Aktivere Beta Ps3?
puffyp
1. Sign in to your PLAYSTATION®Network account via your PLAYSTATION®3
system, or alternatively via PLAYSTATION®Store on PC at
store.playstation.com using the [sign In/Sign Up] button.
2. Once signed in, select [Account Management].
3. Choose [Transaction Management], then [Redeem PLAYSTATION®Network Card or
Promotion Code].
4. Enter your 12 character promotion code and select [Continue].
NOTE: promotion codes are case sensitive and must be entered exactly as
displayed.
INSERTVOUCHERCODE
5. Follow the on-screen instructions to redeem the promotion code.
Promotion codes can only be used once and only by the recipient. You must be
18 years or older to take part in this demo.
Endret av praystation
  • 2 uker senere...
Takker.. Har en nøkkel til COD 5 men det er 20 tall, og leste nå at Beta er kun på Xbox og Pc for COD5. Ahhh... dritt!
hvor fikk du tak i COD5 nøkkel :) ??
Jeg har og :D Fikk mail fra www.callofduty.com
Jeg bytter den gjerne mot PS3 Beta Key! :D :D
Eller selger den.
