script for å dokumentere instillinger på servere
Har forsøkt å prøve å få dokumentasjonsarbeidet på ulike servere så automatisert som mulig. Her er ett script jeg har kommet opp med. Forslag til tillegg/endringer er hjertelig velkomne!
cd\
echo off
echo http://www.techotopia.com/index.php/Window...mand-line_Tools
echo ########################################
echo -
echo Hostname
echo Display the computer name.
hostname
echo -
echo Date
date /t
echo -
echo Ver
echo "displays Windows version"
ver
echo -
echo Nbtstat
echo Display status of NetBIOS.
Nbtstat -n
echo -
echo ipconfig /all
echo print outs the tcp/ip settings
ipconfig /all
echo -
echo getmac
echo prints mac adress
getmac
echo -
echo Systeminfo
echo Display machine properties and configuration.
Systeminfo
echo -
echo Tasklist
echo Display currently running tasks and services.
Tasklist
echo -
echo WMI
echo Display WMI information.
echo must have wmi command installed (maybe resource disk?)
echo -
echo Set
echo Display or modify Windows environment variables. Also used to evaluate numeric expressions at the command line
Set
echo -
echo Route print
echo Manage network routing tables.
route print
echo -
echo net view
echo shares on this computer
net view
echo -
echo Net Localgroup
echo Display or manage local group accounts.
net localgroup
echo -
echo Net Accounts
echo Manage user account and password policies.
Net Accounts
echo
echo Net user
echo Local user(s)
Net user
echo -
echo Net Config Server
echo Display or modify configuration of Server service.
Net Config Server
echo -
echo Net Config Workstation
echo Display or modify configuration of Workstation service.
echo -
echo Gpresult /R
echo Displays RSoP summary data.
Gpresult /R
echo -
echo Driverquery
echo Display the current device driver properties and status.
Driverquery
echo -
echo Chkntfs
echo Display the status of volumes. Set or exclude volumes from automatic system checking during system boot.
Chkntfs C:
echo -
echo Chcp
echo Display or set the active code page number.
Chcp
echo -
echo serverManagerCmd.exe -query
echo list all server roles (only on Windows 2008 SERVER)
echo the version of serverManagerCmd.exe
serverManagerCmd.exe -v
echo -
echo sc query type= service state= all
echo lister alle tjenster som er installert, både aktive og passive.
echo -
echo bootcfg /query
echo queries computers Boot.ini file settings.
bootcfg /query
echo -
echo Vol
echo displays label and serial no. of c: drive
vol
echo -
echo tree c:\ /f
echo "lists the three-structure of the c: drive"
tree c:\ /f
echo ###########EOF - END OF FILE###################
Lurer på hvilke konkrete servere som scriptet dokumenterer. Alle programmer er jo ikke servere. Bare dem som yter tjenester til andre programmer og dets brukere defineres vanligvis som servere. Videre er der litt rusk i scriptet, for eksempel: echo Display currently running tasks and services. I task mangers prosessvindu kommer vel ikke opp aktive services vel?
Scripet skal dokumentere alle instillinger på en server på ett gitt tidspunkt. Brukes oftest i forkant av en større installasjon. Ofte er det flere administratorere som jobber opp mot samme server og det er fint å ha en slik dokumentasjon liggende for senere å spore endringer.
Som regel redirigerer jeg bare output til en fil noe slikt som
c:\dokumentasjons_script.bat > minserver.txt
- scriptet skal dokumentere de fleste servere som kjører i ett windows-miljø. Alt fra virtuelle servere på Vwware, citrix-servere, exchange, sql. Når det kommer til spesifikke instillinger på de ulike serverne (slik som f.eks exchange) tror jeg ikke det er formålstjenelig med script for å dokumenter. Her tror jeg man oftest blir nødt til å dokumentere oppsettet mer manuelt.
