Det0x Skrevet 9. juli 2009 Rapporter Del Skrevet 9. juli 2009 (endret) Tenkte jeg skulle oppdatere litt på Elpida Hyper-fronten, Corsair har klart og fremprovosere de feilene som folk har fått med Elpida Hyper-chips( at de dør altså) og de trekker tilbake alt av brikker i GT-serien( brikker som bruker Elpida Hyper-chips) og kommer ikke i salg igjen før de har funnet en løsning. We have seen a number of reports across various forums about failures of modules (from Corsair as well as from other memory manufacturers) built with Elpida “Hyper” RAMs. Through lab testing, we have now been able to reproduce similar failures. We are continuing to test to determine the cause of these failures. Note that although a relatively small percentage of “Hyper” ICs appear to be affected, the rate of failure is not acceptable to Corsair or to our customers. Due to these failures, we will no longer sell Hyper-based modules until the issue can be resolved. We have also have asked our retailers to return any modules they currently have on their shelves. Products impacted include TW3X4G1600C6GTF, TR3X6G1866C7GTF, TR3X6G2000C8GTF, TR3X3G2000C7GTF, and TR3X6G2000C7GTF. We are working on enhancing our manufacturing and testing process to be able to offer these parts again as soon as possible. We continue to stand behind these modules 100% with our standard warranty, which can be found at http://www.corsair.com/warranty/default.aspx. Kingston kommer ikke med nye brikker innen T1 serien før 1 august siden de skal gå over til Samsung og de sier:' Kingston will not get anymore of this ram in until Aug 1, 2009. So that means you can't get a rma replacement but they do offer a full refund since they know they are out. So either send them back to where you bought them from, if you want another kit....or get a full refund if you so choose. Er butikker som har opplevd 50% rma på Elpida Hyper-brikker, så noe må gjøres. Bra at de tar det seriøst ihvertfall:) Får bare krysse fingrene for at Elpida Hyper kommer sterkere tilbake eller at Samsungs nye chips vil rocke villmann;) Står litt om det her også Blir 7-7-7-20 @ 1600mhz brikker på meg Endret 9. juli 2009 av Det0x Lenke til kommentar
Cortinarius rubellus Skrevet 9. juli 2009 Rapporter Del Skrevet 9. juli 2009 Joda, men Cas9. sett på 2000mhz fronten har ikke Elpida hyper. Ikke 2000 sett til 13-1400kr. Foreks. Ocz Blade Cas.9 har ikke Elpida Hyper;) Kingstin T1 cas.9 2000mhz 6gig settet har Elpida Hyper mener jeg, det ser man på prisen. De settene som er meget dyre har ofte Elpida Hyper. Jeg venter selv på Ocz Blade Cas.9;) Lenke til kommentar
powersound Skrevet 9. juli 2009 Rapporter Del Skrevet 9. juli 2009 Hvor mye bedre er I7 950 enn I7 920? Driver og kanske ser på en liten update nå Lenke til kommentar
wim Skrevet 9. juli 2009 Rapporter Del Skrevet 9. juli 2009 Vel, den kjører på 3.06ghz isteden for 2.66ghz, det er vel eneste forskjellen. Mulig den klokker bittelitt bedre, ettersom de har blitt binned som 950 isteden for 920, men jeg tror dette er små forskjeller som ikke er synlig ved vanlig kjøling som luft, og kanskje tilogmed ikke synlig ved vannkjøling. Lenke til kommentar
Nizzen Skrevet 9. juli 2009 Forfatter Rapporter Del Skrevet 9. juli 2009 Skal du oppgradere fra 920 til en 920 så vil jeg desverre kalle deg noob. Altså det er så liten forskjell, at jeg heller ville ha kjøpt en 3. 4890 skjermkort enn å oppgradert fra 920 d0 til 950. Eller mye heller kjøpt en større skjerm, hvis jeg ser riktig at du har en 22" skjerm. Lenke til kommentar
powersound Skrevet 9. juli 2009 Rapporter Del Skrevet 9. juli 2009 Vel, den kjører på 3.06ghz isteden for 2.66ghz, det er vel eneste forskjellen. Mulig den klokker bittelitt bedre, ettersom de har blitt binned som 950 isteden for 920, men jeg tror dette er små forskjeller som ikke er synlig ved vanlig kjøling som luft, og kanskje tilogmed ikke synlig ved vannkjøling. Blir vannkjøling på det. Men spørsmålet er om det er hvert det. Pris messig så går jeg nok så å si opp i opp vid salg av den PC:n jeg sitter på nå... håper jeg hvertfall. Så håper på litt formeninger om 950 er noe bedre enn 920:en vid overklokking og vannkjøling. Lenke til kommentar
powersound Skrevet 9. juli 2009 Rapporter Del Skrevet 9. juli 2009 (endret) Skal du oppgradere fra 920 til en 920 så vil jeg desverre kalle deg noob. Altså det er så liten forskjell, at jeg heller ville ha kjøpt en 3. 4890 skjermkort enn å oppgradert fra 920 d0 til 950. Eller mye heller kjøpt en større skjerm, hvis jeg ser riktig at du har en 22" skjerm. Ser hva du mener nizzen;) Men skal ha ett nytt kabinett og får kjøpt løst et rampage hk og en 950 til en grei pris så prisen vill da bli den samme på 920 og en 950 for meg. Og som jeg har merket så er det lettere og mer prisgunstig og selge og bygge ny enn å selge av noen av komponentene. Og kan ikke ha større skjerm der jeg sitter nå. Endret 9. juli 2009 av powersound Lenke til kommentar
knopflerbruce Skrevet 9. juli 2009 Rapporter Del Skrevet 9. juli 2009 Vel, den kjører på 3.06ghz isteden for 2.66ghz, det er vel eneste forskjellen. Mulig den klokker bittelitt bedre, ettersom de har blitt binned som 950 isteden for 920, men jeg tror dette er små forskjeller som ikke er synlig ved vanlig kjøling som luft, og kanskje tilogmed ikke synlig ved vannkjøling. Blir vannkjøling på det. Men spørsmålet er om det er hvert det. Pris messig så går jeg nok så å si opp i opp vid salg av den PC:n jeg sitter på nå... håper jeg hvertfall. Så håper på litt formeninger om 950 er noe bedre enn 920:en vid overklokking og vannkjøling. Hvor mye har du klokket den 920'en til nå? Lenke til kommentar
powersound Skrevet 9. juli 2009 Rapporter Del Skrevet 9. juli 2009 Hvor mye har du klokket den 920'en til nå? Nå ligger den bare på 3,8 på stock kjøler da jeg mangler litt deler til vannkjølingen. I utgangspunkt her så lurer jeg bare på hvor mye bedre 950 er. Ikke hvor dum jeg ev. er om jeg bytter. Søker kunnige folk som kan litt om I7 serien og det tror jeg det finnes her. Lenke til kommentar
MiRaCL Skrevet 9. juli 2009 Rapporter Del Skrevet 9. juli 2009 (endret) Hvor vil man betale så mye mer for en litt raskere cpu? Bare å klokke i vei 920'en du allerede har. Ingen garanti for at en 950 vil klokke noe bedre. Begge cpuer på samme mhz yter likt. Jeg klokka min w3520 til 4ghz rett etter at jeg satt sammen maskinen. Surrer å går fint der på luftkjøling. Har ikke prøvd å klokke den noe mer enda, yter meget bra i samtlige spill jeg spiller atm. Tror mange her som ikke får klokka så langt har dårlig kabinett kjøling og cpu kjøling? Powersound: Hvorfor har du kun klokket den ti 3.8ghz? Endret 9. juli 2009 av MiRaCL Lenke til kommentar
MiKA7 Skrevet 9. juli 2009 Rapporter Del Skrevet 9. juli 2009 Hvor mye har du klokket den 920'en til nå? Nå ligger den bare på 3,8 på stock kjøler da jeg mangler litt deler til vannkjølingen. I utgangspunkt her så lurer jeg bare på hvor mye bedre 950 er. Ikke hvor dum jeg ev. er om jeg bytter. Søker kunnige folk som kan litt om I7 serien og det tror jeg det finnes her. en fordel er at den har høyere multiplier.. men til luft/vannkjøling kan du like godt bruke en 920.. Er det en D0 du har?? du vil ikke tjene så mye på å selge en 950 heller.. det er ett tapsprosjekt uansett.. Lenke til kommentar
powersound Skrevet 9. juli 2009 Rapporter Del Skrevet 9. juli 2009 Hvor mye har du klokket den 920'en til nå? Nå ligger den bare på 3,8 på stock kjøler da jeg mangler litt deler til vannkjølingen. I utgangspunkt her så lurer jeg bare på hvor mye bedre 950 er. Ikke hvor dum jeg ev. er om jeg bytter. Søker kunnige folk som kan litt om I7 serien og det tror jeg det finnes her. en fordel er at den har høyere multiplier.. men til luft/vannkjøling kan du like godt bruke en 920.. Er det en D0 du har?? du vil ikke tjene så mye på å selge en 950 heller.. det er ett tapsprosjekt uansett.. nå begynner det og ligne noe her, slik info jeg igrunn var ute etter. Ja, det er en D0 jeg har fra før av. Lenke til kommentar
Dyver`n Skrevet 10. juli 2009 Rapporter Del Skrevet 10. juli 2009 (endret) Ser ut som jeg skal få til en god klokk i helgen, får opp rigen nå som jeg har fått alle delene Et par bilder Endret 10. juli 2009 av Dyver`n Lenke til kommentar
BadCat Skrevet 10. juli 2009 Rapporter Del Skrevet 10. juli 2009 Vil gjerne høre hva du synes om det hovedkortet og om du fikk satt bra frekvens på minnet. Venter på DDR3-minne nå, så bruker tiden på å prøve å bestemme meg for hovedkort. Liker ikke noen av de som er på markedet nå så blir kanskje å måtte rulle terning på hva jeg skal kjøpe:p Hvis jeg ikke gjør noe så banalt som å kjøpe DFI-pga UV-reaktive slotter som blir fancy i mitt kabinett SilverStone Fortress Lenke til kommentar
SilentNET Skrevet 11. juli 2009 Rapporter Del Skrevet 11. juli 2009 (endret) Da har jeg montert min nye Corsair H50 på cpu, og temperaturen er nede i 67 grader på varmeste kjerne ved 22 grader i rommet. (LinX load ved Use all memory) Dette er 7 grader kaldere enn min TRUE med 2 vifter i push pull. Og nå bruker jeg bare 1 stk Antec TriCool vifte på radiatoren. Slettes ikke dårlig for et alt i ett vannkjølingsett til rundt 700,-. Dette er da fortsatt på min W3540 @ 3969MHz og 1,2v vCore under load. Jeg er i alle fall godt fornøyd Endret 11. juli 2009 av SilentNET Lenke til kommentar
Dyver`n Skrevet 11. juli 2009 Rapporter Del Skrevet 11. juli 2009 Bra å se at billige vannkjølings systemer slår de beste luftkjølerne ... Var jo omvent får et 1 siden... Lenke til kommentar
Nizzen Skrevet 11. juli 2009 Forfatter Rapporter Del Skrevet 11. juli 2009 (endret) Ser ut som Corsair H50 faktisk er bra http://www.hexus.net/content/item.php?item=19073&page=7 Koster kr 958,- på komplett + frakt og har 120mm vifte og 1366 fester. Lite info på datakjedens og amentios side om hva som følger med der. Men prisen er veldig lav de sidene. Litt reklamevideo om kjøleren Endret 11. juli 2009 av Nizzen Lenke til kommentar
pcp160 Skrevet 11. juli 2009 Rapporter Del Skrevet 11. juli 2009 Vannkjøling og luftkjøling begynner på sett og vis å flyte litt over i hverandre med enkle lukkede vannkjølesystemer, og avansert varmerørsteknologi på luftkjølere. Men den ser jo faktisk god ut denne lille tassen fra Corsair ja! Lenke til kommentar
Theo343 Skrevet 11. juli 2009 Rapporter Del Skrevet 11. juli 2009 (endret) Æsj, den H50 frister jo kraftig. Men den bråker vel en del mer enn TRUE med gode 1200rpm vifter på pushn pull? Noise The quietest of the trio is the comparison Thermalright Ultra. It has a single 120mm fan that spins at <1,500rpm at all times. Intel's reference heatsink's fan runs all the way up to 2,500rpm when under the cosh, and the difference between idle and load is immediately obvious - the fan is loud when at full chat. Corsair's Hydro H50 has a couple of noise-making components. The supplied fan spins at 1,700-1,750rpm and it's suggested to leave this without the usual speed-management in place. Secondly, the pump's impeller spins at 1,450rpm. Neither is particularly load, sure, but are a touch noisier than the Thermalright. EDIT: Den er jo kun marginalt bedre enn TRUE på temp, så nei. Men en interessant utvikling og ikke minst helt topp for mATX systemer med lite plass til store kjølere! Evt. HTPC vinner kanskje. Endret 11. juli 2009 av Theo343 Lenke til kommentar
ATWindsor Skrevet 11. juli 2009 Rapporter Del Skrevet 11. juli 2009 Tror jeg blåser i undervoltingen, klarer å holde CPUen på akseptabel temp etter 30 minutter med prime95 i sommervarmen på 600 rpm på vifta. Da er jeg ganske fornøyd med resultatet. AtW Lenke til kommentar
