En nybegynner trenger hjelp med mutt
Hva er det jeg gjør feil?
Redigerer fila Muttrc som ligger i /etc.
Muttrc
source /home/bedra/Mutt/address (har manuelt opprettet disse mappene)
I terminalen svar mutt:
Error in /etc/Muttrc, line 94: /home/bedra/Mutt/address: Invalid argument source: errors in /etc/Muttrc
Press any key to continue...
Setter stor pris på rask hjelp!
eh. få se på hele config fila di. ta å nopaste /etc/Muttrc. eller wgetpaste eller hva du foretrekker.
Hei
Her er innholdet i configfila:
### .muttrc   BEGIN
# System configuration file for Mutt ( .muttrc )
###  Pager
ignore *
unignore  X-Bogosity From: Reply-To: To: Cc: Date: Subject:
hdr_order X-Bogosity From: Reply-To: To: Cc: Date: Subject:
###  Macros
# change mailbox
macro index <f5> 'c =inbox^M'
macro pager <f5> 'c =inbox^M'
macro index <f6> 'c =archive^M'
macro pager <f6> 'c =archive^M'
macro index <f7> 'c =saved^M'
macro pager <f7> 'c =saved^M'
macro index <f8> 'c =SPAM^M'
macro pager <f8> 'c =SPAM^M'
macro generic <f12> '!fetchmail^M'
# save attachments to incoming
macro attach s <save-entry><bol>/my_saved/incoming/
###  Headers
my_hdr From: e-post (bedra)
my_hdr Reply-To: e-post (bedra)
my_hdr Errors-To: e-post
my_hdr Organization: Open Source Software Supporter (OSSs)
# email address mutt knows this client as. This is used to
# avoid problems with the "metoo" argument not taking effect.
alternates foo|bar|baz@domene(1|2|3).com
# When OutLook receives email it will put it at the
# top of their mailbox list and flag it with an "urgent"
# red box. Just another way to play with Outlook/LookOut users.
my_hdr X-Message-Flag: OUTLOOK WARNING!! Use Open Source
my_hdr Reply-By: `date --date="-3 days"`
my_hdr X-MSMail-Priority: High
###  Colors
color quoted	yellow	 default
color quoted1   cyan	   default
color quoted2   magenta	default
color quoted3   green	  default
color quoted4   red		default
color signature blue default
color normal	white black
color status	brightgreen blue
color indicator brightyellow black
color error	 red black
color tree	  yellow black
color attachment blue default
color index	 cyan black (calomel.org)
color header	green black .*
color header	brightred  black (^From\:|^Reply-To\:)
color header	brightyellow black (^To\:|^cc\:|^Cc\:)
color body	  magenta	  default "(ftp|http|https)://[^ ]+"
color body	  magenta	  default [-a-z_0-9.]+@[-a-z_0-9.]+
color body	  brightgreen  default "^(gpg: )?Good signature"
color body	  brightgreen  default "^(gpg: )?encrypted"
color body	  brightred	default "^(gpg: )?Bad signature"
color body	  red		  default "^(gpg: )?warning:"
color body	  red		  default "^(gpg: ).*failed:"
color message	magenta		default # info messages
color search	 brightyellow   red	 # search matches
color tilde	  brightmagenta  default # ~ at bottom of msg
color markers	red			default # + at beginning of wrapped lines
color hdrdefault cyan		   default # default header lines
color bold	   cyan		   default # hiliting bold patterns in body
color underline  cyan		   default # hiliting underlined patterns in body
color index	 green		  default  ~T	  # Tagged
color index	 red			default  ~D	  # Deleted
###  Options
bind editor <BackSpace> backspace
push <show-version>
mailboxes ~/Mail/inbox
# Autoview attachments
unset implicit_autoview
alternative_order text/html text/enriched text/plain
auto_view text/html
set mailcap_path=~/.mailcap
set status_format="-%r-Mutt: %f --------[Msgs:%?M?%M/?%m%?n? New:%n?%?o? Old:%o?%?d? Del:%d?%?F? Flag:%F?%?t? Tag:%t?%?p? Post:%p?%?b? Inc:%b?%?l? %l?]-%>-----%h-(%P)"
 set alias_file="~/Mutt/address"
unset abort_nosubject
unset abort_unmodified
 set allow_8bit
unset arrow_cursor
unset ascii_chars
 set autoedit
unset beep
unset beep_new
unset bounce_delivered
 set check_new
unset confirmappend
 set copy
 set delete
unset edit_headers
 set editor = "vim -c 'set textwidth=77' -c 'map <C-x> gqap' -c 'map <C-c> :50d 9999<CR>'"
 set envelope_from
 set fast_reply
unset fcc_attach
 set fcc_clear
 set folder="~/Mail"
 set forward_decode
 set forward_format="Fwd: %s"
 set help
 set hostname="your_isp.com"
 set include
 set index_format="%3C %Z %(%D) %-27.27L (%4c) %s"
 set indent_string=">"
 set ispell="clear;aspell -e -c"
 set mailcap_sanitize
 set mail_check=1
unset markers
unset mark_old
 set menu_scroll
unset metoo
 set mime_forward=no
 set mime_forward_decode
 set mime_forward_rest
 set pager="builtin"
 set pager_format=""
 set pager_index_lines=10
 set pager_stop
unset postpone
 set postponed="~/Mail/postponed"
 set print=ask-no
 set read_inc=2
unset reply_self
 set reply_to
unset sig_dashes
 set sig_on_top
 set smart_wrap
 set sort_aux=last-date-received
 set sort=threads
 set sort_re
 set status_on_top
unset strict_threads
unset suspend
 set tilde
 set timeout=5
 set thorough_search
unset user_agent
unset wait_key
unset write_bcc
###  Hooks
# Hooks
send-hook . "set signature=~/Mutt/signature_long"
send-hook . "set signature=~/Mutt/signature_short"
send-hook . 'unset pgp_autoencrypt pgp_autosign'
send-hook . 'set record="~/Mail/archive"'
# Mark mail as read
#folder-hook archive push '<tag-pattern>.*\r<tag-prefix><clear-flag>N<untag-pattern>.*\r'
# Delete old mail after a set number of days
#folder-hook archive push 'D~r>32d!~F\n'
#folder-hook SPAM push 'D~r>60d!~F\n'
###  GPG Hooks
#my_hdr X-GPG-Key-Server: http://pgp.mit.edu
#my_hdr X-GPG-Key-FingerPrint: kode her
#send-hook e-post 'set pgp_autosign; set pgp_autoencrypt'
#pgp-hook e-post + pgp
#set pgp_decode_command="gpg %?p?--passphrase-fd 0? --no-verbose --batch --output - %f"
#set pgp_verify_command="gpg --no-verbose --batch --output - --verify %s %f"
#set pgp_decrypt_command="gpg --passphrase-fd 0 --no-verbose --batch --output - %f"
#set pgp_sign_command="gpg --no-verbose --batch --output - --passphrase-fd 0 --armor --detach-sign --textmode %?a?-u %a? %f"
#set pgp_clearsign_command="gpg --no-verbose --batch --output - --passphrase-fd 0 --armor --textmode --clearsign %?a?-u %a? %f"
#set pgp_encrypt_only_command="/usr/lib/mutt/pgpewrap gpg --batch --quiet --no-verbose --output - --encrypt --textmode --armor --always-trust --encrypt-to 123456789 -- -r %r -- %f"
#set pgp_encrypt_sign_command="/usr/lib/mutt/pgpewrap gpg --passphrase-fd 0 --batch --quiet --no-verbose --textmode --output - --encrypt --sign %?a?-u %a? --armor --always-trust --encrypt-to 123456789 -- -r %r -- %f"
#set pgp_import_command="gpg --no-verbose --import -v %f"
#set pgp_export_command="gpg --no-verbose --export --armor %r"
#set pgp_verify_key_command="gpg --no-verbose --batch --fingerprint --check-sigs %r"
#set pgp_list_pubring_command="gpg --no-verbose --batch --with-colons --list-keys %r"
#set pgp_list_secring_command="gpg --no-verbose --batch --with-colons --list-secret-keys %r"
#unset pgp_retainable_sigs
#set pgp_ignore_subkeys
#set pgp_verify_sig=yes
#set pgp_create_traditional=no
#set pgp_autosign=no
#set pgp_autoencrypt=no
#set pgp_sign_as=59CCE5B6
#set pgp_replysignencrypted
#set pgp_replyencrypt=yes
#set pgp_replysign=yes
#set pgp_timeout=3600
#set pgp_good_sign="^gpg: Good signature from"
### .muttrc  END
  • 2 uker senere...
Jeg tror source foretrekker filnavn, ikke dirnavn. (Du sa ~/Mutt/address og dirs så antar address også er dir.) Ellers noen grunn til at du bruker /etc/Muttrc og ikke ~/.muttrc? Skal du henvise til noe i et /home/ virker jo det litt sært å gjøre på systembrede filer ...
