -configure
Identifier "X.org Configured"
Screen 0 "Screen0" 0 0
InputDevice "Mouse0" "CorePointer"
InputDevice "Keyboard0" "CoreKeyboard"
EndSection
Section "Files"
ModulePath "/usr/lib/xorg/modules"
FontPath "/usr/share/fonts/X11/misc"
FontPath "/usr/share/fonts/X11/cyrillic"
FontPath "/usr/share/fonts/X11/100dpi/:unscaled"
FontPath "/usr/share/fonts/X11/75dpi/:unscaled"
FontPath "/usr/share/fonts/X11/Type1"
FontPath "/usr/share/fonts/X11/100dpi"
FontPath "/usr/share/fonts/X11/75dpi"
FontPath "/var/lib/defoma/x-ttcidfont-conf.d/dirs/TrueType"
EndSection
Section "Module"
Load "extmod"
Load "dri"
Load "xtrap"
Load "record"
Load "dbe"
Load "glx"
EndSection
Identifier "Keyboard0"
Driver "kbd"
EndSection
Identifier "Mouse0"
Driver "mouse"
Option "Protocol" "auto"
Option "Device" "/dev/input/mice"
Option "ZAxisMapping" "4 5 6 7"
EndSection
Section "Monitor"
#DisplaySize 340 270 # mm
Identifier "Monitor0"
VendorName "HSL"
ModelName "H710"
HorizSync 30.0 - 81.0
VertRefresh 56.0 - 88.0
Option "DPMS"
EndSection
Section "Device"
### Available Driver options are:-
### Values: <i>: integer, <f>: float, <bool>: "True"/"False",
### <string>: "String", <freq>: "<f> Hz/kHz/MHz"
### [arg]: arg optional
#Option "NoAccel" # [<bool>]
#Option "SWcursor" # [<bool>]
#Option "ColorKey" # <i>
#Option "CacheLines" # <i>
#Option "Dac6Bit" # [<bool>]
#Option "DRI" # [<bool>]
#Option "NoDDC" # [<bool>]
#Option "ShowCache" # [<bool>]
#Option "XvMCSurfaces" # <i>
#Option "PageFlip" # [<bool>]
Identifier "Card0"
Driver "intel"
VendorName "Intel Corporation"
BoardName "82865G Integrated Graphics Controller"
BusID "PCI:0:2:0"
EndSection
Section "Screen"
Identifier "Screen0"
Device "Card0"
Monitor "Monitor0"
SubSection "Display"
Viewport 0 0
Depth 1
EndSubSection
Viewport 0 0
Depth 4
EndSubSection
Viewport 0 0
Depth 8
EndSubSection
Viewport 0 0
Depth 15
EndSubSection
Viewport 0 0
Depth 16
EndSubSection
Viewport 0 0
Depth 24
EndSubSection
EndSection
Erstattet xorg og rebootet, men det hjalp ikke noe,
Dette er så godt som første gang jeg har skjermproblemer på denne pc/skjermen. Vet ikke hva jeg skal gjøre nå - har fungert out-of-box før.
Endret av Kagee
Viewport 0 0
Depth 24
Modes "0000x0000" "0000x0000" "0000x0000" "0000x0000" "0000x0000"
EndSubSection
Erstatt med ønsket oppløsning(er).
