BSD/Unix(g) proftpd oppsett
Driver og setter opp en ftp server, og sliter med og få tilgang
vil også ha shh/tls samt fxp
ServerType standalone
DefaultServer on
Umask 022
ServerName "what.ever.com xxx.xxx.xxx.xxx"
ServerIdent on "Roger"
ServerAdmin [email protected]
IdentLookups off
UseReverseDNS off
Port 21212
PassivePorts 40402 40403
#MasqueradeAddress None
TimesGMT on
MaxInstances 30
MaxLoginAttempts 3
TimeoutLogin 300
TimeoutNoTransfer 120
TimeoutIdle 120
DisplayLogin welcome.msg
User nobody
Group nobody
DirFakeUser off Roger
DirFakeGroup off nobody
DefaultTransferMode binary
AllowForeignAddress on
AllowRetrieveRestart on
AllowStoreRestart on
DeleteAbortedStores off
TransferRate RETR 16000
TransferRate STOR 3200
TransferRate STOU 3200
TransferRate APPE 3200
SystemLog /var/log/secure
RequireValidShell off
#gp_random_username_length 6
#gp_random_password_length 10
#gp_randomize_case lower
#gp_useradd_homedir_path /home/ftp
#gp_html_path /var/www/html/ftp.htm
#gp_welcome_name welcome.msg
<IfModule mod_tls.c>
TLSEngine on
TLSRequired on
TLSVerifyClient on
TLSProtocol TLSv1
TLSLog /var/log/proftpd_tls.log
TLSRSACertificateFile /etc/gproftpd/gproftpd.pem
</IfModule>
<IfModule mod_ratio.c>
Ratios on
SaveRatios on
RatioFile "/restricted/proftpd_ratios"
RatioTempFile "/restricted/proftpd_ratios_temp"
CwdRatioMsg "Please upload first!"
FileRatioErrMsg "FileRatio limit exceeded, upload something first..."
ByteRatioErrMsg "ByteRatio limit exceeded, upload something first..."
LeechRatioMsg "Your ratio is unlimited."
</IfModule>
<Limit LOGIN>
AllowUser Test
DenyALL
</Limit>
<Anonymous /home/ftp/downloads>
User Test
Group user
AnonRequirePassword on
MaxClients 5 "The server is full, hosting %m users"
<Limit LOGIN>
Allow from all
Deny from all
</Limit>
AllowOverwrite off
AllowOverwrite on
<Limit LIST NLST STOR STOU APPE RETR RNFR RNTO DELE MKD XMKD SITE_MKDIR RMD XRMD SITE_RMDIR SITE SITE_CHMOD SITE_CHGRP MTDM PWD XPWD SIZE STAT CWD XCWD CDUP XCUP >
AllowAll
</Limit>
<Limit NOTHING >
DenyAll
</Limit>
</Anonymous>
TLSEngine on
TLSLog /var/ftpd/tls.log
TLSProtocol TLSv1
# Are clients required to use FTP over TLS when talking to this server?
TLSRequired on
# Server's certificate
TLSRSACertificateFile /etc/ftpcert/server.crt
TLSRSACertificateKeyFile /etc/ftpcert/server.key
# CA the server trusts
TLSCACertificateFile /etc/ftpcert/ca.crt
# Authenticate clients that want to use FTP over TLS?
TLSVerifyClient off
</IfModule>
TLSEngine on
TLSProtocol TLSv1
TLSRequired off
TLSRSACertificateFile /etc/ftpd/server.cert.pem
TLSRSACertificateKeyFile /etc/ftpd/server.key.pem
TLSCACertificateFile /etc/ftpd/root.cert.pem
TLSVerifyClient off
# Allow SSL/TLS renegotiations when the client requests them, but
# do not force the renegotations. Some clients do not support
# SSL/TLS renegotiations; when mod_tls forces a renegotiation, these
# clients will close the data connection, or there will be a timeout
# on an idle data connection.
TLSRenegotiate required off
</IfModule>
  • 2 uker senere...
