Hvis du er koblet til nett med kabel, kan du forsøke å starte pc'n i sikker modus (tapp F8 under oppstart) og velg sikker modus m/nettverk.
Derfra laster du ned combofix, legg det på skrivebordet og kjører programmet. Post loggen den lager
Kjørte scan to ganger pga at loggen aldri blei fullført den første gangen. ventet i 30 min. Pcen ser bra ut nå. men her har du The Log :)
ComboFix 08-09-28.01 - 19020KEBA 2008-09-29 20:54:14.2 - NTFSx86
Microsoft Windows XP Professional 5.1.2600.3.1252.1.1044.18.1329 [GMT 2:00]
Running from: C:\Documents and Settings\19020KEBA\Skrivebord\ComboFix.exe
WARNING -THIS MACHINE DOES NOT HAVE THE RECOVERY CONSOLE INSTALLED !!
((((((((((((((((((((((((((((((((((((((( Other Deletions )))))))))))))))))))))))))))))))))))))))))))))))))
---- Previous Run -------
C:\Documents and Settings\19020KEBA\Favoritter\Error Cleaner.url
C:\Documents and Settings\19020KEBA\Favoritter\Privacy Protector.url
C:\Documents and Settings\19020KEBA\Favoritter\Spyware&Malware Protection.url
C:\Documents and Settings\19020KEBA\Skrivebord\Error Cleaner.url
C:\Documents and Settings\19020KEBA\Skrivebord\Privacy Protector.url
C:\Documents and Settings\19020KEBA\Skrivebord\Spyware&Malware Protection.url
C:\Programfiler\MicroAV
C:\Programfiler\MicroAV\MicroAV.ooo
C:\Programfiler\MicroAV\MicroAV0.dat
C:\Programfiler\MicroAV\MicroAV1.dat
C:\Programfiler\PCHealthCenter
C:\Programfiler\PCHealthCenter\1.ico
C:\Programfiler\PCHealthCenter\2.ico
C:\Programfiler\PCHealthCenter\sc.html
C:\WINDOWS\dfmlxbpkvkd.dll
C:\WINDOWS\Downloaded Program Files\setup.inf
C:\WINDOWS\ewte.exe
C:\WINDOWS\onfwbsak.dll
C:\WINDOWS\peltodgx.dll
C:\WINDOWS\rwlfsdmk.dll
C:\WINDOWS\system32\1.ico
C:\WINDOWS\system32\2.ico
C:\WINDOWS\system32\bbkxbrka.ini
C:\WINDOWS\system32\byxYrQKC.dll
C:\WINDOWS\system32\ssqNFuus.dll
C:\WINDOWS\system32\vtUmMgEW.dll
C:\WINDOWS\system32\WEgMmUtv.ini
C:\WINDOWS\system32\WEgMmUtv.ini2
((((((((((((((((((((((((( Files Created from 2008-08-28 to 2008-09-29 )))))))))))))))))))))))))))))))
2008-09-29 16:07 . 2008-09-29 16:07 <DIR> dr-h----- C:\Documents and Settings\19020KEBA\Siste
2008-09-29 16:06 . 2008-09-29 16:06 <DIR> d-------- C:\Programfiler\CCleaner
2008-09-29 16:00 . 2008-09-29 16:40 <DIR> d--h----- C:\$AVG8.VAULT$
2008-09-29 15:39 . 2008-09-29 15:39 80,512 --a------ C:\WINDOWS\system32\akrbxkbb.dll
2008-09-29 15:15 . 2008-09-29 15:56 <DIR> d-------- C:\WINDOWS\system32\drivers\Avg
2008-09-29 15:15 . 2008-09-29 15:15 <DIR> d-------- C:\Programfiler\AVG
2008-09-29 15:15 . 2008-09-29 15:15 <DIR> d-------- C:\Documents and Settings\All Users\Programdata\avg8
2008-09-29 15:15 . 2008-09-29 15:15 96,520 --a------ C:\WINDOWS\system32\drivers\avgldx86.sys
2008-09-29 15:15 . 2008-09-29 15:15 75,272 --a------ C:\WINDOWS\system32\drivers\avgtdix.sys
2008-09-29 15:15 . 2008-09-29 15:15 12,424 --a------ C:\WINDOWS\system32\drivers\avgrkx86.sys
2008-09-29 15:15 . 2008-09-29 15:15 10,520 --a------ C:\WINDOWS\system32\avgrsstx.dll
2008-09-29 10:09 . 2008-09-29 06:15 86,016 --a------ C:\WINDOWS\fbxrqtwn.exe
2008-09-29 10:06 . 2008-09-29 10:06 <DIR> d-------- C:\Programfiler\Your Freedom
2008-09-29 10:06 . 2008-09-29 10:06 <DIR> d-------- C:\Programfiler\SocksCapV2
2008-09-29 10:06 . 1998-02-06 22:37 299,520 --a------ C:\WINDOWS\uninst.exe
2008-09-29 10:05 . 2008-09-29 10:05 <DIR> d-------- C:\Documents and Settings\19020KEBA\WINDOWS
2008-09-28 20:53 . 2008-09-29 20:52 <DIR> d-------- C:\Programfiler\Steam
2008-09-28 19:38 . 2008-09-28 19:38 <DIR> d-------- C:\Documents and Settings\19020KEBA\Programdata\Media Player Classic
2008-09-28 19:37 . 2008-09-28 19:37 <DIR> d-------- C:\Programfiler\K-Lite Codec Pack
2008-09-28 19:37 . 2004-01-12 00:00 348,160 --a------ C:\WINDOWS\system32\msvcr71.dll
2008-09-28 19:37 . 2007-09-04 18:56 164,352 --a------ C:\WINDOWS\system32\unrar.dll
2008-09-28 19:37 . 2008-07-30 21:09 38 --a------ C:\WINDOWS\avisplitter.ini
2008-09-28 16:37 . 2008-09-28 16:37 <DIR> d-------- C:\Programfiler\WM Converter
2008-09-25 15:11 . 2008-09-26 14:53 <DIR> d-------- C:\Documents and Settings\19020KEBA\Contacts
2008-09-25 15:10 . 2008-09-25 15:10 268 --ah----- C:\sqmdata01.sqm
2008-09-25 15:10 . 2008-09-25 15:10 244 --ah----- C:\sqmnoopt01.sqm
2008-09-25 15:05 . 2008-09-25 15:09 <DIR> d-------- C:\Programfiler\Windows Live
2008-09-25 15:05 . 2008-09-25 15:08 <DIR> d--hsc--- C:\Programfiler\Fellesfiler\WindowsLiveInstaller
2008-09-25 15:05 . 2008-09-25 15:05 <DIR> d-------- C:\Documents and Settings\All Users\Programdata\WLInstaller
2008-09-25 03:04 . 2008-09-25 03:04 <DIR> d-------- C:\Programfiler\Microsoft CAPICOM 2.1.0.2
2008-09-24 19:24 . 2008-09-24 19:24 <DIR> d-------- C:\Programfiler\Fellesfiler\Blizzard Entertainment
2008-09-24 19:24 . 2008-09-24 19:24 <DIR> d-------- C:\Logs
2008-09-24 16:35 . 2008-09-24 16:35 <DIR> d-------- C:\Programfiler\uTorrent
2008-09-24 16:35 . 2008-09-27 10:50 <DIR> d-------- C:\Documents and Settings\19020KEBA\Programdata\uTorrent
2008-09-24 16:04 . 2008-09-24 16:04 0 --a------ C:\WINDOWS\nsreg.dat
2008-09-24 15:54 . 2008-06-14 19:36 272,256 -----c--- C:\WINDOWS\system32\dllcache\bthport.sys
2008-09-24 15:41 . 2008-09-28 16:25 <DIR> d-------- C:\Programfiler\World of Warcraft
2008-09-24 15:36 . 2001-10-06 13:36 12,160 --a------ C:\WINDOWS\system32\drivers\mouhid.sys
2008-09-24 15:36 . 2001-10-06 13:36 12,160 --a--c--- C:\WINDOWS\system32\dllcache\mouhid.sys
2008-09-24 15:36 . 2008-04-13 11:45 10,368 --a------ C:\WINDOWS\system32\drivers\hidusb.sys
2008-09-24 15:36 . 2008-04-13 11:45 10,368 --a--c--- C:\WINDOWS\system32\dllcache\hidusb.sys
2008-09-24 15:15 . 2008-05-01 16:38 331,776 -----c--- C:\WINDOWS\system32\dllcache\msadce.dll
2008-09-24 15:15 . 2008-05-08 16:02 203,136 -----c--- C:\WINDOWS\system32\dllcache\rmcast.sys
2008-09-24 15:14 . 2008-09-24 15:14 <DIR> d-------- C:\Documents and Settings\19020KEBA\Programdata\ATI
2008-09-24 15:14 . 2008-09-24 15:14 <DIR> d-------- C:\Documents and Settings\19020KEBA\Bluetooth Software
2008-09-24 15:13 . 2008-09-24 15:13 <DIR> d--h----- C:\WINDOWS\system32\GroupPolicy
2008-09-24 15:13 . 2008-09-29 14:50 <DIR> dr------- C:\Documents and Settings\19020KEBA\Start-meny
2008-09-24 15:13 . 2007-10-13 17:24 <DIR> d--h----- C:\Documents and Settings\19020KEBA\Skrivere
2008-09-24 15:13 . 2008-09-29 20:55 <DIR> d-------- C:\Documents and Settings\19020KEBA\Skrivebord
2008-09-24 15:13 . 2008-09-29 20:55 <DIR> dr-h----- C:\Documents and Settings\19020KEBA\Programdata
2008-09-24 15:13 . 2008-09-28 16:45 <DIR> dr------- C:\Documents and Settings\19020KEBA\Mine dokumenter
2008-09-24 15:13 . 2007-10-13 15:43 <DIR> d--h----- C:\Documents and Settings\19020KEBA\Maler
2008-09-24 15:13 . 2008-09-29 20:55 <DIR> d--h----- C:\Documents and Settings\19020KEBA\Lokale innstillinger
2008-09-24 15:13 . 2008-09-29 20:17 <DIR> dr------- C:\Documents and Settings\19020KEBA\Favoritter
2008-09-24 15:13 . 2007-10-13 17:24 <DIR> d--h----- C:\Documents and Settings\19020KEBA\AndrMask
2008-09-24 15:13 . 2008-09-29 16:07 <DIR> d-------- C:\Documents and Settings\19020KEBA
2008-09-24 13:54 . 2008-04-11 21:06 691,712 -----c--- C:\WINDOWS\system32\dllcache\inetcomm.dll
2008-09-24 13:51 . 2008-09-24 13:51 7,836 --a------ C:\WINDOWS\cfgall.ini
2008-09-24 13:49 . 2008-09-24 13:49 <DIR> d-------- C:\Programfiler\Trend Micro
2008-09-24 13:49 . 2008-09-24 13:49 21 --a------ C:\tmuninst.ini
2008-09-24 13:48 . 2008-09-24 13:48 <DIR> d-------- C:\Documents and Settings\19020admin\Bluetooth Software
2008-09-24 13:34 . 2008-07-18 22:07 270,880 --a------ C:\WINDOWS\system32\mucltui.dll
2008-09-24 13:34 . 2008-07-18 22:07 210,976 --a------ C:\WINDOWS\system32\muweb.dll
2008-09-24 13:34 . 2008-07-18 22:07 29,728 --a------ C:\WINDOWS\system32\mucltui.dll.mui
2008-09-01 14:48 . 2004-08-04 01:03 221,184 --a------ C:\WINDOWS\system32\wmpns.dll
2008-09-01 14:42 . 2008-09-01 14:42 <DIR> d-------- C:\WINDOWS\ServicePackFiles
2008-09-01 14:39 . 2006-12-28 12:01 19,569 --a------ C:\WINDOWS\000001_.tmp
2008-09-01 13:28 . 2008-09-01 13:28 <DIR> d--hs---- C:\found.000
(((((((((((((((((((((((((((((((((((((((( Find3M Report ))))))))))))))))))))))))))))))))))))))))))))))))))))
2008-09-25 01:08 --------- d-----w C:\Documents and Settings\All Users\Programdata\Microsoft Help
2008-09-24 14:21 --------- d-----w C:\Programfiler\Java
2008-07-18 20:10 94,920 ----a-w C:\WINDOWS\system32\cdm.dll
2008-07-18 20:10 53,448 ----a-w C:\WINDOWS\system32\wuauclt.exe
2008-07-18 20:10 45,768 ----a-w C:\WINDOWS\system32\wups2.dll
2008-07-18 20:10 36,552 ----a-w C:\WINDOWS\system32\wups.dll
2008-07-18 20:09 563,912 ----a-w C:\WINDOWS\system32\wuapi.dll
2008-07-18 20:09 325,832 ----a-w C:\WINDOWS\system32\wucltui.dll
2008-07-18 20:09 205,000 ----a-w C:\WINDOWS\system32\wuweb.dll
2008-07-18 20:09 1,811,656 ----a-w C:\WINDOWS\system32\wuaueng.dll
2008-07-07 20:29 253,952 ----a-w C:\WINDOWS\system32\es.dll
((((((((((((((((((((((((((((((((((((( Reg Loading Points ))))))))))))))))))))))))))))))))))))))))))))))))))
*Note* empty entries & legit default entries are not shown
REGEDIT4
[HKEY_CURRENT_USER\SOFTWARE\Microsoft\Windows\CurrentVersion\Run]
"ctfmon.exe"="C:\WINDOWS\system32\ctfmon.exe" [2008-04-14 15360]
"MsnMsgr"="C:\Programfiler\Windows Live\Messenger\MsnMsgr.Exe" [2007-10-18 5724184]
"Steam"="C:\Programfiler\Steam\Steam.exe" [2008-09-28 1271032]
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Run]
"hpWirelessAssistant"="C:\Programfiler\Hewlett-Packard\HP Wireless Assistant\HPWAMain.exe" [2007-01-10 472776]
"QlbCtrl"="C:\Programfiler\Hewlett-Packard\HP Quick Launch Buttons\QlbCtrl.exe" [2007-05-07 159744]
"SynTPEnh"="C:\Programfiler\Synaptics\SynTP\SynTPEnh.exe" [2007-06-07 827392]
"StartCCC"="C:\Programfiler\ATI Technologies\ATI.ACE\Core-Static\CLIStart.exe" [2006-11-10 90112]
"AccelerometerSysTrayApplet"="C:\WINDOWS\system32\AccelerometerSt.exe" [2007-01-24 124928]
"SoundMAXPnP"="C:\Programfiler\Analog Devices\Core\smax4pnp.exe" [2007-01-05 872448]
"SunJavaUpdateSched"="C:\Programfiler\Java\jre1.6.0_07\bin\jusched.exe" [2008-06-10 144784]
"Adobe Reader Speed Launcher"="C:\Programfiler\Adobe\Reader 8.0\Reader\Reader_sl.exe" [2007-05-11 40048]
"OfficeScanNT Monitor"="C:\Programfiler\Trend Micro\OfficeScan Client\pccntmon.exe" [2006-02-07 356352]
"AVG8_TRAY"="C:\PROGRA~1\AVG\AVG8\avgtray.exe" [2008-09-29 1172760]
C:\Documents and Settings\All Users\Start-meny\Programmer\Oppstart\
BTTray.lnk - C:\Programfiler\WIDCOMM\Bluetooth Software\BTTray.exe [2007-02-06 561213]
Microsoft Firewall Client Management.lnk - C:\Programfiler\Microsoft Firewall Client 2004\FwcMgmt.exe [2006-12-09 117568]
[HKEY_LOCAL_MACHINE\software\microsoft\windows nt\currentversion\windows]
"AppInit_DLLs"=avgrsstx.dll
[HKEY_LOCAL_MACHINE\software\microsoft\windows\currentversion\group policy\state\Machine\Scripts\Startup\0\0]
"Script"=Startup.bat
[HKEY_LOCAL_MACHINE\software\microsoft\windows\currentversion\group policy\state\S-1-5-21-3799992752-535036049-2774849586-51603\Scripts\Logon\0\0]
"Script"=PushPrinterConnections.exe
[HKLM\~\services\sharedaccess\parameters\firewallpolicy\standardprofile\AuthorizedApplications\List]
"%windir%\\system32\\sessmgr.exe"=
"%windir%\\Network Diagnostic\\xpnetdiag.exe"=
"C:\\Programfiler\\uTorrent\\uTorrent.exe"=
"C:\\Programfiler\\World of Warcraft\\BackgroundDownloader.exe"=
"C:\\Programfiler\\AVG\\AVG8\\avgupd.exe"=
"C:\\Programfiler\\AVG\\AVG8\\avgnsx.exe"=
"C:\\Programfiler\\Windows Live\\Messenger\\msnmsgr.exe"=
"C:\\Programfiler\\Windows Live\\Messenger\\livecall.exe"=
[HKLM\~\services\sharedaccess\parameters\firewallpolicy\standardprofile\GloballyOpenPorts\List]
"3724:TCP"= 3724:TCP:Blizzard Downloader: 3724
R0 AvgRkx86;avgrkx86.sys;C:\WINDOWS\system32\Drivers\avgrkx86.sys [2008-09-29 12424]
R1 AvgLdx86;AVG AVI Loader Driver x86;C:\WINDOWS\system32\Drivers\avgldx86.sys [2008-09-29 96520]
R2 avg8wd;AVG8 WatchDog;C:\PROGRA~1\AVG\AVG8\avgwdsvc.exe [2008-09-29 282904]
R2 AvgTdiX;AVG8 Network Redirector;C:\WINDOWS\system32\Drivers\avgtdix.sys [2008-09-29 75272]
R2 FwcAgent;Firewall Client Agent;C:\Programfiler\Microsoft Firewall Client 2004\FwcAgent.exe [2006-12-09 128832]
R2 NMSAccessU;NMSAccessU;C:\Programfiler\CDBurnerXP\NMSAccessU.exe [2007-05-04 71360]
R2 SWIHPWMI;SWIHPWMI;C:\Programfiler\HPQ\Shared\Sierra Wireless\Win32\Unicode\SWIHPWMI.exe [2006-12-04 292384]
R3 IFXTPM;IFXTPM;C:\WINDOWS\system32\DRIVERS\IFXTPM.SYS [2007-01-23 36608]
S3 HP24X;HP PC Card Smart Card Reader;C:\WINDOWS\system32\DRIVERS\HP24X.sys [2006-10-19 33024]
- - - - ORPHANS REMOVED - - - -
BHO-{602F6418-A62C-4992-93C6-A0E1AD4B670A} - C:\WINDOWS\system32\vtUmMgEW.dll
BHO-{7B091D1B-AF42-4EA3-8FF5-3ADB46FE8DAE} - C:\WINDOWS\system32\byxYrQKC.dll
BHO-{F07C2B06-FF81-4EB8-8AB9-7620A24309FD} - C:\WINDOWS\dfmlxbpkvkd.dll
Toolbar-{59B4236E-2A39-4942-8278-980630D6D26F} - C:\WINDOWS\peltodgx.dll
HKCU-Run-\YUR1.exe - C:\Windows\system32\YUR1.exe
HKCU-Run-\YUR2.exe - C:\Windows\system32\YUR2.exe
HKCU-Run-\YUR3.exe - C:\Windows\system32\YUR3.exe
HKCU-Run-\YUR4.exe - C:\Windows\system32\YUR4.exe
HKLM-Run-\YURF1.exe - C:\Windows\system32\YURF1.exe
HKLM-Run-\YURF2.exe - C:\Windows\system32\YURF2.exe
HKLM-Run-\YURF3.exe - C:\Windows\system32\YURF3.exe
HKLM-Run-\YURF4.exe - C:\Windows\system32\YURF4.exe
HKLM-Run-ANTIVIRUS - C:\Programfiler\MicroAV\MicroAV.exe
HKLM-Run-\YUR1.exe - C:\Windows\system32\YUR1.exe
HKLM-Run-\YUR2.exe - C:\Windows\system32\YUR2.exe
HKLM-Run-\YUR3.exe - C:\Windows\system32\YUR3.exe
HKLM-Run-\YUR4.exe - C:\Windows\system32\YUR4.exe
ShellExecuteHooks-{7B091D1B-AF42-4EA3-8FF5-3ADB46FE8DAE} - C:\WINDOWS\system32\byxYrQKC.dll
------- Supplementary Scan -------
FireFox -: Profile - C:\Documents and Settings\19020KEBA\Programdata\Mozilla\Firefox\Profiles\rncgrdmz.default\
catchme 0.3.1361 W2K/XP/Vista - rootkit/stealth malware detector by Gmer, http://www.gmer.net
Rootkit scan 2008-09-29 20:55:55
Windows 5.1.2600 Service Pack 3 NTFS
scanning hidden processes ...
scanning hidden autostart entries ...
scanning hidden files ...
scan completed successfully
hidden files: 0
Completion time: 2008-09-29 20:57:11
ComboFix-quarantined-files.txt 2008-09-29 18:57:07
Pre-Run: 48,156,323,840 byte ledig
Post-Run: 48,140,226,560 byte ledig
215 --- E O F --- 2008-09-25 01:08:18
Kjør gjennom resten av veiledningen i følgende tråd: https://www.diskusjon.no/index.php?showtopic=691246
Loggene poste du her i din egen tråd, så ser vi om det er noe som må fjerne manuelt etterpå.
HijackThis Log:
Logfile of Trend Micro HijackThis v2.0.2
Scan saved at 21:42, on 2008-09-30
Platform: Windows XP SP3 (WinNT 5.01.2600)
MSIE: Internet Explorer v7.00 (7.00.6000.16705)
Boot mode: Normal
Running processes:
C:\WINDOWS\System32\smss.exe
C:\WINDOWS\system32\winlogon.exe
C:\WINDOWS\system32\services.exe
C:\WINDOWS\system32\lsass.exe
C:\WINDOWS\system32\Ati2evxx.exe
C:\WINDOWS\system32\svchost.exe
C:\WINDOWS\System32\svchost.exe
C:\Programfiler\WIDCOMM\Bluetooth Software\bin\btwdins.exe
C:\WINDOWS\system32\spoolsv.exe
C:\WINDOWS\system32\agrsmsvc.exe
C:\WINDOWS\system32\drivers\CDAC11BA.EXE
C:\Programfiler\Fellesfiler\Microsoft Shared\VS7DEBUG\mdm.exe
C:\Programfiler\Trend Micro\OfficeScan Client\ntrtscan.exe
C:\PROGRA~1\AVG\AVG8\avgam.exe
C:\Programfiler\Trend Micro\OfficeScan Client\tmlisten.exe
C:\PROGRA~1\AVG\AVG8\avgnsx.exe
C:\Programfiler\Hewlett-Packard\Shared\hpqwmiex.exe
C:\Programfiler\Trend Micro\OfficeScan Client\OfcPfwSvc.exe
C:\Programfiler\ATI Technologies\ATI.ACE\Core-Static\MOM.EXE
C:\PROGRA~1\HEWLET~1\Shared\HPQTOA~1.EXE
C:\PROGRA~1\WIDCOMM\BLUETO~1\BTSTAC~1.EXE
C:\Programfiler\ATI Technologies\ATI.ACE\Core-Static\ccc.exe
C:\WINDOWS\explorer.exe
C:\Programfiler\Windows Media Player\wmplayer.exe
C:\Programfiler\AVG\AVG8\avgrsx.exe
C:\Programfiler\Mozilla Firefox\firefox.exe
C:\Programfiler\Malwarebytes' Anti-Malware\mbam.exe
C:\Programfiler\Trend Micro\HijackThis\HijackThis.exe
R0 - HKCU\Software\Microsoft\Internet Explorer\Main,Start Page = http://softwarereferral.com/jump.php?wmid=...6Ojg5&lid=2
R1 - HKLM\Software\Microsoft\Internet Explorer\Main,Default_Page_URL = http://go.microsoft.com/fwlink/?LinkId=69157
R1 - HKLM\Software\Microsoft\Internet Explorer\Main,Default_Search_URL = http://go.microsoft.com/fwlink/?LinkId=54896
R1 - HKLM\Software\Microsoft\Internet Explorer\Main,Search Page = http://go.microsoft.com/fwlink/?LinkId=54896
R0 - HKLM\Software\Microsoft\Internet Explorer\Main,Start Page = http://go.microsoft.com/fwlink/?LinkId=69157
R1 - HKCU\Software\Microsoft\Internet Connection Wizard,ShellNext = http://go.microsoft.com/fwlink/?LinkId=74005
R1 - HKCU\Software\Microsoft\Windows\CurrentVersion\Internet Settings,ProxyServer = 10.8.1.2:8080
R0 - HKCU\Software\Microsoft\Internet Explorer\Toolbar,LinksFolderName = Koblinger
O2 - BHO: Koblingshjelpeprogram for Adobe PDF Reader - {06849E9F-C8D7-4D59-B87D-784B7D6BE0B3} - C:\Programfiler\Fellesfiler\Adobe\Acrobat\ActiveX\AcroIEHelper.dll
O2 - BHO: WormRadar.com IESiteBlocker.NavFilter - {3CA2F312-6F6E-4B53-A66E-4E65E497C8C0} - C:\Programfiler\AVG\AVG8\avgssie.dll
O2 - BHO: SSVHelper Class - {761497BB-D6F0-462C-B6EB-D4DAF1D92D43} - C:\Programfiler\Java\jre1.6.0_07\bin\ssv.dll
O2 - BHO: (no name) - {7E853D72-626A-48EC-A868-BA8D5E23E045} - (no file)
O4 - HKLM\..\Run: [hpWirelessAssistant] %ProgramFiles%\Hewlett-Packard\HP Wireless Assistant\HPWAMain.exe
O4 - HKLM\..\Run: [QlbCtrl] %ProgramFiles%\Hewlett-Packard\HP Quick Launch Buttons\QlbCtrl.exe /Start
O4 - HKLM\..\Run: [synTPEnh] C:\Programfiler\Synaptics\SynTP\SynTPEnh.exe
O4 - HKLM\..\Run: [startCCC] C:\Programfiler\ATI Technologies\ATI.ACE\Core-Static\CLIStart.exe
O4 - HKLM\..\Run: [AccelerometerSysTrayApplet] C:\WINDOWS\system32\AccelerometerSt.exe
O4 - HKLM\..\Run: [soundMAXPnP] C:\Programfiler\Analog Devices\Core\smax4pnp.exe
O4 - HKLM\..\Run: [sunJavaUpdateSched] "C:\Programfiler\Java\jre1.6.0_07\bin\jusched.exe"
O4 - HKLM\..\Run: [Adobe Reader Speed Launcher] "C:\Programfiler\Adobe\Reader 8.0\Reader\Reader_sl.exe"
O4 - HKLM\..\Run: [OfficeScanNT Monitor] "C:\Programfiler\Trend Micro\OfficeScan Client\pccntmon.exe" -HideWindow
O4 - HKLM\..\Run: [AVG8_TRAY] C:\PROGRA~1\AVG\AVG8\avgtray.exe
O4 - HKCU\..\Run: [ctfmon.exe] C:\WINDOWS\system32\ctfmon.exe
O4 - HKCU\..\Run: [MsnMsgr] "C:\Programfiler\Windows Live\Messenger\MsnMsgr.Exe" /background
O4 - HKCU\..\Run: [steam] "C:\Programfiler\Steam\Steam.exe" -silent
O4 - Global Startup: BTTray.lnk = ?
O4 - Global Startup: Microsoft Firewall Client Management.lnk = C:\Programfiler\Microsoft Firewall Client 2004\FwcMgmt.exe
O8 - Extra context menu item: E&ksporter til Microsoft Excel - res://C:\PROGRA~1\MICROS~3\Office12\EXCEL.EXE/3000
O8 - Extra context menu item: Send til &Bluetooth-enhet... - C:\Programfiler\WIDCOMM\Bluetooth Software\btsendto_ie_ctx.htm
O9 - Extra button: (no name) - {08B0E5C0-4FCB-11CF-AAA5-00401C608501} - C:\Programfiler\Java\jre1.6.0_07\bin\ssv.dll
O9 - Extra 'Tools' menuitem: Sun Java Console - {08B0E5C0-4FCB-11CF-AAA5-00401C608501} - C:\Programfiler\Java\jre1.6.0_07\bin\ssv.dll
O9 - Extra button: Research - {92780B25-18CC-41C8-B9BE-3C9C571A8263} - C:\PROGRA~1\MICROS~3\Office12\REFIEBAR.DLL
O9 - Extra button: @btrez.dll,-4015 - {CCA281CA-C863-46ef-9331-5C8D4460577F} - C:\Programfiler\WIDCOMM\Bluetooth Software\btsendto_ie.htm
O9 - Extra 'Tools' menuitem: @btrez.dll,-12650 - {CCA281CA-C863-46ef-9331-5C8D4460577F} - C:\Programfiler\WIDCOMM\Bluetooth Software\btsendto_ie.htm
O9 - Extra button: Messenger - {FB5F1910-F110-11d2-BB9E-00C04F795683} - C:\Programfiler\Messenger\msmsgs.exe
O9 - Extra 'Tools' menuitem: Windows Messenger - {FB5F1910-F110-11d2-BB9E-00C04F795683} - C:\Programfiler\Messenger\msmsgs.exe
O16 - DPF: {00134F72-5284-44F7-95A8-52A619F70751} (ObjWinNTCheck Class) - https://sjvgs-fs2:4343/officescan/console/C...ll/WinNTChk.cab
O16 - DPF: {08D75BB0-D2B5-11D1-88FC-0080C859833B} (OfficeScan Corp Edition Web-Deployment SetupINICtrl Class) - https://sjvgs-fs2:4343/officescan/console/C...ll/setupini.cab
O16 - DPF: {08D75BC1-D2B5-11D1-88FC-0080C859833B} (OfficeScan Corp Edition Web-Deployment SetupCtrl Class) - https://sjvgs-fs2:4343/officescan/console/C...stall/setup.cab
O16 - DPF: {35C3D91E-401A-4E45-88A5-F3B32CD72DF4} (Encrypt Class) - https://sjvgs-fs2:4343/officescan/console/html/AtxEnc.cab
O16 - DPF: {5EFE8CB1-D095-11D1-88FC-0080C859833B} (OfficeScan Corp Edition Web-Deployment ObjRemoveCtrl Class) - https://sjvgs-fs2:4343/officescan/console/C.../RemoveCtrl.cab
O16 - DPF: {6414512B-B978-451D-A0D8-FCFDF33E833C} (WUWebControl Class) - http://www.update.microsoft.com/windowsupd...b?1192283903578
O17 - HKLM\System\CCS\Services\Tcpip\Parameters: Domain = skole.troms.vgs.no
O17 - HKLM\Software\..\Telephony: DomainName = skole.troms.vgs.no
O17 - HKLM\System\CS1\Services\Tcpip\Parameters: Domain = skole.troms.vgs.no
O18 - Protocol: linkscanner - {F274614C-63F8-47D5-A4D1-FBDDE494F8D1} - C:\Programfiler\AVG\AVG8\avgpp.dll
O20 - AppInit_DLLs: avgrsstx.dll
O23 - Service: Agere Modem Call Progress Audio (AgereModemAudio) - Agere Systems - C:\WINDOWS\system32\agrsmsvc.exe
O23 - Service: Ati HotKey Poller - ATI Technologies Inc. - C:\WINDOWS\system32\Ati2evxx.exe
O23 - Service: AVG8 WatchDog (avg8wd) - AVG Technologies CZ, s.r.o. - C:\PROGRA~1\AVG\AVG8\avgwdsvc.exe
O23 - Service: Bluetooth Service (btwdins) - Broadcom Corporation. - C:\Programfiler\WIDCOMM\Bluetooth Software\bin\btwdins.exe
O23 - Service: C-DillaCdaC11BA - Macrovision - C:\WINDOWS\system32\drivers\CDAC11BA.EXE
O23 - Service: hpqwmiex - Hewlett-Packard Development Company, L.P. - C:\Programfiler\Hewlett-Packard\Shared\hpqwmiex.exe
O23 - Service: NMSAccessU - Unknown owner - C:\Programfiler\CDBurnerXP\NMSAccessU.exe
O23 - Service: OfficeScanNT RealTime Scan (ntrtscan) - Trend Micro Inc. - C:\Programfiler\Trend Micro\OfficeScan Client\ntrtscan.exe
O23 - Service: OfficeScanNT Personal Firewall (OfcPfwSvc) - Trend Micro Inc. - C:\Programfiler\Trend Micro\OfficeScan Client\OfcPfwSvc.exe
O23 - Service: SWIHPWMI - Sierra Wireless Inc. - C:\Programfiler\HPQ\Shared\Sierra Wireless\Win32\Unicode\SWIHPWMI.exe
O23 - Service: OfficeScanNT Listener (tmlisten) - Trend Micro Inc. - C:\Programfiler\Trend Micro\OfficeScan Client\tmlisten.exe
End of file - 8766 bytes
Mbam Log:
Malwarebytes' Anti-Malware 1.28
Database versjon: 1225
2008-09-30 21:50:38
mbam-log-2008-09-30 (21-50-38).txt
Skanntype: Rask Skann
Objekter skannet: 49250
Tid tilbakelagt: 5 minute(s), 13 second(s)
Minneprosesser infisert: 0
Minnemoduler infisert: 0
Registernøkler infisert: 4
Registerverdier infisert: 0
Registerfiler infisert: 2
Mapper infisert: 0
Filer infisert: 2
(Ingen mistenkelige filer funnet)
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\contim (Trojan.Vundo) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\peltodgx.bxfa (Trojan.FakeAlert) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\peltodgx.toolbar.1 (Trojan.FakeAlert) -> Quarantined and deleted successfully.
HKEY_CURRENT_USER\SOFTWARE\MicroAV (Rogue.MicroAntivirus) -> Quarantined and deleted successfully.
HKEY_CURRENT_USER\SOFTWARE\Microsoft\Internet Explorer\Main\Start Page (Hijack.Homepage) -> Bad: (http://softwarereferral.com/jump.php?wmid=6010&mid=MjI6Ojg5&lid=2) Good: (http://www.google.com/) -> Quarantined and deleted successfully.
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\ProductId (Trojan.FakeAlert) -> Bad: (VIRUS ALERT!) Good: (55274-640-1058016-23654) -> Quarantined and deleted successfully.
Mapper infisert:
Filer infisert:
C:\WINDOWS\system32\akrbxkbb.dll (Trojan.Vundo) -> Quarantined and deleted successfully.
C:\WINDOWS\fbxrqtwn.exe (Trojan.FakeAlert) -> Quarantined and deleted successfully.
Så en ny combofix-logg :)
Hær er en ny log:
ComboFix 08-09-30.01 - 19020KEBA 2008-09-30 22:24:42.3 - NTFSx86
Microsoft Windows XP Professional 5.1.2600.3.1252.1.1044.18.1285 [GMT 2:00]
* Created a new restore point
((((((((((((((((((((((((( Files Created from 2008-08-28 to 2008-09-30 )))))))))))))))))))))))))))))))
2008-09-30 21:36 . 2008-09-30 21:36 <DIR> d-------- C:\Programfiler\Malwarebytes' Anti-Malware
2008-09-30 21:36 . 2008-09-30 21:36 <DIR> d-------- C:\Documents and Settings\All Users\Programdata\Malwarebytes
2008-09-30 21:36 . 2008-09-30 21:36 <DIR> d-------- C:\Documents and Settings\19020KEBA\Programdata\Malwarebytes
2008-09-30 21:36 . 2008-09-10 00:04 38,528 --a------ C:\WINDOWS\system32\drivers\mbamswissarmy.sys
2008-09-30 21:36 . 2008-09-10 00:03 17,200 --a------ C:\WINDOWS\system32\drivers\mbam.sys
2008-09-29 16:07 . 2008-09-29 21:57 <DIR> dr-h----- C:\Documents and Settings\19020KEBA\Siste
2008-09-29 16:00 . 2008-09-29 21:24 <DIR> d--h----- C:\$AVG8.VAULT$
2008-09-29 15:15 . 2008-09-30 21:45 <DIR> d-------- C:\WINDOWS\system32\drivers\Avg
2008-09-28 20:53 . 2008-09-30 21:55 <DIR> d-------- C:\Programfiler\Steam
2008-09-24 15:13 . 2008-09-30 22:23 <DIR> d-------- C:\Documents and Settings\19020KEBA\Skrivebord
2008-09-24 15:13 . 2008-09-30 21:36 <DIR> dr-h----- C:\Documents and Settings\19020KEBA\Programdata
2008-09-24 15:13 . 2008-09-30 22:26 <DIR> d--h----- C:\Documents and Settings\19020KEBA\Lokale innstillinger
2008-09-24 13:49 . 2008-09-30 21:39 <DIR> d-------- C:\Programfiler\Trend Micro
2008-06-24 16:46 74,240 ----a-w C:\WINDOWS\system32\mscms.dll
2008-06-24 16:12 295,936 ------w C:\WINDOWS\system32\wmpeffects.dll
2008-06-23 16:57 826,368 ----a-w C:\WINDOWS\system32\wininet.dll
2008-06-20 17:49 246,784 ----a-w C:\WINDOWS\system32\mswsock.dll
((((((((((((((((((((((((((((( snapshot@2008-09-29_20.56.40.28 )))))))))))))))))))))))))))))))))))))))))
- 2008-09-29 18:07:24 62,620 ----a-w C:\WINDOWS\system32\perfc009.dat
+ 2008-09-30 19:58:10 62,620 ----a-w C:\WINDOWS\system32\perfc009.dat
- 2008-09-29 18:07:24 71,120 ----a-w C:\WINDOWS\system32\perfc014.dat
+ 2008-09-30 19:58:10 71,120 ----a-w C:\WINDOWS\system32\perfc014.dat
- 2008-09-29 18:07:24 400,958 ----a-w C:\WINDOWS\system32\perfh009.dat
+ 2008-09-30 19:58:10 400,958 ----a-w C:\WINDOWS\system32\perfh009.dat
- 2008-09-29 18:07:24 405,032 ----a-w C:\WINDOWS\system32\perfh014.dat
+ 2008-09-30 19:58:10 405,032 ----a-w C:\WINDOWS\system32\perfh014.dat
REGEDIT4
Rootkit scan 2008-09-30 22:26:57
hidden files: 0
Completion time: 2008-09-30 22:28:22
ComboFix-quarantined-files.txt 2008-09-30 20:28:12
ComboFix2.txt 2008-09-29 18:57:13
Pre-Run: 48,063,283,200 byte ledig
Post-Run: 48,052,600,832 byte ledig
180 --- E O F --- 2008-09-25 01:08:18
Bruk utforsker til å finne og slette fila: C:\WINDOWS\000001_.tmp
Det kan se ut som om du kjører med 2 antivirusprog (AVG og Trend Micro). Bestem deg for ett av dem og avinstaller det andre.
Loggen din ser for øvrig grei ut. Kjører pc'n ok?
Hvis, så kan du fjerne combofix ved å skrive combofix /u i kjør-feltet (start->kjør)
Dette vil også nullstille systemgjenopprettingen slik at du ikke blir infisert ved en evt. gjenoppretting senere.
