Legge til marker ved klikk (google maps)
Hei!
Har en lang kode jeg bruker med Google Maps her, blant annet søkefunksjon osv. Alt funker veldig bra, men det jeg argher meg over er at jeg ikke ønsker at marker er der før man klikker en gang på kartet. Kan noen hjelpe meg endre dette?
Her er koden:
<script type="text/javascript">
//<![CDATA[
// globals
var map;
var marker;
var places = [ ];
// geocoder variables and constants
var geo = new GClientGeocoder();
var reasons = [ ];
	reasons[G_GEO_SUCCESS] = "Success";
	reasons[G_GEO_MISSING_ADDRESS] = "Missing Address: The address was either missing or had no value.";
	reasons[G_GEO_UNKNOWN_ADDRESS] = "Unknown Address:  No corresponding geographic location could be found for the specified address.";
	reasons[G_GEO_UNAVAILABLE_ADDRESS] = "Unavailable Address:  The geocode for the given address cannot be returned due to legal or contractual reasons.";
	reasons[G_GEO_BAD_KEY] = "Bad Key: The API key is either invalid or does not match the domain for which it was given";
	reasons[G_GEO_TOO_MANY_QUERIES] = "Too Many Queries: The daily geocoding quota for this site has been exceeded.";
	reasons[G_GEO_SERVER_ERROR] = "Server error: The geocoding request could not be successfully processed.";
	reasons[G_GEO_BAD_REQUEST] = "A directions request could not be successfully parsed.";
	reasons[G_GEO_MISSING_QUERY] = "No query was specified in the input.";
	reasons[G_GEO_UNKNOWN_DIRECTIONS] = "The GDirections object could not compute directions between the points.";
var accuracy = [ ];
	accuracy[0] = 'Ukjent';
	accuracy[1] = 'Land';
	accuracy[2] = 'Region';
	accuracy[3] = 'Sub-region';
	accuracy[4] = 'By';
	accuracy[5] = 'Post adresse';
	accuracy[6] = 'Gate';
	accuracy[7] = 'Vei';
	accuracy[8] = 'Adresse';
	accuracy[9] = 'Område';
// fix precision of reported Lat/Lng
function fix6ToString(n) {
	return n.toFixed(6).toString();
// get window width independent of browser
function getWWidth() {
	var myWidth = 0;
	if( typeof( window.innerWidth ) == 'number' ) {
//Non-IE
		myWidth = window.innerWidth;
	} else if( document.documentElement && document.documentElement.clientWidth) {
//IE 6+ in 'standards compliant mode'
		myWidth = document.documentElement.clientWidth;
	} else if( document.body && document.body.clientWidth ) {
//IE 4 compatible
		myWidth = document.body.clientWidth;
	return myWidth;
// get window height independent of browser
function getWHeight() {
	var myHeight = 0;
	if( typeof( window.innerHeight ) == 'number' ) {
		myHeight = window.innerHeight;
	} else if( document.documentElement && document.documentElement.clientHeight) {
		myHeight = document.documentElement.clientHeight;
	} else if( document.body && document.body.clientHeight ) {
		myHeight = document.body.clientHeight;
	return myHeight;
// set div size
function setDivSize() {
	if (getWWidth()) {  // if it works!
		document.getElementById("googleMap").style.width = getWWidth() > 758 ? Math.ceil(getWWidth()*0.300) +'px' : '450px';
	if (getWHeight()) {
		document.getElementById("googleMap").style.height = Math.ceil(getWHeight()*0.300) +'px';
// resize map keeping same centre
function resizeAndCenterMap() {
	var mapcenter = map.getCenter();
	setDivSize();
	map.checkResize();
	map.setCenter(mapcenter);
// nudges
function nudgeW() {
	var ll = marker.getPoint();
	var newll = new GLatLng(ll.lat(), (ll.lng() - nudgeFactor().lng()));
	marker.setPoint(newll);
	marker.redraw();
	GEvent.trigger(marker,'click');
function nudgeE() {
	var newll = new GLatLng(ll.lat(), (ll.lng() + nudgeFactor().lng()));
	marker.redraw();
function nudgeN() {
	var newll = new GLatLng(ll.lat() + nudgeFactor().lat(), ll.lng());
	marker.redraw();
function nudgeS() {
	var newll = new GLatLng(ll.lat() - nudgeFactor().lat(), ll.lng());
	marker.redraw();
// nudgeFactor returns GLatLng with Lat & Lng per pixel
function nudgeFactor() {
	var b = map.getBounds().toSpan(); // LatLng as size of the map
	var s = map.getSize(); // width and height of map in pixels
	return new GLatLng(b.lat()/s.height , b.lng()/s.width );
// zoom in
function zoomIn() {
	var mag = map.getZoom();
	if (mag < 19) mag += 1;
	map.setCenter(map.getCenter(), mag);
// zoom out
function zoomOut() {
	if (mag > 2) mag -= 1;
// main map drawing function
function load() {
	var nudgestring =  "<table cellpadding='0' cellspacing='0' border='0' class='blockcenter'><tr><td> </td><td><a href='java script:nudgeN()' accesskey='n'><img src='images/btn_arrow_up.gif' alt='up' title='nudge north' width='20' height='20' border='0' /></a></td><td> </td></tr>" +
"<tr><td><a href='java script:nudgeW()'><img src='images/btn_arrow_l.gif' alt='left' title='nudge west' width='20' height='20' border='0' /></a></td><td><img src='images/mark_mini.gif' alt='marker' title='nudge marker' width='20' height='20' /></td><td><a href='java script:nudgeE()'><img src='images/btn_arrow_r.gif' alt='right' title='nudge east' width='20' height='20' border='0' /></a></td></tr>" +
"<tr><td> </td><td><a href='java script:nudgeS()'><img src='images/btn_arrow_dn.gif' alt='down' title='nudge south' width='20' height='20' border='0' /></a></td><td> </td></tr></table>";
	if (GBrowserIsCompatible()) {
// Reset the initial size of the map div to fill screen
		setDivSize();
// Start processing the map
		map = new GMap2(document.getElementById("googleMap"));
		GEvent.addListener(map, "moveend", function() {
			var center = map.getCenter();
			document.getElementById("message").innerHTML = "Midten av kartet @ " + fix6ToString(center.lat()) + " , " + fix6ToString(center.lng());
		GEvent.addListener(map, "dblclick", function(moverlay, mpoint) {
			marker.setPoint(mpoint);
// Lane Realty pos
		var LRPoint = new GLatLng(<?php echo $kontroll['geokode']; ?>);
		var CentrePoint = new GLatLng(<?php echo $kontroll['geokode']; ?>);
// Add controls
		map.addMapType(G_PHYSICAL_MAP);
		map.addControl(new GLargeMapControl());
		map.addControl(new GScaleControl());
		map.addControl(new GMapTypeControl());
		map.setCenter(CentrePoint,5);
// Now the marker and click label
		marker = new GMarker(LRPoint, {draggable: true});
		GEvent.addListener(marker, "click", function() {
			var point = marker.getPoint();
			marker.InfoWindowHtml( fix6ToString(point.lat()) + " , " + fix6ToString(point.lng()) + nudgestring);
			map.addOverlay(marker);
		GEvent.addListener(marker, "dragstart", function() {
			map.closeInfoWindow();
		GEvent.addListener(marker, "dragend", function() {
			marker.openInfoWindowHtml( fix6ToString(point.lat()) + " , " + fix6ToString(point.lng()) + nudgestring);
			GEvent.addListener(marker, "drag", function(){
document.getElementById("location").value=marker.getPoint().toUrlValue();
// Monitor the window resize event and let the map know when it occurs
		if (window.attachEvent) {	// IE
			window.attachEvent("onresize", function() {resizeAndCenterMap();} );
		} else { 					// others
			window.addEventListener("resize", function() {resizeAndCenterMap();} , false);
// Display marker info window
// Add Lat Long to centre report at base of map
		GEvent.trigger(map,'moveend');
// Set marker for placemark
function setPlaceMarker(n) {
	  var p = places[n].Point.coordinates;
	  map.setCenter(new GLatLng(p[1],p[0]), 8 + places[n].AddressDetails.Accuracy);
	marker.setPoint(new GLatLng(p[1],p[0]));
	marker.redraw();
// Find an Address...
function findaddress( ){
	if (document.addressform.address.value) {
		var address = document.addressform.address.value;
		geo.getLocations(address, function (result) {
			if (result.Status.code == G_GEO_SUCCESS) {
				  document.getElementById("geomessage").innerHTML = "<br /><br /><b>Fant " + result.Placemark.length +" result(er)</b>";
				  for (var i=0; i<result.Placemark.length; i++){
					places[i] = result.Placemark[i];
					  var p = places[i].Point.coordinates;
   					document.getElementById("geomessage").innerHTML += "<br /><br /> <input type='button' value='Vis adresse på kart!' onclick='setPlaceMarker(" + i + ")' name='goto" + i + "' /><br /> "+(i+1)+": "+ places[i].address + " : " + p[1] + " , " + p[0] + "<br /> <b>Resultat:</b> " + accuracy[places[i].AddressDetails.Accuracy] + "<br />";
				setPlaceMarker(0);
 			} else {
				  var reason="Code "+result.Status.code;
				  if (reasons[result.Status.code]) {
					  reason = reasons[result.Status.code]
				  alert('Could not find "' + address + '" ' + reason);
  		} else {
		alert('Must have something in the address!')
</script>
  • 2 uker senere...
Oj, det var da litt v en kode smørje :D Har du lyst til å dele webside, vil se hvordan dette ser ut :)
Har du sett på eksemplene google selv har gitt ut for API`et?
De har eksempler på de fleste funksjonene. Brukte de flittig da jeg lagde adressebase her på jobben i sommer.
eksempel for å hente muesklikk fra kartet og legge til en marker der du klikket: http://code.google.com/apis/maps/documenta...nt-removal.html
