7digital, forskjell på license og DRM?
PapaDon
Kjøpte et par album fra 7Digital.com (registrerte meg for en stund siden, men så dinside.no sin sak om at man nå kan kjøpe derfra selv om man er i Norge) og stusset over en ting. Jeg kjøpte to album i DRM-fritt mp3 format, men ved nedlasting måtte jeg lisensere noen av filene (og bruke IE i stedet for opera..). Etter å ha tittet på FAQen til 7digital forstår jeg ikke helt skillet mellom DRM og lisens (license). Klipp og lim fra faq:
What is a license?
When you purchase a track, our system will issue you a personal license enabling you to play the track on up to 3 computers as well as burn the track to CD and transfer to a compatible portable music player.
Så jeg kan altså ikke bruke disse filene fritt (slik man får inntrykk av med tanke på at de er DRM-frie). Og med tanke på at jeg formaterer maskinen min en gang i året, minst, vil jeg bare ha sangene i rundt tre år før de ikke lenger vil spilles av?
Dear *****,
Sorry for the problem you have experienced.
There should not be any restrictions on MP3s. It may be because you have the option of downloading as a WMA file, which alerts the computer to attempt to licence the files.
It should not restrict your use of the files.
Thanks,
7digital Download Support
Customer Support Request History
To: 7digital Support Team
Hello,
I am wondering what the difference is between DRM and license? I have downloaded two albums from you, both in mp3 format (Jazzanova: Remixed and DJ Cam: Lost and found Compilation), but when I was to download I had to switch to internet explorer (I usually use Opera) to license the files from the Jazzanova album (I didn't have to do it with the DJ Cam album).
According to your FAQ the license restricts the file from being played on more then three computers, so what is the difference between the two, because I must say the license sounds a lot like DRM to me!? As far as I know, adding DRM or some sort of license is not possible with the MP3 format, so what's the deal?
Pleas clear this up for my so I can continue to use your shop, although if this is some form of DRM or license control of the use of the files I will not be buying anything more from you.
Regards ******
så da var den løst:)
