[LØST]Har mistet skrivebordet. (XP)
EDIT: Problemet ble løst ved å fjerne en debugger key i registeret.
Sitter og skal fikse ei maskin som har mistet skrivebordet sitt. Har kjørt antimalware og antivirus og fant da en stk trojan som ble fjernet. Har også kjørt reparasjons reinstallasjon, men det hjalp heller ikke.
Har kjørt HJT-skann, og dette er loggen:
Logfile of Trend Micro HijackThis v2.0.2
Scan saved at 20:44:36, on 20.10.2008
Platform: Windows XP SP3 (WinNT 5.01.2600)
MSIE: Internet Explorer v7.00 (7.00.6000.16735)
Boot mode: Normal
Running processes:
C:\WINDOWS\System32\smss.exe
C:\WINDOWS\system32\winlogon.exe
C:\WINDOWS\system32\services.exe
C:\WINDOWS\system32\lsass.exe
C:\WINDOWS\system32\svchost.exe
C:\Program Files\Windows Defender\MsMpEng.exe
C:\WINDOWS\System32\svchost.exe
C:\Program Files\WIDCOMM\Bluetooth Software\bin\btwdins.exe
C:\Program Files\Common Files\Logitech\Bluetooth\LBTSERV.EXE
C:\Norman\Npm\bin\ELOGSVC.EXE
C:\Norman\Npm\bin\ZANDA.EXE
C:\WINDOWS\system32\spoolsv.exe
C:\Program Files\Logitech\Easy Synchronization\servicestub.exe
C:\Program Files\Logitech\Easy Synchronization\LogitechEasySync.exe
C:\WINDOWS\system32\nvsvc32.exe
C:\WINDOWS\system32\SearchIndexer.exe
C:\Norman\Npm\bin\NJEEVES.EXE
C:\Norman\Nvc\bin\nvcoas.exe
C:\Norman\Nvc\BIN\NVCSCHED.EXE
C:\Program Files\Citrix\ICA Client\ssonsvr.exe
C:\WINDOWS\system32\userinit.exe
E:\HiJackThis.exe
R0 - HKCU\Software\Microsoft\Internet Explorer\Main,Start Page = http://www.startsiden.no/
R1 - HKLM\Software\Microsoft\Internet Explorer\Main,Default_Page_URL = http://go.microsoft.com/fwlink/?LinkId=69157
R1 - HKLM\Software\Microsoft\Internet Explorer\Main,Default_Search_URL = http://go.microsoft.com/fwlink/?LinkId=54896
R1 - HKLM\Software\Microsoft\Internet Explorer\Main,Search Page = http://go.microsoft.com/fwlink/?LinkId=54896
R0 - HKLM\Software\Microsoft\Internet Explorer\Main,Start Page = http://go.microsoft.com/fwlink/?LinkId=69157
R1 - HKCU\Software\Microsoft\Internet Connection Wizard,ShellNext = http://r.office.microsoft.com/r/rlid...1=3...p;p2=5&p3=1
O2 - BHO: Adobe PDF Reader Link Helper - {06849E9F-C8D7-4D59-B87D-784B7D6BE0B3} - C:\Program Files\Common Files\Adobe\Acrobat\ActiveX\AcroIEHelper.dll
O2 - BHO: SSVHelper Class - {761497BB-D6F0-462C-B6EB-D4DAF1D92D43} - C:\Program Files\Java\jre1.6.0\bin\ssv.dll
O2 - BHO: Google Toolbar Helper - {AA58ED58-01DD-4d91-8333-CF10577473F7} - c:\program files\google\googletoolbar1.dll
O2 - BHO: Google Toolbar Notifier BHO - {AF69DE43-7D58-4638-B6FA-CE66B5AD205D} - C:\Program Files\Google\GoogleToolbarNotifier\3.1.807.1746\swg.dll
O3 - Toolbar: &Google - {2318C2B1-4965-11d4-9B18-009027A5CD4F} - c:\program files\google\googletoolbar1.dll
O4 - HKLM\..\Run: [NvCplDaemon] RUNDLL32.EXE C:\WINDOWS\system32\NvCpl.dll,NvStartup
O4 - HKLM\..\Run: [nwiz] nwiz.exe /install
O4 - HKLM\..\Run: [NvMediaCenter] RUNDLL32.EXE C:\WINDOWS\system32\NvMcTray.dll,NvTaskbarInit
O4 - HKLM\..\Run: [skyTel] SkyTel.EXE
O4 - HKLM\..\Run: [sunJavaUpdateSched] "C:\Program Files\Java\jre1.6.0\bin\jusched.exe"
O4 - HKLM\..\Run: [Norman ZANDA] "C:\Norman\Npm\bin\ZLH.EXE" /LOAD /SPLASH
O4 - HKLM\..\Run: [Windows Defender] "C:\Program Files\Windows Defender\MSASCui.exe" -hide
O4 - HKLM\..\Run: [synchronization Manager] %SystemRoot%\system32\mobsync.exe /logon
O4 - HKLM\..\Run: [Kernel and Hardware Abstraction Layer] KHALMNPR.EXE
O4 - HKLM\..\Run: [Logitech BT Wizard] LBTWiz.exe -silent
O4 - HKLM\..\Run: [Easy Synchronization] C:\Program Files\Logitech\Easy Synchronization\LogitechEasySync.exe
O4 - HKLM\..\Run: [Adobe Reader Speed Launcher] "C:\Program Files\Adobe\Reader 8.0\Reader\Reader_sl.exe"
O4 - HKLM\..\Run: [igfxtray] C:\WINDOWS\system32\igfxtray.exe
O4 - HKLM\..\Run: [igfxhkcmd] C:\WINDOWS\system32\hkcmd.exe
O4 - HKLM\..\Run: [igfxpers] C:\WINDOWS\system32\igfxpers.exe
O4 - HKLM\..\Run: [RTHDCPL] RTHDCPL.EXE
O4 - HKLM\..\Run: [soundMan] SOUNDMAN.EXE
O4 - HKLM\..\Run: [AlcWzrd] ALCWZRD.EXE
O4 - HKLM\..\Run: [Alcmtr] ALCMTR.EXE
O4 - HKLM\..\RunOnce: [*Restore] C:\WINDOWS\system32\restore\rstrui.exe -i
O4 - HKCU\..\Run: [CTFMON.EXE] C:\WINDOWS\system32\ctfmon.exe
O4 - HKCU\..\Run: [swg] C:\Program Files\Google\GoogleToolbarNotifier\GoogleToolbarNotifier.exe
O4 - HKCU\..\Run: [Nokia.PCSync] "C:\Program Files\Nokia\Nokia PC Suite 7\PCSync2.exe" /NoDialog
O4 - HKCU\..\Run: [PC Suite Tray] "C:\Program Files\Nokia\Nokia PC Suite 7\PCSuite.exe" -onlytray
O4 - HKUS\S-1-5-18\..\Run: [CTFMON.EXE] C:\WINDOWS\system32\CTFMON.EXE (User 'SYSTEM')
O4 - HKUS\S-1-5-18\..\Run: [DWQueuedReporting] "C:\PROGRA~1\COMMON~1\MICROS~1\DW\dwtrig20.exe" -t (User 'SYSTEM')
O4 - HKUS\.DEFAULT\..\Run: [CTFMON.EXE] C:\WINDOWS\system32\CTFMON.EXE (User 'Default user')
O4 - Global Startup: AutoCAD Startup Accelerator.lnk = C:\Program Files\Common Files\Autodesk Shared\acstart17.exe
O4 - Global Startup: BTTray.lnk = ?
O4 - Global Startup: Logitech Desktop Messenger.lnk = C:\Program Files\Logitech\Desktop Messenger\8876480\Program\LogitechDesktopMessenger.exe
O4 - Global Startup: Logitech SetPoint.lnk = ?
O4 - Global Startup: PC-søk i Windows.lnk = C:\Program Files\Windows Desktop Search\WindowsSearch.exe
O8 - Extra context menu item: E&ksporter til Microsoft Excel - res://C:\PROGRA~1\MICROS~2\Office12\EXCEL.EXE/3000
O8 - Extra context menu item: Send til &Bluetooth-enhet... - C:\Program Files\WIDCOMM\Bluetooth Software\btsendto_ie_ctx.htm
O9 - Extra button: (no name) - {08B0E5C0-4FCB-11CF-AAA5-00401C608501} - C:\Program Files\Java\jre1.6.0\bin\ssv.dll
O9 - Extra 'Tools' menuitem: Sun Java Console - {08B0E5C0-4FCB-11CF-AAA5-00401C608501} - C:\Program Files\Java\jre1.6.0\bin\ssv.dll
O9 - Extra button: Research - {92780B25-18CC-41C8-B9BE-3C9C571A8263} - C:\PROGRA~1\MICROS~2\Office12\REFIEBAR.DLL
O9 - Extra button: @btrez.dll,-4015 - {CCA281CA-C863-46ef-9331-5C8D4460577F} - C:\Program Files\WIDCOMM\Bluetooth Software\btsendto_ie.htm
O9 - Extra 'Tools' menuitem: @btrez.dll,-12650 - {CCA281CA-C863-46ef-9331-5C8D4460577F} - C:\Program Files\WIDCOMM\Bluetooth Software\btsendto_ie.htm
O9 - Extra button: (no name) - {e2e2dd38-d088-4134-82b7-f2ba38496583} - C:\WINDOWS\Network Diagnostic\xpnetdiag.exe
O9 - Extra 'Tools' menuitem: @xpsp3res.dll,-20001 - {e2e2dd38-d088-4134-82b7-f2ba38496583} - C:\WINDOWS\Network Diagnostic\xpnetdiag.exe
O9 - Extra button: Messenger - {FB5F1910-F110-11d2-BB9E-00C04F795683} - C:\Program Files\Messenger\msmsgs.exe
O9 - Extra 'Tools' menuitem: Windows Messenger - {FB5F1910-F110-11d2-BB9E-00C04F795683} - C:\Program Files\Messenger\msmsgs.exe
O16 - DPF: {17492023-C23A-453E-A040-C7C580BBF700} (Windows Genuine Advantage Validation Tool) - http://go.microsoft.com/fwlink/?linkid=39204
O16 - DPF: {6E32070A-766D-4EE6-879C-DC1FA91D2FC3} (MUWebControl Class) - http://update.microsoft.com/microsof...?1171891949562
O17 - HKLM\System\CCS\Services\Tcpip\Parameters: Domain = langlo.local
O17 - HKLM\Software\..\Telephony: DomainName = langlo.local
O17 - HKLM\System\CS1\Services\Tcpip\Parameters: Domain = langlo.local
O17 - HKLM\System\CS2\Services\Tcpip\Parameters: Domain = langlo.local
O18 - Protocol: bwfile-8876480 - {9462A756-7B47-47BC-8C80-C34B9B80B32B} - C:\Program Files\Logitech\Desktop Messenger\8876480\Program\GAPlugProtocol-8876480.dll
O23 - Service: Autodesk Licensing Service - Autodesk - C:\Program Files\Common Files\Autodesk Shared\Service\AdskScSrv.exe
O23 - Service: Bluetooth Service (btwdins) - Broadcom Corporation. - C:\Program Files\WIDCOMM\Bluetooth Software\bin\btwdins.exe
O23 - Service: Norman eLogger service 6 (eLoggerSvc6) - Norman ASA - C:\Norman\Npm\bin\ELOGSVC.EXE
O23 - Service: Google Updater Service (gusvc) - Google - C:\Program Files\Google\Common\Google Updater\GoogleUpdaterService.exe
O23 - Service: InstallDriver Table Manager (IDriverT) - Macrovision Corporation - C:\Program Files\Common Files\InstallShield\Driver\1150\Intel 32\IDriverT.exe
O23 - Service: Logitech Bluetooth Service (LBTServ) - Logitech Inc. - C:\Program Files\Common Files\Logitech\Bluetooth\LBTSERV.EXE
O23 - Service: Logitech Easy Synchronization - Unknown owner - C:\Program Files\Logitech\Easy Synchronization\servicestub.exe
O23 - Service: Norman NJeeves - Norman ASA - C:\Norman\Npm\bin\NJEEVES.EXE
O23 - Service: Norman ZANDA - Norman ASA - C:\Norman\Npm\bin\ZANDA.EXE
O23 - Service: Norman Scanner Engine Service (nsesvc) - Norman ASA - C:\Norman\nse\bin\NSESVC.EXE
O23 - Service: Norman Virus Control on-access component (nvcoas) - Norman ASA - C:\Norman\Nvc\bin\nvcoas.exe
O23 - Service: Norman Virus Control Scheduler (NVCScheduler) - Norman ASA - C:\Norman\Nvc\BIN\NVCSCHED.EXE
O23 - Service: NVIDIA Display Driver Service (NVSvc) - NVIDIA Corporation - C:\WINDOWS\system32\nvsvc32.exe
O23 - Service: ServiceLayer - Nokia. - C:\Program Files\PC Connectivity Solution\ServiceLayer.exe
End of file - 8747 bytes
Jeg har ikke peiling på slike logger, men andre har sagt at det ikke er noe feil der. Når jeg forsøker å kjøre explorer.exe gjennom taskmanager, så får jeg beskjed om at fila ikke er der selv om jeg ser den i mappesystemet.
Men jeg trodde strengt tatt at en reparasjons reinstallasjon ville fikse problemer med explorer.exe.
Har også Desktop hijack fix, men det eneste den gjorde var å fjerne wallpaperet.
Endret av karakas
