Lage egen EDID for min lcd-tv
Hei sliter med problemet å få lyd i fra mitt lydkort til min lcd-tv i stedet fra hdmi på skjermkortet etter at jeg gikk over til nvidia.
Jeg kom over denne tråden: http://www.nvnews.net/vbulletin/showthread...dmi+linux+audio
Men sliter med å forstå hvordan jeg lager min egen EDID for lcd-tv'en, her er min xorg logg:
X.Org X Server 1.5.2
Release Date: 10 October 2008
X Protocol Version 11, Revision 0
Build Operating System: Linux 2.6.27-ARCH i686
Current Operating System: Linux Magda 2.6.27-ARCH #1 SMP PREEMPT Sun Oct 12 15:16:25 CEST 2008 i686
Build Date: 12 October 2008  02:04:57PM
Before reporting problems, check http://wiki.x.org
to make sure that you have the latest version.
Module Loader present
Markers: (--) probed, (**) from config file, (==) default setting,
(++) from command line, (!!) notice, (II) informational,
(WW) warning, (EE) error, (NI) not implemented, (??) unknown.
(==) Log file: "/var/log/Xorg.0.log", Time: Tue Oct 14 23:44:43 2008
(==) Using config file: "/etc/X11/xorg.conf"
(==) ServerLayout "Layout0"
(**) |-->Screen "Screen0" (0)
(**) |   |-->Monitor "Monitor0"
(**) |   |-->Device "Device0"
(**) |-->Input Device "Keyboard0"
(**) |-->Input Device "Mouse0"
(**) Option "Xinerama" "0"
(==) Automatically adding devices
(==) Automatically enabling devices
(==) FontPath set to:
/usr/share/fonts/misc,
/usr/share/fonts/100dpi:unscaled,
/usr/share/fonts/75dpi:unscaled,
/usr/share/fonts/TTF,
/usr/share/fonts/Type1
(==) ModulePath set to "/usr/lib/xorg/modules"
(WW) Open ACPI failed (/var/run/acpid.socket) (No such file or directory)
(II) No APM support in BIOS or kernel
(II) Loader magic: 0x81d5ea0
(II) Module ABI versions:
X.Org ANSI C Emulation: 0.4
X.Org Video Driver: 4.1
X.Org XInput driver : 2.1
X.Org Server Extension : 1.1
X.Org Font Renderer : 0.6
(II) Loader running on linux
(++) using VT number 7
(--) PCI:*(0@5:0:0) nVidia Corporation G94 [GeForce 9600 GT] rev 161, Mem @ 0xfa000000/0, 0xd0000000/0, 0xf8000000/0, I/O @ 0x00006c00/0, BIOS @ 0x????????/524288
(II) System resource ranges:
[0] -1	0	0xffffffff - 0xffffffff (0x1) MX[B]
[1] -1	0	0x000f0000 - 0x000fffff (0x10000) MX[B]
[2] -1	0	0x000c0000 - 0x000effff (0x30000) MX[B]
[3] -1	0	0x00000000 - 0x0009ffff (0xa0000) MX[B]
[4] -1	0	0xffffffff - 0xffffffff (0x1) MX[B]
[5] -1	0	0x000f0000 - 0x000fffff (0x10000) MX[B]
[6] -1	0	0x000c0000 - 0x000effff (0x30000) MX[B]
[7] -1	0	0x00000000 - 0x0009ffff (0xa0000) MX[B]
[8] -1	0	0xffffffff - 0xffffffff (0x1) MX[B]
[9] -1	0	0x000f0000 - 0x000fffff (0x10000) MX[B]
[10] -1	0	0x000c0000 - 0x000effff (0x30000) MX[B]
[11] -1	0	0x00000000 - 0x0009ffff (0xa0000) MX[B]
[12] -1	0	0xffffffff - 0xffffffff (0x1) MX[B]
[13] -1	0	0x000f0000 - 0x000fffff (0x10000) MX[B]
[14] -1	0	0x000c0000 - 0x000effff (0x30000) MX[B]
[15] -1	0	0x00000000 - 0x0009ffff (0xa0000) MX[B]
[16] -1	0	0x0000ffff - 0x0000ffff (0x1) IX[B]
[17] -1	0	0x00000000 - 0x00000000 (0x1) IX[B]
[18] -1	0	0x0000ffff - 0x0000ffff (0x1) IX[B]
[19] -1	0	0x00000000 - 0x00000000 (0x1) IX[B]
[20] -1	0	0x0000ffff - 0x0000ffff (0x1) IX[B]
[21] -1	0	0x00000000 - 0x00000000 (0x1) IX[B]
[22] -1	0	0x0000ffff - 0x0000ffff (0x1) IX[B]
[23] -1	0	0x00000000 - 0x00000000 (0x1) IX[B]
(II) "extmod" will be loaded. This was enabled by default and also specified in the config file.
(II) "dbe" will be loaded. This was enabled by default and also specified in the config file.
(II) "glx" will be loaded. This was enabled by default and also specified in the config file.
(II) "freetype" will be loaded. This was enabled by default and also specified in the config file.
(II) "dri" will be loaded by default.
(II) LoadModule: "dbe"
(II) Loading /usr/lib/xorg/modules/extensions//libdbe.so
(II) Module dbe: vendor="X.Org Foundation"
compiled for 1.5.2, module version = 1.0.0
Module class: X.Org Server Extension
ABI class: X.Org Server Extension, version 1.1
(II) Loading extension DOUBLE-BUFFER
(II) LoadModule: "extmod"
(II) Loading /usr/lib/xorg/modules/extensions//libextmod.so
(II) Module extmod: vendor="X.Org Foundation"
(II) Loading extension SHAPE
(II) Loading extension MIT-SUNDRY-NONSTANDARD
(II) Loading extension BIG-REQUESTS
(II) Loading extension SYNC
(II) Loading extension MIT-SCREEN-SAVER
(II) Loading extension XC-MISC
(II) Loading extension XFree86-VidModeExtension
(II) Loading extension XFree86-Misc
(II) Loading extension XFree86-DGA
(II) Loading extension DPMS
(II) Loading extension TOG-CUP
(II) Loading extension Extended-Visual-Information
(II) Loading extension XVideo
(II) Loading extension XVideo-MotionCompensation
(II) Loading extension X-Resource
(II) LoadModule: "type1"
(WW) Warning, couldn't open module type1
(II) UnloadModule: "type1"
(EE) Failed to load module "type1" (module does not exist, 0)
(II) LoadModule: "freetype"
(II) Loading /usr/lib/xorg/modules/fonts//libfreetype.so
(II) Module freetype: vendor="X.Org Foundation & the After X-TT Project"
compiled for 1.5.2, module version = 2.1.0
Module class: X.Org Font Renderer
ABI class: X.Org Font Renderer, version 0.6
(II) Loading font FreeType
(II) LoadModule: "glx"
(II) Loading /usr/lib/xorg/modules/extensions//libglx.so
(II) Module glx: vendor="NVIDIA Corporation"
compiled for 4.0.2, module version = 1.0.0
(II) NVIDIA GLX Module  177.80  Wed Oct  1 15:06:06 PDT 2008
(II) Loading extension GLX
(II) LoadModule: "dri"
(II) Loading /usr/lib/xorg/modules/extensions//libdri.so
(II) Module dri: vendor="X.Org Foundation"
(II) Loading extension XFree86-DRI
(II) LoadModule: "nvidia"
(II) Loading /usr/lib/xorg/modules/drivers//nvidia_drv.so
(II) Module nvidia: vendor="NVIDIA Corporation"
Module class: X.Org Video Driver
(II) LoadModule: "kbd"
(II) Loading /usr/lib/xorg/modules/input//kbd_drv.so
(II) Module kbd: vendor="X.Org Foundation"
compiled for 1.4.2, module version = 1.3.1
Module class: X.Org XInput Driver
ABI class: X.Org XInput driver, version 2.0
(II) LoadModule: "mouse"
(II) Loading /usr/lib/xorg/modules/input//mouse_drv.so
(II) Module mouse: vendor="X.Org Foundation"
compiled for 1.4.2, module version = 1.3.0
(II) NVIDIA dlloader X Driver  177.80  Wed Oct  1 14:45:01 PDT 2008
(II) NVIDIA Unified Driver for all Supported NVIDIA GPUs
(II) Primary Device is: PCI 05@00:00:0
(II) Loading sub module "fb"
(II) LoadModule: "fb"
(II) Loading /usr/lib/xorg/modules//libfb.so
(II) Module fb: vendor="X.Org Foundation"
ABI class: X.Org ANSI C Emulation, version 0.4
(II) Loading sub module "wfb"
(II) LoadModule: "wfb"
(II) Loading /usr/lib/xorg/modules//libwfb.so
(II) Module wfb: vendor="X.Org Foundation"
(II) Loading sub module "ramdac"
(II) LoadModule: "ramdac"
(II) Module "ramdac" already built-in
(II) resource ranges after probing:
(**) NVIDIA(0): Depth 24, (--) framebuffer bpp 32
(==) NVIDIA(0): RGB weight 888
(==) NVIDIA(0): Default visual is TrueColor
(==) NVIDIA(0): Using gamma correction (1.0, 1.0, 1.0)
(**) NVIDIA(0): Option "TwinView" "1"
(**) NVIDIA(0): Option "MetaModes" "DFP-0: 1680x1050_60_0 +1360+0, DFP-1: nvidia-auto-select +0+0; DFP-0: nvidia-auto-select +1360+0, DFP-1: nvidia-auto-select +0+0"
(**) NVIDIA(0): Option "UseEdidDpi" "FALSE"
(**) NVIDIA(0): Option "DPI" "96 x 96"
(**) NVIDIA(0): Enabling RENDER acceleration
(II) NVIDIA(0): Support for GLX with the Damage and Composite X extensions is
(II) NVIDIA(0):	 enabled.
(II) NVIDIA(0): NVIDIA GPU GeForce 9600 GT (G94) at PCI:5:0:0 (GPU-0)
(--) NVIDIA(0): Memory: 524288 kBytes
(--) NVIDIA(0): VideoBIOS: 62.94.11.00.00
(II) NVIDIA(0): Detected PCI Express Link width: 16X
(--) NVIDIA(0): Interlaced video modes are supported on this GPU
(--) NVIDIA(0): Connected display device(s) on GeForce 9600 GT at PCI:5:0:0:
(--) NVIDIA(0):	 CMO CMC 22 W (DFP-0)
(--) NVIDIA(0):	 LG 32LG3000 (DFP-1)
(--) NVIDIA(0): CMO CMC 22 W (DFP-0): 330.0 MHz maximum pixel clock
(--) NVIDIA(0): CMO CMC 22 W (DFP-0): Internal Dual Link TMDS
(--) NVIDIA(0): LG 32LG3000 (DFP-1): 330.0 MHz maximum pixel clock
(--) NVIDIA(0): LG 32LG3000 (DFP-1): Internal Dual Link TMDS
(**) NVIDIA(0): TwinView enabled
(II) NVIDIA(0): Display Devices found referenced in MetaMode: DFP-0, DFP-1
(WW) NVIDIA(0): The EDID for LG 32LG3000 (DFP-1) contradicts itself: mode
(WW) NVIDIA(0):	 "720x480" is specified in the EDID; however, the EDID's
(WW) NVIDIA(0):	 valid HorizSync range (28.000-67.000 kHz) would exclude
(WW) NVIDIA(0):	 this mode's HorizSync (15.7 kHz); ignoring HorizSync check
(WW) NVIDIA(0):	 for mode "720x480".
(WW) NVIDIA(0):	 "720x576" is specified in the EDID; however, the EDID's
(WW) NVIDIA(0):	 this mode's HorizSync (15.6 kHz); ignoring HorizSync check
(WW) NVIDIA(0):	 for mode "720x576".
(WW) NVIDIA(0):	 "1920x1080" is specified in the EDID; however, the EDID's
(WW) NVIDIA(0):	 this mode's HorizSync (27.0 kHz); ignoring HorizSync check
(WW) NVIDIA(0):	 for mode "1920x1080".
(WW) NVIDIA(0):	 valid VertRefresh range (50.000-75.000 Hz) would exclude
(WW) NVIDIA(0):	 this mode's VertRefresh (24.0 Hz); ignoring VertRefresh
(WW) NVIDIA(0):	 check for mode "1920x1080".
(WW) NVIDIA(0):	 this mode's VertRefresh (25.0 Hz); ignoring VertRefresh
(WW) NVIDIA(0):	 this mode's VertRefresh (30.0 Hz); ignoring VertRefresh
(II) NVIDIA(0): Assigned Display Devices: DFP-0, DFP-1
(II) NVIDIA(0): Validated modes:
(II) NVIDIA(0):
(II) NVIDIA(0):	 "DFP-0:1680x1050_60_0+1360+0,DFP-1:nvidia-auto-select+0+0"
(II) NVIDIA(0):
(II) NVIDIA(0):	 "DFP-0:nvidia-auto-select+1360+0,DFP-1:nvidia-auto-select+0+0"
(II) NVIDIA(0): Virtual screen size determined to be 3040 x 1050
(**) NVIDIA(0): DPI set to (96, 96); computed from "DPI" X config option
(==) NVIDIA(0): Enabling 32-bit ARGB GLX visuals.
(--) Depth 24 pixmap format is 32 bpp
(II) do I need RAC?  No, I don't.
(II) resource ranges after preInit:
(II) NVIDIA(0): Initialized GPU GART.
(II) NVIDIA(0): Unable to connect to the ACPI daemon; the ACPI daemon may not
(II) NVIDIA(0):	 be running or the "AcpidSocketPath" X configuration option
(II) NVIDIA(0):	 may not be set correctly.  When the ACPI daemon is
(II) NVIDIA(0):	 available, the NVIDIA X driver can use it to receive ACPI
(II) NVIDIA(0):	 events.  For details, please see the "ConnectToAcpid" and
(II) NVIDIA(0):	 "AcpidSocketPath" X configuration options in Appendix B: X
(II) NVIDIA(0):	 Config Options in the README.
(II) NVIDIA(0): Setting mode
(II) Loading extension NV-GLX
(II) NVIDIA(0): NVIDIA 3D Acceleration Architecture Initialized
(II) NVIDIA(0): Using the NVIDIA 2D acceleration architecture
(==) NVIDIA(0): Backing store disabled
(==) NVIDIA(0): Silken mouse enabled
(**) Option "dpms"
(**) NVIDIA(0): DPMS enabled
(II) Loading extension NV-CONTROL
(II) Loading extension XINERAMA
(==) RandR enabled
(II) Initializing built-in extension MIT-SHM
(II) Initializing built-in extension XInputExtension
(II) Initializing built-in extension XTEST
(II) Initializing built-in extension XKEYBOARD
(II) Initializing built-in extension XC-APPGROUP
(II) Initializing built-in extension SECURITY
(II) Initializing built-in extension XINERAMA
(II) Initializing built-in extension XFIXES
(II) Initializing built-in extension RENDER
(II) Initializing built-in extension RANDR
(II) Initializing built-in extension COMPOSITE
(II) Initializing built-in extension DAMAGE
(II) Initializing built-in extension XEVIE
(II) Initializing extension GLX
(**) Option "CoreKeyboard"
(**) Keyboard0: always reports core events
(**) Option "Protocol" "standard"
(**) Keyboard0: Protocol: standard
(**) Option "AutoRepeat" "500 30"
(**) Option "XkbRules" "xorg"
(**) Keyboard0: XkbRules: "xorg"
(**) Option "XkbModel" "pc105"
(**) Keyboard0: XkbModel: "pc105"
(**) Option "XkbLayout" "no"
(**) Keyboard0: XkbLayout: "no"
(**) Option "CustomKeycodes" "off"
(**) Keyboard0: CustomKeycodes disabled
(**) Option "Protocol" "auto"
(**) Option "Device" "/dev/psaux"
(II) Mouse0: Setting mouse protocol to "ExplorerPS/2"
(**) Mouse0: Device: "/dev/psaux"
(**) Mouse0: Protocol: "auto"
(**) Option "CorePointer"
(**) Mouse0: always reports core events
(**) Option "Emulate3Buttons" "no"
(**) Option "ZAxisMapping" "4 5"
(**) Mouse0: ZAxisMapping: buttons 4 and 5
(**) Mouse0: Buttons: 9
(**) Mouse0: Sensitivity: 1
(II) evaluating device (Keyboard0)
(II) XINPUT: Adding extended input device "Keyboard0" (type: KEYBOARD)
(II) evaluating device (Mouse0)
(II) XINPUT: Adding extended input device "Mouse0" (type: MOUSE)
(II) Mouse0: ps2EnableDataReporting: succeeded
(II) config/hal: Adding input device Logitech Logitech BT Mini-Receiver
(II) LoadModule: "evdev"
(WW) Warning, couldn't open module evdev
(II) UnloadModule: "evdev"
(EE) Failed to load module "evdev" (module does not exist, 0)
(EE) No input driver matching `evdev'
(EE) config/hal: NewInputDeviceRequest failed
(II) config/hal: Adding input device G15 Keyboard G15 Keyboard
(II) config/hal: Adding input device Gaming Keyboard
(II) config/hal: Adding input device Logitech USB Gaming Mouse
(II) config/hal: Adding input device Macintosh mouse button emulation
AUDIT: Tue Oct 14 23:44:54 2008: 3258 Xorg: client 5 rejected from local host ( uid=1000 gid=100 pid=3274 )
 Auth name: MIT-MAGIC-COOKIE-1 ID: -1
AUDIT: Tue Oct 14 23:44:54 2008: 3258 Xorg: client 5 rejected from local host ( uid=1000 gid=100 pid=3275 )
AUDIT: Tue Oct 14 23:44:54 2008: 3258 Xorg: client 5 rejected from local host ( uid=1000 gid=100 pid=3276 )
LG 32LG3000 er lcd-tv'en min, noen som har peiling på dette og kan hjelpe meg?
Endret av cyclo
La til spoiler tag
