XFX 8800gtx har HDCP?
Scrubs
8800 GTX 768MB (575/1350/1800) (13.8/86.4) (PCIe) 384-bit HDCP D-DLDVI
HDCP (High-Bandwidth Digital Content Protection)
This is a DRM (Digital Rights Management) technology which currently is being used by HD-DVD and Blu-Ray movies. The movie industry thinks this will reduce piracy but it makes it a lot harder for people to back-up their originals.
You need a video card and monitor/HDTV which are both HDCP ready if you want to use digital connections (HDMI, DVI).
Analogue connections have currently no such limitations since ICT (Image Constraint Token) is not yet implemented – when it’s (2009 or even as late as 2012) the resolution will be reduced to 540p or not allowed at all. It should be noted that AACS (Advanced Access Content System) don’t allow component to transfer more than a maximum 1080i - VGA on the other hand has no such restrictions.
Så lenge skjermen din ikke bruker oppløsningen 2560x1600 (krever dual-link HDCP, noe 8800 GTX ikke har) har du ikke noe å beskymre deg over når du ser Blu-ray/HD-DVD filmer.
Edit
HDCP har ingen betydning hvis du ikke bruker PC-en til å se Blu-ray/HD-DVD filmer.
Endret av guezz
