WD MyBook kommer ikke opp i fdisk eller /dev
Hei! Har en Western Digital MyBook her som jeg prøver å mounte i Arch Linux. Men jeg finner ikke harddisken. Den kommer ikke opp med:
fdisk -l:
bash-3.2# fdisk -l
Disk /dev/sda: 320.0 GB, 320072933376 bytes
255 heads, 63 sectors/track, 38913 cylinders
Units = cylinders of 16065 * 512 = 8225280 bytes
Disk identifier: 0xc464c464
  Device Boot	  Start		 End	  Blocks   Id  System
/dev/sda1   *		   1		2550	20482843+   7  HPFS/NTFS
/dev/sda2			2551	   38780   291017475   83  Linux
/dev/sda3		   38781	   38913	 1068322+  82  Linux swap / Solaris
bash-3.2#
lsusb:
bash-3.2# lsusb
Bus 008 Device 002: ID 0bda:0111 Realtek Semiconductor Corp.
Bus 008 Device 001: ID 1d6b:0002
Bus 007 Device 001: ID 1d6b:0001
Bus 006 Device 001: ID 1d6b:0001
Bus 005 Device 001: ID 1d6b:0001
Bus 004 Device 004: ID 056d:0002 EIZO Corp.
Bus 004 Device 003: ID 046d:c01b Logitech, Inc. MX310 Optical Mouse
Bus 004 Device 002: ID 0409:005a NEC Corp.
Bus 004 Device 001: ID 1d6b:0002
Bus 003 Device 001: ID 1d6b:0001
Bus 002 Device 001: ID 1d6b:0001
Bus 001 Device 001: ID 1d6b:0001
bash-3.2#
eller dmesg | tail (Disconnect er den eksterne CD-rommen, har prøvd å koble harddisken litt fra og til. )
bash-3.2# dmesg | tail
scsi 7:0:0:0: CD-ROM			HL-DT-ST DVD-RAM GSA-E60L 1.00 PQ: 0 ANSI: 0
scsi 7:0:0:0: Attached scsi generic sg5 type 5
usb-storage: device scan complete
Driver 'sr' needs updating - please use bus_type methods
sr0: scsi3-mmc drive: 48x/48x writer dvd-ram cd/rw xa/form2 cdda tray
Uniform CD-ROM driver Revision: 3.20
sr 7:0:0:0: Attached scsi CD-ROM sr0
cdrom: This disc doesn't have any tracks I recognize!
warning: `wodim' uses 32-bit capabilities (legacy support in use)
usb 8-2: USB disconnect, address 4
bash-3.2#
Broren min bruker den daglig på windows. Burde ikke riktig moduler osv bli lastet automatisk? Noen som har noen ide?
edit: lsmod | grep usb
bash-3.2# lsmod  | grep usb
usb_storage			90560  0
usbhid				 46016  0
hid					40960  1 usbhid
ff_memless			  6664  1 usbhid
usbcore			   132080  5 usb_storage,usbhid,ehci_hcd,uhci_hcd
scsi_mod			   95692  5 sr_mod,sg,usb_storage,sd_mod,libata
bash-3.2#
Endret av Blackslash
