Sondre Skrevet 8. oktober 2008 Del Skrevet 8. oktober 2008 (endret) Edit: Problem løst. If you are able to see Servers in Steam Server Browser but not in the Game Server Browser then the problem is that you have a firewall that is blocking hl.exe from accessing the internet. You need to remove all permissions for Steam.exe and all instances of HL.exe (there will be one for each different game that you play) and then either re-add them or allow the firewall to discover them again when you run Steam and each of the games. You need to give permission for TCP & UDP and for all ports when the firewall asks. Hvordan i all verden gjør jeg dette? Kjører Windows Vista og bruker Norman Security Suite. Endret 8. oktober 2008 av Sondr3h Lenke til kommentar
