MST Skrevet 22. oktober 2008 Forfatter Rapporter Del Skrevet 22. oktober 2008 Den må ikke spilles av samma profil som den lastest ned fra.. Bare logg inn på den nye acc'n jeg lader, start download og så kan den spilles på din egen PSN profil. Men jeg venter litt til for å se om jeg får inn noen tilbud fra andre forums:P... Men Mokoo har i hvertfall fått sin beta nå. Lenke til kommentar
Pesico Skrevet 22. oktober 2008 Rapporter Del Skrevet 22. oktober 2008 Oki. Den lukkede betaen var bundet til PSN id. Lenke til kommentar
MST Skrevet 22. oktober 2008 Forfatter Rapporter Del Skrevet 22. oktober 2008 (endret) En liten update:) Kilde: http://ps3.ign.com/articles/922/922057p1.html Resistance 2 Multiplayer Details Open beta news and multiplayer powers explained. by Jeff Haynes October 21, 2008 - Do you have a desire to crush Chimera under your boots? Of course you do, but you've still got a few weeks to go until Resistance 2 comes out on November 4. Fortunately, you won't have to wait that long to get a taste of the multiplayer action found within the game. This Thursday, Insomniac Games and Sony Computer Entertainment will be opening the formerly closed doors on their multiplayer beta, allowing players to leap onto maps and blast away. Here's what you'll need to do to jump into the fray: on Thursday, go to this link on MyResistance.Net and apply. Once you get in, get ready to invade the United States or defend humanity. To help you with some pointers, SCEA and Insomniac provided us with the following video on Berserks. What are Berserks, you ask? These are rewards that players gain for accomplishing their goals in competitive multiplayer matches. Initially you only have a few, but you gain multiple powers as you play more. Some of these range from being able to see heat signatures of enemies through walls to invisibility and even health regeneration for allies. If you want to excel at Resistance 2 tactics on the 60 player battlefield, you'll want to take a look here to start getting familiar with the abilities you'll be able to unleash once you join the beta. Endret 22. oktober 2008 av MST Lenke til kommentar
vicheous Skrevet 22. oktober 2008 Rapporter Del Skrevet 22. oktober 2008 (endret) Jeg har en ekstra key! Noen som vil ha?? Helt gratis! Legg til PSN: vicheous å skriv R2 Beta i meldingen så skal jeg godta å sende kode til den første som gjør det! Har bare en kode så første mann til mølla får! Edit: Da var den borte!! Den gikk til PSN: SanAndre Endret 22. oktober 2008 av vicheous Lenke til kommentar
Paisley Skrevet 22. oktober 2008 Rapporter Del Skrevet 22. oktober 2008 Den må ikke spilles av samma profil som den lastest ned fra..Bare logg inn på den nye acc'n jeg lader, start download og så kan den spilles på din egen PSN profil. Men jeg venter litt til for å se om jeg får inn noen tilbud fra andre forums:P... Men Mokoo har i hvertfall fått sin beta nå. Så jeg får ikke?? Lenke til kommentar
Mokko Skrevet 22. oktober 2008 Rapporter Del Skrevet 22. oktober 2008 Tusen takk for Beta, MST! Utrolig takknemlig, den holder på å lastes ned nå.. Er det noen som vet om jeg bare kan overføre Resistance-filen til min egentlige bruker, eller må jeg ha den brukeren som jeg logget meg på på PS3en for å spille den..? Lenke til kommentar
puffyp Skrevet 22. oktober 2008 Rapporter Del Skrevet 22. oktober 2008 Ahhh... klarer aldri skaffe beta nøkkel. Tror jeg får vente til det kommer i butikken. Lenke til kommentar
Morty87 Skrevet 22. oktober 2008 Rapporter Del Skrevet 22. oktober 2008 Ahhh... klarer aldri skaffe beta nøkkel. Tror jeg får vente til det kommer i butikken. Sjekk PM Lenke til kommentar
BadSmile Skrevet 22. oktober 2008 Rapporter Del Skrevet 22. oktober 2008 (endret) Jeg tar gjerne imot en beta nøkkel om noen har det Edit: Inlegg nr 800 å greier. Endret 22. oktober 2008 av BadSmile Lenke til kommentar
Naiits Skrevet 22. oktober 2008 Rapporter Del Skrevet 22. oktober 2008 Koffor skulle han sjekke PM? Fikk han en kode?! ;O Lenke til kommentar
MST Skrevet 22. oktober 2008 Forfatter Rapporter Del Skrevet 22. oktober 2008 Prøv denna linken: https://beta.myresistance.net/en-us/Apply/BetaForm Ifølge IGN skal de fleste som sender inn en sånn apply ting få en beta code. Lenke til kommentar
Naiits Skrevet 22. oktober 2008 Rapporter Del Skrevet 22. oktober 2008 Eg har sjekket på tusen sider etter en beta kode. Hadde blitt så evig takknemlig om noen snille sjeler der ute hadde gitt meg en Lenke til kommentar
Mokko Skrevet 22. oktober 2008 Rapporter Del Skrevet 22. oktober 2008 Flere koder her Lenke til kommentar
Delta_hf Skrevet 22. oktober 2008 Rapporter Del Skrevet 22. oktober 2008 Har noen en kode til overs som jeg kan ninjae? Typisk at jeg ikke var hjemme i går... Lenke til kommentar
Paisley Skrevet 22. oktober 2008 Rapporter Del Skrevet 22. oktober 2008 Jaja, syntes du kunne gitt meg den koden MST. Noen som har en til overs?? Lenke til kommentar
MST Skrevet 22. oktober 2008 Forfatter Rapporter Del Skrevet 22. oktober 2008 Paisley, hva er msn din? Lenke til kommentar
akristina92 Skrevet 22. oktober 2008 Rapporter Del Skrevet 22. oktober 2008 Jeg tar gjerne imot en kode om noen har en til overs. Lenke til kommentar
dudley.no Skrevet 22. oktober 2008 Rapporter Del Skrevet 22. oktober 2008 hallo har nå prøvd å regisrere meg på flere nettsider for key men ingen luck....både i dag og i går. Hvis noen har til overs så tar jeg gjerne i mot.......den som skulle være så snill og gi vil automatisk få key tilbake hvis det skulle ligge en i epost kassa mi en dag. Har også liggende 48timers LIVE koder kort som kan gis bort her til vedkommende som sender key eller han kan bestemme hva som skal gjøres med dem her Noen der ute Lenke til kommentar
eddie1 Skrevet 22. oktober 2008 Rapporter Del Skrevet 22. oktober 2008 noen som har en kode please,send pm Lenke til kommentar
Paisley Skrevet 22. oktober 2008 Rapporter Del Skrevet 22. oktober 2008 Paisley, hva er msn din? Sender deg en pm. Lenke til kommentar
