På tide å prøve LittleBigPlanet!
Gjest Slettet+981234789
Jeg finner ikke alle gosakene.
Jeg har funnet 60% i banen "Ta tak" og 95% i "Skate til seier"
Hvordan får jeg tak i resten?
Tror jeg har funnet ca. 85 % i de to, 100 % i den første. Har prøvd å finne walkthroughs på youtube osv, men finner ingenting.. Noen som vet hvor de "gjemte" skattene finnes?
Jeg fant løsningen på hvordan man får 100% på alle brettene på et annet forum.
First Level:
No secrets... no sticker unlocks... just run through the level...
be sure to replay it... and sticker the Boot/shoe... right after the first humpty dumpty... the its starts a race... and drops a bird down later in the level... which u need to ace it... JUMP to the bird... in the section where it forces you to commit suicide... this will make you ace the level... thus giving you the really cool PIRATE HOOK and EYE PATCH
Second Level:
This Level is tricky... i will of course leave out... all obvious unlocks... such as the ones you get just by running through the level... also make sure u ace the level... for pirate clothes
• First Spot: Use the R1 Block at the begging of the level... to jump to the buildings in the way back... this gets you some cool building stickers and then after using the star unlock you can get even more
• Second Spot: Use the Sticker unlock with the Teapot and Star to get these unlocks
• Third Spot: (Hard) Sorta drag the Horse to the top of the hill...
pass the first tree while riding down... then on the second tree jump off onto it... takes some time getting the timing right... so be patient... when on top use the star sticker to unlock stuff... then jump off to the right and get the one right below the tree of a face
• Fourth Spot: (HARD) Now on the Part where u learn how to TAP X to drag faster... after u beat that part u jump off into a path of points to a check point...
the tree and bush that the check point is on... is actually only on the 2nd level of play and u can go behind it... so head over to the gap between that bush/tree and go behind it for a unlock
• Fifth Spot: a lot later after u use the see-saws u get to the a platform... where there is a Star sticker unlock and a pile of bean/sack blocks... use them to jump over too the tree... get a few unlocks and use stickers to unlock the clouds (continue over to the clouds from the tree)
• Sixth Spot: (Ultra HARD) this is the one that had me lost for a bit... after getting the score challenge continue on toward the Decorations Tut... the lady who tells u how to do stuff... the one with a bird behind here... or w.e.... all you have to do is go BEHIND her to get the Unlock
• Seventh Spot: While Travailing down on the horse u pass a Star Sticker Unlock location... just after the race... go back and get it... not hard... just back track... make sure u finish before you go back so you can get the mushroom sticker with the help of the Horse
Third Level:
Same as before... i wont tell you the obvious ones...
also MAKE SURE you ace it... for a COOL PIRATE HAT
also to absolutly 100% you need another player
if you have no friends... play online
• First Spot: (HARD) Right When the Level Starts... head Left to a pile of tea cups... use the Sticker unlock and Drops down a couple of Unlock Bubbles yay... easy but lots of people miss it
• Second Spot: After the Falling bricks with the stickers on them... there is a spinning star at the bottom of that part of the level... just stick it and u get that unlock
• Third Spot: After using the bird make sure u go back to collect the two that were above and left of the spinning Water wheel... just use the other bird to swing over to it ...
• Fourth Spot: Make sure u get all the unlocks and sticker unlocks with the jet pack over to the left by the tree...
• Fifth Spot: Now travel past the ghosts and go up the first shoe... and the second one... get the sticker unlock by using the Lion the the Shield at the top of the second shoe... near the Score Challenge key and the ghost (who keeps trying to kill u when u try to use ure sticker LOL)
• Sixth Spot: then continue on... and get the Two person Challenge Stickers... by Each standing on one button for about 1 sec
• Seventh Spot: (hard) Travel up and use the shoe launch to get over to the part where u have to pull the path down... using a block.... there go all the way to the left... and jump forward... of the platform down onto another platform that you should have been able to see when u came up the two rising platforms where the ghost was...
get those two stickers and use the Sticker unlock... in the room to ure left... to get the rest
• Eighth Spot: (HARD) Use the skateboard ramp to travel down... finish the race... then backtrack where u went... there will be a couple of unlocks u missed... including two in a tree... keep going left... till u get to the giant Skate board ramp then go under it... keep going a long way till you get the the end... there is one unlock
That should 100% you
Selv etter guiden får jeg bare 98% i spøkelses banen, hvor er den siste?
First Level:
Second Level:
Third Level:
Har fulgt den flotte guiden nå, og ble ferdig med tredje bane nå nettopp.. men jeg har også "bare" 98 % på den!
Noen som kan hjelpe..?
Er veeeeldig irriterende å være 2 % fra 100 på Historie-modusen! :!:
Endret av Mokko
