GIMP 2.6 klar
Litt mer info om den store nyheten GEGL:
Introduction
GIMP 2.6 is an important release from a development point of view. It features changes to the user interface addressing some often received complaints, and a tentative integration of GEGL, the graph based image processing library that will eventually bring high bit-depth and non-destructive editing to GIMP.
GEGL
Important progress towards high bit-depth and non-destructive editing in GIMP has been made. Most color operations in GIMP are now ported to the powerful graph based image processing framework GEGL, meaning that the interal processing is being done in 32bit floating point linear light RGBA. By default the legacy 8bit code paths are still used, but a curious user can turn on the use of GEGL for the color operations with Colors / Use GEGL.
Experimental GEGL tool screenshot
In addition to porting color operations to GEGL, an experimental GEGL Operation tool has been added, found in the Tools menu. It enables applying GEGL operations to an image and it gives on-canvas previews of the results. The screenshot to the right shows this for a Gaussian Blur.
GIMP 2.6 Release Notes
Hvordan er gimp i forhold til Photoshop (til hobby basis)
Bruker en del CS3 til redigering av bilder nå.
Har tidligere prøvd gimp 2.2.13 som fulgte pc'en. (synes denne versjonen er for tungvint da man har flere vinduer og drasse med)
