Sketchup til Ubuntu?
AT1S
I just downloaded SketchUp from Google and installed it via wine, and it worked fine. The menu bar and the "quick pick" buttons on the top of the screen, as well as the status bar on the bottom of the screen would go black frequently, but when I moused-over them, they would reappear.
Modeling a quick house went without a hitch, and the 3D rendering worked fine. I'm no expert, but the menu bar issue may not be a universal problem...but again, it wasn't that big of an issue. If you use the program enough, you will get the hotkeys down quickly enough.
So, to answer your question, my suggestion would be to install and run it using wine. Good luck!
Kilde: Ubuntuforums
Videre er det noen som anbefaler Blender 3D og Equinox 3D.
