På tide å prøve LittleBigPlanet!
Gjest Slettet+981234789
Amatørmessig..
Så du mener alle sidene må regne med at de får over 10 000 besøkende akuratt samtidig??
De burde skjønne at dette skulle komme til å skje..
og så? det er ikke slikt at de kjøper inn ekstra servere kun for noe slikt? Ikke spesielt ammatørmessig. Det skjer så og si over alt ved store annonseringer ol, gta 4 trailere ble sluppet ut flere enn rockstars sine sider gikk ned.. Overload skjer :)
UPDATE 2: Still working on the problem here (we apologize for the delay!), and we hope to have the contest up and running soon. The contest is not first come, first serve, so please refrain from mashing the Refresh button--it won't help you win a beta code.
NOTE: GamePro.com is the ONLY place you can register for entry into the LittleBigPlanet beta. Registering on BlogFaction sites (incuding GamePro Arcade and GameGirl) won't register you as a GamePro.com user (due to technical limitations). If you want to win a beta code, be sure to sign up on GamePro.com only. Any registration errors will be fixed today, and you'll have plenty of time to enter today to win. Thanks again for your patience.
