Kan noen løse denne koden?
Hei kjære folk ;)
Noen som kan være så snill og hjelpe meg og komme inn på denne japanske Manga siden? ja, det er bilder av gutter som kysser der, emn det er til 3 jenter i klassen min :-P
Pliz hjelp meg og løse koden!
PLIZ!
PS. svaret skal være en nettside
Koden: Vvv.ligzqsoeogxl.gku/ltektz/ofrtb.izds
hintene: Pico's puzzle is called a cryptogram. It replaces letters with other letters. But, of course, they aren't replaced all willy-nilly. No, there is a pattern to it.
The most common key to solving a cryptogram is to simply reverse the alphabet where A will mean Z, B will mean Y, C will mean X and so on. But that's too easy.
Here are some clues on how to decipher Pico's puzzle:
1. It looks like it's a web address. This is made more evident since the first three letters before the dot are the same. Web addresses typically start with WWW. So it's pretty safe to say that V=W.
2. If it's a web address, it's either pixiesticks or shotalicious. Since pixiesticks is 11 letters long and shotalicious is 12, just count the number of letters past the first dot and you should have ALOT of help in figuring out what the remaining letters are.
3. Finally, the code ends in dot and four letters after it. Well that means it can't be .org or .com. What other combination do websites typically end in? If you can figure that out, there are some more letter combinations you've solved.
If you're still stuck after all of that, try to figure out why the letters are being replaced by other letters. What pattern do they fall under? Sometimes the easiest answer is right under your nose.
Gjest
