Gå til Virustotal og last opp følgende fil for sjekk:
C:\WINDOWS\system32\ws341274.ocx
Gi tilbakemelding på om det ble funnet noe på fila.
Kunne du også si noe om hva som evt. oppleves som et problem?
Jeg synes den har blitt litt tregere. Spesielt i starten, da bruker den lenger tid, enn den pleier. Og så har minne på HDD, gått ned. Og jeg har ikke lastet ned/ lagt inn noen programmer som er store.
Svar:
File ws341274.ocx received on 10.05.2008 14:25:36 (CET)
Current status: Loading ... queued waiting scanning finished NOT FOUND STOPPED
Result: 0/36 (0%)
Loading server information...
Your file is queued in position: 1.
Estimated start time is between 37 and 53 seconds.
Do not close the window until scan is complete.
The scanner that was processing your file is stopped at this moment, we are going to wait a few seconds to try to recover your result.
If you are waiting for more than five minutes you have to resend your file.
Your file is being scanned by VirusTotal in this moment,
results will be shown as they're generated.
Compact Print results
Your file has expired or does not exists.
Service is stopped in this moments, your file is waiting to be scanned (position: ) for an undefined time.
You can wait for web response (automatic reload) or type your email in the form below and click "request" so the system sends you a notification when the scan is finished.
Email:
Antivirus Version Last Update Result
AhnLab-V3 2008.10.3.2 2008.10.03 -
AntiVir 7.8.1.34 2008.10.04 -
Authentium 5.1.0.4 2008.10.05 -
Avast 4.8.1248.0 2008.10.04 -
AVG 8.0.0.161 2008.10.05 -
BitDefender 7.2 2008.10.05 -
CAT-QuickHeal 9.50 2008.10.04 -
ClamAV 0.93.1 2008.10.04 -
DrWeb 4.44.0.09170 2008.10.05 -
eSafe 7.0.17.0 2008.10.02 -
eTrust-Vet 31.6.6129 2008.10.04 -
Ewido 4.0 2008.10.05 -
F-Prot 4.4.4.56 2008.10.05 -
F-Secure 8.0.14332.0 2008.10.05 -
Fortinet 3.113.0.0 2008.10.04 -
GData 19 2008.10.05 -
Ikarus T3.1.1.34.0 2008.10.05 -
K7AntiVirus 7.10.484 2008.10.04 -
Kaspersky 7.0.0.125 2008.10.05 -
McAfee 5398 2008.10.04 -
Microsoft 1.4005 2008.10.05 -
NOD32 3495 2008.10.04 -
Norman 5.80.02 2008.10.03 -
Panda 9.0.0.4 2008.10.05 -
PCTools 4.4.2.0 2008.10.05 -
Prevx1 V2 2008.10.05 -
Rising 20.63.62.00 2008.09.28 -
SecureWeb-Gateway 6.7.6 2008.10.05 -
Sophos 4.34.0 2008.10.05 -
Sunbelt 3.1.1675.1 2008.09.27 -
Symantec 10 2008.10.05 -
TheHacker 6.3.1.0.101 2008.10.04 -
TrendMicro 8.700.0.1004 2008.10.03 -
VBA32 3.12.8.6 2008.10.04 -
ViRobot 2008.10.4.1406 2008.10.04 -
VirusBuster 4.5.11.0 2008.10.04 -
Additional information
File size: 565 bytes
MD5...: 296b369ebbbbfbb76781cc662b0c8b4c
SHA1..: cbe7606e83543b209206c3d27a16e6a8b16d6f63
SHA256: 8b8bbfbf642691c16fe21b867261de56822321e4474d2b09001d699ec17eeebe
SHA512: e358e64ddbc2756ba9bd666cc37387380587e398e08f0ecb0ec5ffdaf995c7e5
8219deba220d0c3af6c8eb01710e929d6fc52351a4e4eccd4b1a3a2710ce7d3c
PEiD..: -
TrID..: File type identification
Unknown!
Endret av macgyver1958
Svar:
Result: 0/36 (0%)
Email:
PEiD..: -
Unknown!
mener du når den logger inn? hvis det er tilfelle så går du på start, kjør, og skriver "msconfig" også går du på fanen "oppstart" hvis du har vista så må du søke etter "kjør"
Ser greit ut dette. Det eneste som kunne ha vært noe er disse to filene:
C:\os501435.bin
Hvis du selv ikke vet hva disse to filene er, så kunne du ha endret filendelsen midlertidig og sett om det hadde gjort noe utslag på ett eller annet.
ws341274.ocx -> ws341274.ocx.bak
os501435.bin -> os501435.bin.bak
Ut over dette kunne du ha fjernet program som du ikke bruker
Kjørt en rens med CCleaner (se punkt 1 i veiledningen)
Fjernet progarm fra oppstarten som du ikke behøver skal starte opp samtidig med Windows (skriv msconfig i kjør-feltet, velg arkfanen Oppstart)
C:\os501435.bin
Så da skal jeg lage et CFScript på Skrivebordet med disse filene:
C:\os501435.bin
Og etter dette skal jeg
Gå til Start > Kjør
Skriv følgende i boksen:
combofix /u
Trykk Enter.
Denne kommandoen vil:
Fjerne følgende:
ComboFix og dets tilhørende filer og mapper.
Nullstille klokke-instillingene.
Skjule filetternavn hvis det er nødvendig.
Skjule System/Skjulte filer og mapper hvis det er nødvendig.
Nullstille systemgjennoprettingspunkter.
Du finner fram til de to filene (via utforsker), høyreklikker på filen(e) og velger å endre navn. Ikke fjern noe fra navnet. men legg til .bak
Hvis du ikke ser gjeldne filendelse, så må du slå på funksjonen for å vise slike filendelser:
kontrollpanel->mappealternativer->Vis. Fjern avmerkingen framfor "skjul filetternavn for kjente filtyper".
Nå har jeg søkt med total commander 7.0, og finner ingen av filene.
