Lastet ned MP3 med explorer.....
Hei!
Lastet ned noen MP3'er fra http://www.danhagen.net/Download.htm, men problemet er at når sangen kommer ned på maskinen kan jeg ikke spille den i winamp, men må først konvertere til MP3 før jeg kan spille den av... Om jeg laster ned med Opera kommer den som MP3 med det samme eller som "winamp media file."
Noen som vet hvordan jeg kan ordne dette i explorer?
Fant dette men det gir ikke noe svar: Har fjernet real player...
Why are the files are not saving as an mp3, Why are they not downloading completely, Why do the file keep opening in realplayer?
A few people have emailed me about the downloads not completing or the files saving as something other than mp3 (eg. mpeg). First, make sure that the comment next to the file doesn't specify that the file is something other than an mp3. There are a couple occasions where I will post a short movie file or an .asf file that was harvested from streaming audio or video. But the main reason for your problems are most likely on the user's end. Software incompatibilities or installations will set your defaults to the specifications of the software (eg. realplayer, AOL) which could in effect change file extension names or cause them to play only in the software which you installed. Also, those of you using the AOL browser for downloading are extremely prone to getting kicked off of servers for taking too long to complete the download.
