FreakPalace Skrevet 2. oktober 2008 Del Skrevet 2. oktober 2008 Noen som kan være så snill og hjelpe meg og komme inn på denne japanske Manga siden? ja, det er bilder av gutter som kysser der, emn det er til 3 jenter i klassen min :-P Pliz hjelp meg og løse koden! PLIZ! PS. svaret skal være en nettside Koden: Vvv.ligzqsoeogxl.gku/ltektz/ofrtb.izds hintene: Pico's puzzle is called a cryptogram. It replaces letters with other letters. But, of course, they aren't replaced all willy-nilly. No, there is a pattern to it. The most common key to solving a cryptogram is to simply reverse the alphabet where A will mean Z, B will mean Y, C will mean X and so on. But that's too easy. Here are some clues on how to decipher Pico's puzzle: 1. It looks like it's a web address. This is made more evident since the first three letters before the dot are the same. Web addresses typically start with WWW. So it's pretty safe to say that V=W. 2. If it's a web address, it's either pixiesticks or shotalicious. Since pixiesticks is 11 letters long and shotalicious is 12, just count the number of letters past the first dot and you should have ALOT of help in figuring out what the remaining letters are. 3. Finally, the code ends in dot and four letters after it. Well that means it can't be .org or .com. What other combination do websites typically end in? If you can figure that out, there are some more letter combinations you've solved. If you're still stuck after all of that, try to figure out why the letters are being replaced by other letters. What pattern do they fall under? Sometimes the easiest answer is right under your nose. Lenke til kommentar
vikingkylling Skrevet 2. oktober 2008 Del Skrevet 2. oktober 2008 Første bit er helt enkelt: VVV = siden det er et kryptogram, bare dytt bokstavene ett hakk forover. Sier seg selv når det starter med tre identiske bokstaver, og det skal være en web-adresse. ligzqsoeog = Tenk logisk. Det er to mulige valg. Ett på elleve bokstaver og et på tolv. Hvor mange bokstaver er dette? gku = sammenlign bokstavene over med løsningen. Første del blir da: www.shotalicious.org/ Resten burde ikke være så vanskelig, men gidder ikke løse alt for deg. Lenke til kommentar
Acurus Skrevet 2. oktober 2008 Del Skrevet 2. oktober 2008 de 4 siste er sikkert html iallefall. så da har du at: v=W i=h z=t d=m s=l Lenke til kommentar
frentix Skrevet 2. oktober 2008 Del Skrevet 2. oktober 2008 Etter mye om og men fant jeg ut at koden blir til: http://www.youtube.com/watch?v=Yu_moia-oVI Lenke til kommentar
