Warhammer online crasher
Hei! Jeg har fått noen problemer med at Warhammer crasher etter rundt et kvarter.
Enten så crasher den til desktop, eller så får den PCen til å klikke fullstendig så jeg må restarte.
Dette er litt frustrerende så jeg lurte på om noen har noen løsninger;)
MVH Privinius
Endret av privinius
Du er ikke alene ;)
Tusenvis av andre lider din skjebne (inkludert meg), og det finnes flere tips ute på nettet, men jeg har ikke funnet en eneste ting som fikser problemet. :hmm:
Hentet fra FAQ på warhammeralliance.com:
3.4 - Windows Crashes or Freezes while playing the game, or game exits without warning. Black screen crashes.
Updating your onboard sound device drivers has been known to solve this issue (get your drivers direct not just from the oem/motherboard manufacturer, check 3.2 for more info). Try disabling (not just closing but actually disabling it) your security suite as well to see if that might be contributing to it. Try the solutions in 3.2/3.3.
In Vista try to disable display scaling on high DPI settings. Right click WAR shortcut- Properties- Compatibility- Disable display scaling on high DPI settings (change it back if this doesn't work). - Thanks Orangeheaven!
Nforce motherboards seem to cause crashes and network instability in this game when using the built in network card because it shares the same irq as one or some of the sata ports. Can try moving your harddrive to the other ports I believe ports 1&2 share the same ports or maybe it was 3&4 ? Also try removing the hardware firewall by uninstalling network access manager. This doesn't always work though so you might need to completely remove and reinstall your motherboard drivers and selecting custom install and making sure not to install the firewall and network manager. Also don't use teaming/firstpacket if that available on your model.
Nvidia 9600gt: There is a major problem with quite a few revisions of this card which causes a black screen of death crash after a little while playing. You may need to rma your card, please see your manufacturer's homepage for support.
Du kan jo prøve noe av dette, og hvis resultatet uteblir, er det bare å smøre seg med tolmodighet og vente på at Mythic finner en løsning på problemet. Etter at jeg prøvde tips nr to har jeg forresten merket at blackscreenen kommer sjeldnere. Det er et enkelt grep, og definitivt vert å prøve. (hvis du har vista da)
Ellers kan du jo lete litt på http://www.warhammeralliance.com/forums/fo...splay.php?f=129 og se om du kan plukke opp noen tips.
Har hendt meg et par ganger nå at spillet bare krasjer, og siden jeg har Vista får jeg opp problemet. Og feilmeldingen er at skjermkort driverene slutter å virke...
Vet ikke om det gjelder for dere andre her, men det kan virke som om det er en bug i WAR.
Får bare håpe det kommer nye skjermkortdrivere snart :)
Har ATI mobility 2600 XT med catalyst 8.8 drivere.
