Hvordan sette permission på NTFS med VBS Script?
'* File: FileMan.vbs
'* Created: March 1999
'* Version: 1.0
'* Main Function: Perform various simple operations on a file.
'* 1. Fileman.vbs /D <targetfile> | /T <targetfile>
'* [/s <server>][/u <username>][/W <password>]
'* [/O <outputfile>]
'* 2. Fileman.vbs /R <targetfile> | /C <targetfile>
'* /N <newfile>
'* Copyright © 1999 Microsoft Corporation
OPTION EXPLICIT
'Define constants
CONST CONST_ERROR = 0
CONST CONST_WSCRIPT = 1
CONST CONST_CSCRIPT = 2
CONST CONST_SHOW_USAGE = 3
CONST CONST_PROCEED = 4
CONST CONST_DELETE = 5
CONST CONST_RENAME = 6
CONST CONST_COPY = 7
CONST CONST_TAKEOWNERSHIP = 8
'Declare variables
Dim intOpMode, i
Dim strServer, strUserName, strPassword, strOutputFile
Dim strTaskCommand, strFileName, strNewFileName
Dim blnForce
'Make sure the host is csript, if not then abort
VerifyHostIsCscript()
'Parse the command line
intOpMode = intParseCmdLine(strServer , _
strUserName , _
strPassword , _
strOutputFile , _
strTaskCommand , _
strFileName , _
strNewFileName , _
blnForce )
Select Case intOpMode
Case CONST_SHOW_USAGE
Call ShowUsage()
Case CONST_PROCEED
Call FileMan(strServer , _
strUserName , _
strPassword , _
strOutputFile , _
strTaskCommand , _
strFileName , _
strNewFileName , _
blnForce )
Case CONST_ERROR
Call Wscript.Echo("Invalid or missing parameters " _
& "Please check the input and try again," & vbCRLF _
& "or invoke with '/?' for help with the syntax.")
Wscript.Quit
Case Else 'Default -- should never happen
Call Wscript.Echo("Error occurred in passing parameters.")
End Select
'* End of Script
'* Sub FileMan
'* Purpose: Perform various simple operations on a file.
'* Input:
'* strServer a machine name
'* strOutputFile an output file name
'* strUserName the current user's name
'* strPassword the current user's password
'* strTaskCommand the file operation to perform
'* strFileName the target file
'* strNewFileName the new file
'* blnForce overwrite read only files.
Private Sub FileMan(strServer , _
strUserName , _
strPassword , _
strOutputFile , _
strTaskCommand , _
strFileName , _
strNewFileName , _
blnForce )
ON ERROR RESUME NEXT
Dim objFileSystem, objOutputFile, objService
Dim strQuery
'Open a text file for output if the file is requested
If Not IsEmpty(strOutputFile) Then
If (NOT blnOpenFile(strOutputFile, objOutputFile)) Then
Call Wscript.Echo ("Could not open an output file.")
Exit Sub
End If
End If
'Establish a connection with the server.
If blnConnect("rootcimv2" , _
strUserName , _
strPassword , _
strServer , _
objService ) Then
Call Wscript.Echo("")
Call Wscript.Echo("Please check the server name, " _
& "credentials and WBEM Core.")
Exit Sub
End If
'Now execute the method.
Select Case strTaskCommand
Case CONST_DELETE
Call DeleteFile(strServer , _
strUserName , _
strPassword , _
objService , _
objOutputFile , _
strFileName , _
blnForce )
Case CONST_RENAME
Call RenameFile(strServer , _
strUserName , _
strPassword , _
objService , _
objOutputFile , _
strFileName , _
strNewFileName )
Case CONST_COPY
Call CopyFile(strServer , _
strUserName , _
strPassword , _
objService , _
objOutputFile , _
strFileName , _
strNewFileName )
Case CONST_TAKEOWNERSHIP
Call TakeOwnOfFile(strServer , _
strUserName , _
strPassword , _
objService , _
objOutputFile , _
strFileName )
Case CONST_ERROR
'Do nothing.
End Select
If NOT IsEmpty(objOutputFile) Then
objOutputFile.Close
Wscript.Echo "Results are saved in file " & strOutputFile & "."
End If
End Sub
'* Sub DeleteFile()
'* Purpose: Delete a file.
'* Input: strServer a machine name
'* objService The Wbem service
'* objOutputFile The Output File Object
'* strFileName The file to delete.
'* blnForce Overwrite Read-Only files
'* Output: Results are either printed on screen or saved in strOutputFile.
Private Sub DeleteFile(ByVal strServer , _
ByVal strUserName , _
ByVal strPassword , _
ByVal objService , _
ByVal objOutputFile , _
ByVal strFileName , _
ByVal blnForce )
Dim strWBEMClass
Dim objFileSet, objInst
Dim intFileCount
strWBEMClass = "CIM_DataFile"
strFileName = strDoubleBackSlashes(strFileName)
Set objFileSet = objService.ExecQuery("SELECT * FROM " & strWBEMClass & _
" WHERE Name = """ & strFileName & """",,0)
if objFileSet.Count = 0 then
Call WriteLine("File not found.", objOutputFile)
Exit Sub
End If
If blnErrorOccurred("Could not obtain " & strWBEMClass & " instance.") Then
Exit Sub
End If
intFileCount = 0
For Each objInst In objFileSet
If blnCheckFile(objInst.Name,objService,blnForce) Then
Call objInst.Delete()
If NOT blnErrorOccurred("Could not delete " & objInst.Name) Then
intFileCount = intFileCount + 1
End If
Else
Call WriteLine("File is either marked as a system file, " _
& "or is read only.", objOutputFile)
Call WriteLine("Use the /F switch to override.", objOutputFile)
End If
Next
If blnErrorOccurred("Could not delete " & strFileName & ".") Then
Exit Sub
Else
Call WriteLine("File deleted.", objOutputFile)
End If
End Sub
'* Sub RenameFile()
'* Purpose: Rename a file.
'* Input: strServer A machine name
'* strUserName The current user's name
'* strPassword The current user's password
'* strNewFileName The new file name
Private Sub RenameFile(ByVal strServer , _
ByVal strNewFileName )
Dim strWBEMClass
Dim objInst, objFileSet
Set objFileSet = objService.ExecQuery("SELECT * FROM " & strWBEMClass _
& " WHERE Name = """ & strFileName & """",,0)
Call Writeline ("File not found.", objOutputFile)
Exit Sub
End If
Exit Sub
End If
For Each objInst in objFileSet
Call objInst.Rename(strNewFileName)
If blnErrorOccurred("Could not copy " & strFileName & ".") Then
Exit Sub
Else
Call WriteLine("File renamed.", objOutputFile)
End If
Next
End Sub
'* Sub CopyFile()
'* Purpose: Copy a file.
'* strFileName The file to copy.
'* strNewFileName The new file name.
Private Sub CopyFile(ByVal strServer , _
Dim strWBEMClass
Set objFileSet = objService.ExecQuery("SELECT * FROM " & _
strWBEMClass & " WHERE Name = """ & strFileName & """",,0)
Exit Sub
End If
Exit Sub
End If
Call objInst.Copy(strNewFileName)
Exit Sub
Else
Call WriteLine("File copied.", objOutputFile)
End If
Next
End Sub
'* Sub TakeOwnOfFile()
'* Purpose: Take ownership of a file.
'* strFileName the file to sieze
Private Sub TakeOwnOfFile(ByVal strServer , _
ByVal strFileName )
Dim objFileSystem, objInst
Dim strWBEMClass
Set objInst = objService.Get(strWBEMClass & "=" & """" & strFileName & """")
Exit Sub
End If
Call objInst.TakeOwnerShip()
If blnErrorOccurred("Could not take ownership of " & strFileName & ".") Then
Exit Sub
Else
Call WriteLine("Ownership taken.", objOutputFile)
End If
End Sub
'* Function intParseCmdLine()
'* Purpose: Parses the command line.
'* Input:
'* Output: strServer a remote server ("" = local server")
'* strTaskCommand one of /list, /start, /stop /install /remove
'* /dependents
'* strDriverName name of the DEVICE
'* strStartMode start mode of the DEVICE
'* strDisplayName Display name for the DEVICE.
'* blnDetails Extra information to be displayed on the output
Private Function intParseCmdLine( ByRef strServer , _
ByRef strUserName , _
ByRef strPassword , _
ByRef strOutputFile , _
ByRef strTaskCommand , _
ByRef strFileName , _
ByRef strNewFileName , _
ByRef blnForce )
Dim strFlag
Dim intState, intArgIter
Dim objFileSystem
If Wscript.Arguments.Count > 0 Then
strFlag = Wscript.arguments.Item(0)
End If
If IsEmpty(strFlag) Then 'No arguments have been received
intParseCmdLine = CONST_ERROR
Wscript.Echo("Arguments are required")
Exit Function
End If
'Check if the user is asking for help or is just confused
If (strFlag="help") OR (strFlag="/h") OR (strFlag="h") OR (strFlag="-h") _
OR (strFlag = "?") OR (strFlag = "/?") OR (strFlag = "?") _
OR (strFlag="h") Then
intParseCmdLine = CONST_SHOW_USAGE
Exit Function
End If
'Retrieve the command line and set appropriate variables
intArgIter = 0
Do While intArgIter <= Wscript.arguments.Count - 1
Select Case LCase(Wscript.arguments.Item(intArgIter))
Case "/s"
If Not blnGetArg("Server", strServer, intArgIter) Then
Exit Function
End If
intArgIter = intArgIter + 1
Case "/o"
If Not blnGetArg("Output File", strOutputFile, intArgIter) Then
Exit Function
End If
Case "/u"
If Not blnGetArg("User Name", strUserName, intArgIter) Then
Exit Function
End If
Case "/w"
If Not blnGetArg("User Password", strPassword, intArgIter) Then
Exit Function
End If
Case "/d"
If Not blnGetArg ("Target File", strFileName, intArgIter) Then
Exit Function
End If
strTaskCommand = CONST_DELETE
intParseCmdLine = CONST_PROCEED
Case "/t"
Exit Function
End If
strTaskCommand = CONST_TAKEOWNERSHIP
Case "/r"
Exit Function
End If
strTaskCommand = CONST_RENAME
Case "/c"
Exit Function
End If
strTaskCommand = CONST_COPY
Case "/n"
If Not blnGetArg ("New File", strNewFileName, intArgIter) Then
Exit Function
End If
Case Else 'We shouldn't get here
Call Wscript.Echo("Invalid or misplaced parameter: " _
& Wscript.arguments.Item(intArgIter) & vbCRLF _
Wscript.Quit
End Select
Loop '** intArgIter <= Wscript.arguments.Count - 1
If IsEmpty(intParseCmdLine) Then
Wscript.Echo ("Required arguments [/D | /T | /C | /R] are missing.")
End If
If strTaskCommand = CONST_COPY then
if isEmpty(strNewFileName) then
Wscript.Echo ("The /N parameter is required when copying.")
End If
End If
If strTaskCommand = CONST_RENAME then
Wscript.Echo ("The /N parameter is required when renaming a file.")
End If
End If
End Function
'* Sub ShowUsage()
'* Purpose: Shows the correct usage to the user.
'* Input: None
'* Output: Help messages are displayed on screen.
Private Sub ShowUsage()
Wscript.Echo ""
Wscript.Echo "Perform various simple operations on a file."
Wscript.Echo ""
Wscript.Echo "SYNTAX:"
Wscript.Echo "1. Fileman.vbs /D <targetfile> | /T <targetfile>"
Wscript.Echo " [/s <server>][/u <username>][/W <password>]"
Wscript.Echo " [/O <outputfile>]"
Wscript.Echo ""
Wscript.Echo "2. Fileman.vbs /R <targetfile> | /C <targetfile>"
Wscript.Echo " /N <newfile>"
Wscript.Echo ""
Wscript.Echo "PARAMETER SPECIFIERS:"
Wscript.Echo " /D Delete File"
Wscript.Echo " /T Take Ownership of file"
Wscript.Echo " /R Rename File"
Wscript.Echo " /C Copy File"
Wscript.Echo " targetfile The target file."
Wscript.Echo " newfile The destination filename."
Wscript.Echo " server A machine name."
Wscript.Echo " username The current user's name."
Wscript.Echo " password Password of the current user."
Wscript.Echo " outputfile The output file name."
Wscript.Echo ""
Wscript.Echo "EXAMPLE:"
Wscript.Echo "1. cscript Fileman.vbs /d c:test.txt /s MyMachine2"
Wscript.Echo " Deletes the file test.txt on the machine MyMachine2."
Wscript.Echo "2. cscript Fileman.vbs /r c:test.txt /n c:new.txt"
Wscript.Echo " Renames the file test.txt to new.txt on the " _
& "local machine."
Wscript.Echo ""
Wscript.Echo "NOTE:"
Wscript.Echo "1. You must include the full path when specifying " _
& "the files."
Wscript.Echo ""
Wscript.Echo "2. Wildcards (*, ?) will not work."
End Sub
'* General Routines
'* Function blnCheckFile()
'* Purpose: Checks to see if file is read only or marked as a system file.
'* Input: strFileName The file to check
'* objService The WBEM object
'* blnForce Whether to force an action on a read only file.
'* Output: Ture or False
Function blnCheckFile(strFileName,objService,blnForce)
Dim objFileSet
Dim strWBEMClass
Dim Inst
If blnForce=True Then
blnCheckFile=True
Exit Function
Else
blnCheckFile=False
End If
strWBEMClass = "CIM_LogicalFile"
Exit Function
End If
For Each Inst In objFileSet
If Inst.System = True then
Exit Function
ElseIf inst.Writeable = False then
Exit Function
Else
blnCheckFile = True
End If
Next
End Function
'* Function: strDoubleBackSlashes (strIn)
'* Purpose: expand path string to use double node-delimiters;
'* doubles ALL backslashes.
'* Input: strIn path to file or directory
'* Output: WMI query-food
'* eg: c:pagefile.sys becomes c:pagefile.sys
'* but: servershare becomes servershare
Private Function strDoubleBackSlashes (strIn)
Dim i, str, strC
str = ""
for i = 1 to len (strIn)
strC = Mid (strIn, i, 1)
str = str & strC
if strC = "" then str = str & strC
next
strDoubleBackSlashes = str
End Function
'* Function strPackString()
'* Purpose: Attaches spaces to a string to increase the length to intWidth.
'* Input: strString a string
'* intWidth the intended length of the string
'* blnAfter Should spaces be added after the string?
'* blnTruncate specifies whether to truncate the string or not if
'* the string length is longer than intWidth
'* Output: strPackString is returned as the packed string.
Private Function strPackString( ByVal strString, _
ByVal intWidth, _
ByVal blnAfter, _
ByVal blnTruncate)
intWidth = CInt(intWidth)
blnAfter = CBool(blnAfter)
blnTruncate = CBool(blnTruncate)
If Err.Number Then
Call Wscript.Echo ("Argument type is incorrect!")
Err.Clear
Wscript.Quit
End If
If IsNull(strString) Then
strPackString = "null" & Space(intWidth-4)
Exit Function
End If
strString = CStr(strString)
If Err.Number Then
Err.Clear
Wscript.Quit
End If
If intWidth > Len(strString) Then
If blnAfter Then
strPackString = strString & Space(intWidth-Len(strString))
Else
strPackString = Space(intWidth-Len(strString)) & strString & " "
End If
Else
If blnTruncate Then
strPackString = Left(strString, intWidth-1) & " "
Else
strPackString = strString & " "
End If
End If
End Function
'* Function blnGetArg()
'* Purpose: Helper to intParseCmdLine()
'* Usage:
'* Case "/s"
'* blnGetArg ("server name", strServer, intArgIter)
Private Function blnGetArg ( ByVal StrVarName, _
ByRef strVar, _
ByRef intArgIter)
blnGetArg = False 'failure, changed to True upon successful completion
If Len(Wscript.Arguments(intArgIter)) > 2 then
If Mid(Wscript.Arguments(intArgIter),3,1) = ":" then
If Len(Wscript.Arguments(intArgIter)) > 3 then
strVar = Right(Wscript.Arguments(intArgIter), _
Len(Wscript.Arguments(intArgIter)) - 3)
blnGetArg = True
Exit Function
Else
If intArgIter > (Wscript.Arguments.Count - 1) Then
Call Wscript.Echo( "Invalid " & StrVarName & ".")
Call Wscript.Echo( "Please check the input and try again.")
Exit Function
End If
strVar = Wscript.Arguments.Item(intArgIter)
If Err.Number Then
Exit Function
End If
If InStr(strVar, "/") Then
Call Wscript.Echo( "Invalid " & StrVarName)
Exit Function
End If
blnGetArg = True 'success
End If
Else
Len(Wscript.Arguments(intArgIter)) - 2)
Exit Function
End If
Else
Exit Function
End If
If Err.Number Then
Exit Function
End If
Exit Function
End If
End If
End Function
'* Function blnConnect()
'* Purpose: Connects to machine strServer.
'* strNameSpace a namespace
'* strUserName name of the current user
'* strPassword password of the current user
'* Output: objService is returned as a service object.
'* strServer is set to local host if left unspecified
Private Function blnConnect(ByVal strNameSpace, _
ByVal strUserName, _
ByVal strPassword, _
ByRef strServer, _
ByRef objService)
Dim objLocator, objWshNet
blnConnect = False 'There is no error.
'Create Locator object to connect to remote CIM object manager
Set objLocator = CreateObject("WbemScripting.SWbemLocator")
If Err.Number then
Call Wscript.Echo( "Error 0x" & CStr(Hex(Err.Number)) & _
" occurred in creating a locator object." )
If Err.Description <> "" Then
Call Wscript.Echo( "Error description: " & Err.Description & "." )
End If
Err.Clear
blnConnect = True 'An error occurred
Exit Function
End If
'Connect to the namespace which is either local or remote
Set objService = objLocator.ConnectServer (strServer, strNameSpace, _
strUserName, strPassword)
ObjService.Security_.impersonationlevel = 3
If Err.Number then
" occurred in connecting to server " _
& strServer & ".")
End If
Err.Clear
End If
'Get the current server's name if left unspecified
If IsEmpty(strServer) Then
Set objWshNet = CreateObject("Wscript.Network")
strServer = objWshNet.ComputerName
End If
End Function
'* Sub VerifyHostIsCscript()
'* Purpose: Determines which program is used to run this script.
'* Input: None
'* Output: If host is not cscript, then an error message is printed
'* and the script is aborted.
Dim strFullName, strCommand, i, j, intStatus
strFullName = WScript.FullName
If Err.Number then
Call Wscript.Echo( "Error 0x" & CStr(Hex(Err.Number)) & " occurred." )
End If
intStatus = CONST_ERROR
End If
i = InStr(1, strFullName, ".exe", 1)
If i = 0 Then
Else
j = InStrRev(strFullName, "", i, 1)
If j = 0 Then
Else
strCommand = Mid(strFullName, j+1, i-j-1)
Select Case LCase(strCommand)
Case "cscript"
intStatus = CONST_CSCRIPT
Case "wscript"
intStatus = CONST_WSCRIPT
Case Else 'should never happen
Call Wscript.Echo( "An unexpected program was used to " _
& "run this script." )
Call Wscript.Echo( "Only CScript.Exe or WScript.Exe can " _
& "be used to run this script." )
End Select
End If
End If
If intStatus <> CONST_CSCRIPT Then
Call WScript.Echo( "Please run this script using CScript." & vbCRLF & _
"This can be achieved by" & vbCRLF & _
"1. Using ""CScript PS.VBS arguments"" for Windows 95/98 or" _
& vbCRLF & "2. Changing the default Windows Scripting Host " _
& "setting to CScript" & vbCRLF & " using ""CScript " _
& "//H:CScript //S"" and running the script using" & vbCRLF & _
" ""PS.VBS arguments"" for Windows NT/2000." )
WScript.Quit
End If
End Sub
'* Sub WriteLine()
'* Purpose: Writes a text line either to a file or on screen.
'* Input: strMessage the string to print
'* objFile an output file object
'* Output: strMessage is either displayed on screen or written to a file.
Sub WriteLine(ByVal strMessage, ByVal objFile)
On Error Resume Next
If IsObject(objFile) then 'objFile should be a file object
objFile.WriteLine strMessage
Else
Call Wscript.Echo( strMessage )
End If
End Sub
'* Function blnErrorOccurred()
'* Purpose: Reports error with a string saying what the error occurred in.
'* Input: strIn string saying what the error occurred in.
'* Output: displayed on screen
Private Function blnErrorOccurred (ByVal strIn)
If Err.Number Then
Call Wscript.Echo( "Error 0x" & CStr(Hex(Err.Number)) & ": " & strIn)
Call Wscript.Echo( "Error description: " & Err.Description)
End If
Err.Clear
blnErrorOccurred = True
Else
blnErrorOccurred = False
End If
End Function
'* Function blnOpenFile
'* Purpose: Opens a file.
'* Input: strFileName A string with the name of the file.
'* Output: Sets objOpenFile to a FileSystemObject and setis it to
'* Nothing upon Failure.
Private Function blnOpenFile(ByVal strFileName, ByRef objOpenFile)
Dim objFileSystem
Set objFileSystem = Nothing
If IsEmpty(strFileName) OR strFileName = "" Then
blnOpenFile = False
Set objOpenFile = Nothing
Exit Function
End If
'Create a file object
Set objFileSystem = CreateObject("Scripting.FileSystemObject")
If blnErrorOccurred("Could not create filesystem object.") Then
blnOpenFile = False
Exit Function
End If
'Open the file for output
Set objOpenFile = objFileSystem.OpenTextFile(strFileName, 8, True)
If blnErrorOccurred("Could not open") Then
blnOpenFile = False
Exit Function
End If
blnOpenFile = True
End Function
'* End of File *
Det scriptet over inneholder mulighet for å ta ownership... Det hjelper ikke meg så mye da jeg må ha muligheten til å spessifisere at hjemmekatalogene til brukerne skal ha sikkerhet på denne måten: admin og "User"
Noen som kan hjelpe?
