SirLeon Skrevet 13. oktober 2008 Skrevet 13. oktober 2008 Hei.. Trenger en search funksjon til mine sider, men den skal bare være for selve siden og ikke for hele webben. Har tittet en del rundt men har ikke funnet noen ordentlig fungerende script. Så lurte litt på om noen av dere her har noen tips og komme med, eller egne lagde search funksjoner som fungerer. Kan være i php eller mysql, java eller html. your choice^^ Takk for all hjelp!
InsertNumLock Skrevet 13. oktober 2008 Skrevet 13. oktober 2008 (endret) 1. Kopier koden i step one inn i HEAD 2. Kopier koden i step two inn i body. Dette er søkeknappen <!-- STEP ONE: Paste this code into the HEAD of your HTML document --> <HEAD> <script LANGUAGE="JavaScript"> <!-- Original: Dion ([email protected]) --> <!-- Web Site: http://www.iinet.net.au/~biab --> <!-- This script and many more are available free online at --> <!-- The JavaScript Source!! http://javascript.internet.com --> <!-- Begin var item = new Array(); /* Here is where all the magic happens. Just enter as many additional pages that that you want to search, then fill in the additional listings for each page. */ // "Page Name","path","Page Title","Many,Key,Words","Descriptive Comments" c=0; item[c]=new Array("index.html","","DemoSite","index,main,start,home,front","Demonstration search engine data about an imagined but probable internet site."); c++; item[c]=new Array("about.htm","","About Me","about,author,contact,email,who","Contact details and general information about the creator of the site and what the site is about."); c++; item[c]=new Array("links.htm","","Links page","links,more,where,similar,friends","Links to my favourite sites which I find interesting. Other friends sites which have similar interests to my own."); c++; item[c]=new Array("main.htm","main/","Main Page","content,main,focus","The main part of my site which contains what you have come to see. Lots of stuff like that and more great things. All in a sub directory."); c++; item[c]=new Array("logo.jpg","main/images/","Link Logo","link,image,logo,graphic","The logo.jpg is just a small image which you can place on your site as a link to me. It's in a second level subdirectory."); page="<html><head><title>Search Results</title></head><body bgcolor='white'><center><table border=0 cellspacing=10 width=80%>"; function search(frm) { win = window.open("","","scrollbars"); win.document.write(page); txt = frm.srchval.value.split(" "); fnd = new Array(); total=0; for (i = 0; i < item.length; i++) { fnd[i] = 0; order = new Array(0, 4, 2, 3); for (j = 0; j < order.length; j++) for (k = 0; k < txt.length; k++) if (item[i][order[j]].toLowerCase().indexOf(txt[k]) > -1 && txt[k] != "") fnd[i] += (j+1); } for (i = 0; i < fnd.length; i++) { n = 0; w = -1; for (j = 0;j < fnd.length; j++) if (fnd[j] > n) { n = fnd[j]; w = j; }; if (w > -1) total += show(w, win, n); fnd[w] = 0; } win.document.write("</table><br>Total found: "+total+"<br></body></html>"); win.document.close(); } function show(which,wind,num) { link = item[which][1] + item[which][0]; line = "<tr><td><a href='"+link+"'>"+item[which][2]+"</a> Score: "+num+"<br>"; line += item[which][4] + "<br>"+link+"</td></tr>"; wind.document.write(line); return 1; } // End --> </script> </HEAD> <!-- STEP TWO: Copy this code into the BODY of your HTML document --> <BODY> <center> <form method=get action="java script:void(0)" onsubmit="search(this); return false;"> <tr><td><input type=text name=srchval value=""><input type=submit value="Search"></td></tr> </form> </center> Endret 13. oktober 2008 av Hille
SirLeon Skrevet 13. oktober 2008 Forfatter Skrevet 13. oktober 2008 ja dette skriptet er en mulighet. men vil bli VELDIG tungvindt når man har over 100 sider. å måtte skrive inn hver enkelt side i <head> delen. Og spesielt og når siden oppdateres gjevnlig med fler sider. noe med mysql database hadde vært fint.. f.eks.
qualbeen Skrevet 18. oktober 2008 Skrevet 18. oktober 2008 å bruke google eller andre selskapers løsninger er som regel det som gir best resultat. F.eks. har nrk.no nylig gått over til google. Men det er jo ingenting som er artigere enn å løse det selv Om du vil ha en dum søkesak (og all informasjon ligger i databaser) er det jo svært enkelt å lage en funksjon som tar inn en søkestreng, kjører en "select * from table where txt like $query" og printer resultat. Men det fins jo laangt bedre måter å gjøre søk på. Blandt annet er det kjekt med algoritmer som også gir treff på Levenshtein distanse under ett angitt nivå..
