Dungeon Siege på zonematch - kan ikke joine game
Hver gang jeg prøver å joine en game på zonematch, kommer det en pop up der det står "looking for game". Etter noen sekunder, står det "no games were found on the specified adress". Merkelig.....
Takker på forhånd for all hjelp...... gleder meg til å knuse andre DS-ere... :D
Jeg er bak en firewall. Har ikke mye peiling på dette, så det må jeg få hjelp til.....
Kan dette hjelpe? (tatt fra readme-fila)
Playing Dungeon Siege Online Behind a NAT (Network Address Translation) or Firewall
If you use a broadband connection, you may encounter problems when trying to play Dungeon Siege on systems using Network Address Translation (NAT). If your system uses a NAT you will not be able to host games of Dungeon Siege. However, you will typically be able join games hosted by users whose systems do not employ a NAT.
1) You can overcome this problem by reprogramming your NAT to redirect all external network traffic to a specific host on the internal network. Be aware that you can only have a single server behind the NAT. Port forwarding circumvents many of the security features of your NAT.
2) Alternatively you can enable specific ports. Dungeon Siege uses DirectPlay 8.1, which typically uses ports 6073, 2302, and 2300.
ZoneMatch Port
• AutoUpdate, Chat, Games List, News: 80 TCP
• 2300 UDP - Primary ZoneMatch Port
Game Session Ports
• 6073 UDP - Primary: Inbound for Hosting, Outbound for Joining
• 2302-2400 UDP - Secondary: Inbound
• 2302-2400 UDP - Secondary: Outbound
Please consult your NAT documentation for specific information on port forwarding.
For more information on NAT please see the article at http://msdn.microsoft.com/library/default....orking/nats.asp.
Hva slags firewall er det du er bak?
Software eller hardware?
Hvis du kan så kan du jo bare disable firewallen mens du spiller. Ellers så må du åpne de portene det står du skal åpne i readme filen. Hvis du ikke vet hvordan du gjør det, så anbefaler jeg deg at du søker litt på google med "Ditt routernavn + Opening ports" eller noe lignende. Finner du ingenting så kan du poste her igjen
Hva slags firewall er det du har da?
Min er f. eks den som fulgte med NextGenTel adsl'en min. Det er en Cisco 667i-DIR.
Jeg søkte "Cisco 667i-DIR" på google. Der fant jeg en side som het www.relativt.net (Genial norsk side for NGT brukere) også fant jeg en faq hvor det var "Hvordan åpne porter."
Hvis du har lest i manualen hvilken adresse det skal være, og du er _sikker_ på at du ikke kommer inn på den, så er det sikkert fordi din maskin har feil ip.
Veldig mange routere vil standard bare ta i mot fra hvisse ip'er. Sjekk manualen for hvilke. Deretter bytt til den riktige ip'en. Vet du ikke hvordan du gjør det, SØK SØK SØK (i forumet)
Jeg har kommet inn på den riktige web configuratoren.
Derfra kom jeg inn på en slik port-greie.
Jeg vet hvilke porter jeg skal åpne, de står jo i readme-fila til DS.
Men det er også et vindu der for ip-adressen til serveren jeg vil åpne porten til. Denne vet jeg ikke.
Dersom jeg lot ip-feltet stå tomt skjedde det ingen forandring på zonematch. Jeg vet ikke om det skjer noe om jeg finner ip-adressen heller. Men siden det ikke står noen ip-adresse i readme-fila regner jeg med at den ikke trengs.
Hvordan skal jeg løse dette problemet?
