Trenger hjelp med mail form! Prøvd flere ganger selv!
Hallo, jeg hadde tenkt å redigere en mail form, men har en del problem, har prøvd mange ganger selv..
Er det mail form som har problemet? Eller er det jeg som ikke gjør det riktig.
Antal kbm/säckar*
Önskad längd ( 27 - 90 cm )*
Typ av ved*
Namn*
Gatuadress*
Postadress
Telefon*
Mobil
Vil ha inn disse!
Og her er php koden:
<?php
/*	   EMAIL CONTACT FORM	   */
/*		  VERSION 1.1		   */
/* Copyright 2004 (c) Epleweb.com */
/*	GNU General Public License
This program is free software; you can redistribute it and/or modify
it under the terms of the GNU General Public License as published by
the Free Software Foundation; either version 2 of the License, or
(at your option) any later version.
This program is distributed in the hope that it will be useful,
but WITHOUT ANY WARRANTY; without even the implied warranty of
MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
GNU General Public License for more details.
You should have received a copy of the GNU General Public License
along with this program; if not, write to the Free Software
Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA  02111-1307  USA
if ($_POST['submit'] == TRUE) {
$receiverMail = "[email protected]";
$name		= stripslashes(strip_tags($_POST['name']));
$email		= stripslashes(strip_tags($_POST['email']));
			$blabla		= stripslashes(strip_tags($_POST['blabla']));
$subject	= stripslashes(strip_tags($_POST['subject']));
$msg		= stripslashes(strip_tags($_POST['msg']));
$ip			= $_SERVER['REMOTE_ADDR'];
			$msgformat	= "From: $name ($ip)\nEmail: $email\n\n$msg\n$blabla";
if(empty($name) || empty($email) || empty($subject) || empty($msg)) {
	echo "<h2>The email was not sent</h2><p>Please fill all the required fields</p>";
elseif(!ereg("^[_a-z0-9-]+(\.[_a-z0-9-]+)*@[a-z0-9-]+(\.[a-z0-9-]+)*(\.[a-z]{2,3})$", $email)) {
	echo "<h2>The email was not sent</h2><p>The email address is invalid</p>";
elseif(mail($receiverMail, $subject, $msgformat, "From: $name <$email>")) {
	echo "<h2>The email has been sent!</h2><p>I will get back to you as soon as possible.</p>"; }
else {
	echo "<h2>The email was not sent</h2><p>Please try again... If the problem continues there's probably something wrong with the server.</p>";
else { ?>
<form method="post" action="">
<p>
<label for="name">Name</label>
<input id="name" name="name" type="text" size="30" maxlength="40" /><br />
<label for="email">Email</label>
<input id="email" name="email" type="text" size="30" maxlength="40" /><br />
<label for="subject">Subject</label>
<input id="subject" name="subject" type="text" size="30" maxlength="40" /><br />
	<label for="blabla">Bla Bla</label>
	<input id="blabla" name="blabla" type="text" size="30" maxlength="40" /><br />
<label for="message">Message</label>
<textarea id="message" name="msg" cols="50" rows="6"></textarea><br />
<label for="submit"> </label>
<input id="submit" class="button" type="submit" name="submit" value="Send" />
</p>
</form>
<?php } ?>
Takker for den som hjelper, har gjort det flere ganger men har ikke klart det!
TAKK!
Antal kbm/säckar*
Typ av ved*
Namn*
Gatuadress*
Postadress
Telefon*
Mobil
Legg til input til hvert av dem;)
<br>
Mobil:
<input type="text" name="mobil"><br>
PHP:
$mob_input = $_POST['mobil']
Har prøvd, ser ikke helt ut som om den virker? Gjør jeg feil?
Her er linken: http://vedexperten.se/try.php
Endret av Fight4Lov3
Antal kbm/säckar*
Typ av ved*
Namn*
Gatuadress*
Postadress
Telefon*
Mobil
<br>
Mobil:
PHP:
Det er helt hvit skjerm?
Prøv:
<?php
if (isset($_POST['submit'])) {
else {
<p>
</p>
</form>
Endret av Rematusen
Gjorde det..
Sjekk:
Jupp, nå fungerer det?
Bare legg til slik jeg sa lenger opp..
Jeg gjorde det, det men det førte til at det ble ingenting, som istad!
Du vet hvor du skal skrive hva?
altså jeg har prøvd flere ganger =(..
Mulig du kan gjøre det for meg? altså hvis du har tid? siden jeg er så lei av det! har prøvd flere flere ganger!
Om det er noe jeg kan gjøre for deg? Så kan du gjøre dette for meg? Takk
<?php
$blabla		= stripslashes(strip_tags($_POST['email_2']));
$msg		= stripslashes(strip_tags($_POST['email_3']));
$msg_1		= stripslashes(strip_tags($_POST['email_4']));
$msg_2		= stripslashes(strip_tags($_POST['email_5']));
$msg_3		= stripslashes(strip_tags($_POST['email_6']));
$msg_4		= stripslashes(strip_tags($_POST['email_7']));
			$msgformat	= "
			Telefon: $msg_3 MOB: $msg_4\n\n
			POSTADR: $msg_2\n
			GATU: $msg_1\n
			TYP AV VED: $blabla\n
			ØNSKET LENGE: $email\n
			Antal kbm/säckar: $name\n
else {
<p>
<label for="subject">EMNE PÅ MAIL: *</label>
<label for="name"><br>
Antal kbm/säckar*</label>
<label for="email">Önskad längd ( 27 - 90 cm )* </label>
<label for="message">Typ av ved*</label>
<input id="email" name="email_2" type="text" size="30" maxlength="40" /><br />
<label for="message">Namn*</label>
<input id="email" name="email_3" type="text" size="30" maxlength="40" /><br />
	<label for="blabla">Gatuadress*</label>
 <input id="email" name="email_4" type="text" size="30" maxlength="40" /><br />
<label for="message">Postadress </label>
<input id="email" name="email_5" type="text" size="30" maxlength="40" /><br />
<label for="message">Telefon* </label>
<input id="email" name="email_6" type="text" size="30" maxlength="40" /><br />
<label for="message">Mobil</label>
<input id="email" name="email_7" type="text" size="30" maxlength="40" /><br />
<input id="submit" class="button" type="submit" name="submit" value=" Send Mail " />
</p>
</form>
<?php
			$msgformat	= "
			POSTADR: $msg_2\n
			GATU: $msg_1\n
else {
<p>
</p>
</form>
Takk for jobben du har gjort, men den virker ikke helt.
Sjekk: Http://www.vedexperten.se/ready.php
Når jeg prøver og sender teksten så kommer det
Hva er problemet? Har du muligheten til å fikse den?
<?php
			$msgformat	= "
			POSTADR: $msg_2\n
			GATU: $msg_1\n
else {
<p>
</p>
</form>
Feil enda?
Endret av Rematusen
<?php
			$msgformat	= "
			POSTADR: $msg_2\n
			GATU: $msg_1\n
else {
<p>
</p>
</form>
Feil enda?
Jeg vet ikke hva jeg skal si nå, men du reddet meg!!! TAKK!!!
VELDIG TAKK NEMLIG! Det må jeg si! Tusen hjertelig TAKK!
Takk for hjelpen!
