Vil Du Joine Burnout Paradise Online For å Få Trophies?
dannad
Heisann folkens
Er det noen her som er med på å spille Burnout Paradise online for å få Trophies? :p
Det skjer flere ganger at når jeg setter i gang 'Timed Challenges' så tar en eller flere og dropper ut og oppdraget blir mislykket...
Men hvis vi er flere som vet hva man skal gjøre - og som er ute etter det samme, kan det være lettere å skaffe de Troféene som bare kan skaffes online.
Her er noen av Troféene som krever online-spilling:
Complete 10 Freeburn Challenge (Silver): Awarded when you complete your 10th Freeburn Challenge
- Win your 10th Freeburn Challenge. If you are the host you can start a freeburn from the ‘Easy Drive’ menu under ‘Challenges.’ A Timed Challenge does not count as a Freeburn Challenge.
8 Players meet in the Wildcats’ Baseball Stadium (Bronze): Awarded for meeting up with 7 other players inside the Wildcats’ Baseball Stadium in an online game
- You’ll need a cooperative group of 8 players to pull this off as all 8 of you must be present inside the Wildcats’ Baseball Stadium at once. There are 8-player Freeburn and Timed Challenges that involve meeting up here. This must be done in cars and not in bikes.
Complete 10 Timed Challenges (Gold): Awarded when you complete your 10th Timed Challenge
- Complete your tenth Timed Challenge. If you are the host you can start a Timed Challenge from the ‘Easy Drive’ menu under ‘Challenges.’ A Freeburn Challenge does not count as a Timed Challenge.
Take part in an Online Stunt Run (Bronze): Awarded for taking part in an Online Stunt Run
- Take part in an Online Stunt Run. If you are the host, select ‘Events’ from the ‘Freeburn Menu.’
Take part in an Online Marked Man (Bronze): Awarded for taking part in an Online Marked Man
- Take part in an Online Marked Man. If you are the host, select ‘Events’ from the ‘Freeburn Menu.’
Be on the Blue team for Online Road Rage (Bronze): Awarded for taking part in an Online Road Rage as a Runner on the Blue Team
- Take part in an Online Road Rage. You can change your team color from the ‘Freeburn Menu.’ If you are the host, select ‘Events’ from the ‘Freeburn Menu.’ After teams are set up select ‘Start Event.’
Be on the Red team for Online Road Rage (Bronze): Awarded for taking part in an Online Road Rage as a Chaser on the Red Team
Noen som ønsker å være med? :)
