Tetanus Skrevet 18. oktober 2008 Del Skrevet 18. oktober 2008 (endret) Heisann! Nedenfor kan dere lese en mail jeg har sendt til support hos AMD/ATI. I og med at jeg anser sjansen for å få et normalt hjelpsomt svar derfra som minimal, håper jeg noen her inne kanskje kan komme med noe som kan løse problemet. ------------------------------------------------------------------------------------- Hi there! I am having problems with CCC I recently updated to 8.10, and when I rebooted i got an error message saying "MOM.Implementation" error. I am now using the latest driver, but I am unable to install and use CCS. Here is what I have done. 1)Unistalled all ATI drivers and files from "add/remove programs" and C: (manual delete) (rebooted) 2)Ran safe mode and ran driver cleaner. Then ran ccleaner and checked for any and all registry errors. Fixed them all. Ran registry mechanic, no errors found. 3) rebooted, and once more installed driver and CCS. Reboot. No joy, still same error. Reboot Repeated step 1 and 2. 4) Unistalled .Net framework 2. Rebooted. 5) installed .net framework 2. Rebooted. 6) Ran ccleaner registry check and registry mechanic. Then installed driver and CCC. No joy, still same error. "MOM.implemetation" error. 7) completed step 1) and 2) once more. Installed driver ONLY. No problems, but now I don't have CCC. Hardware: ASUS P5Q Pro, Intel E8500, MSI Radeon HD4870 512MB PCI-E (R4870-T2D512), 4Gb system ram, 80 Gb system HDD. Software: GENUINE WinXP Pro (ver2002) SP3 updated, all updates downloaded and installed. .Net framework 1.1 (and hotfix) and .Net framework 2 installed I don't see what else I could possibly have done in addition to the things I have already tried. Please advise on sollution! ------------------------------------------------------------------ -Tet Endret 5. november 2008 av Tetanus Lenke til kommentar
Stjernestøv Skrevet 2. november 2008 Del Skrevet 2. november 2008 (endret) Har samme problemet som deg med 8.10 Jeg har lastet ned 8.9 driver og CCC for å kunne bruke CCC Fungerer fint enn så lenge. Her må det være et problem med 8.10 CCC. Håper du får svar på dette og kan dele infoen med oss andre Burde vært postet under skjermkort btw Endret 2. november 2008 av The Metal God Lenke til kommentar
Tetanus Skrevet 4. november 2008 Forfatter Del Skrevet 4. november 2008 (endret) Fikk bare et standard svar fra ATI, var ikke særlig mye hjelp i det. Endte med at jeg ga opp, så nå har jeg ikke CCC installert. -Tet Edit:leif Endret 5. november 2008 av Tetanus Lenke til kommentar
Stjernestøv Skrevet 5. november 2008 Del Skrevet 5. november 2008 Du mener selfølgelig CCC Catalyst Control Center. Som jeg sa fungerer CCC 8.9 fint dersom du trenger det. Et helt enkelt oppsett krever jo ikke CCC, så det går sikkert greit Lenke til kommentar
