Tonyman Skrevet 10. september 2008 Del Skrevet 10. september 2008 Jeg har lyst til å unngå oppstardssiden på Windows, hvor jeg må logge på, etter at jeg har intstallert Net Framework. Er det noen som vet hvordan jeg kan unngå dette? Dvs sånn at jeg kommer rett inn på skrivebordet når jeg skrur på PCen uten å gå omveien via påloggingssiden/velkomstsiden til Windows? Bruker XP SP3. Lenke til kommentar
okasin Skrevet 11. september 2008 Del Skrevet 11. september 2008 tja.. den tungvinne metoden først 1. Click Start, click Run, type regedit, and then click OK. 2. Locate the following registry key: HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Winlogon 3. Using your account name and password, double-click the DefaultUserName entry, type your user name, and then click OK. 4. Double-click the DefaultPassword entry, type your password under the value data box, and then click OK. If there is no DefaultPassword value, create the value. To do this, follow these steps: a. In Registry Editor, click Edit, click New, and then click String Value. b. Type DefaultPassword as the value name, and then press ENTER. c. Double-click the newly created key, and then type your password in the Value Data box. If no DefaultPassword string is specified, Windows XP automatically changes the value of the AutoAdminLogon registry key from 1 (true) to 0 (false) to turn off the AutoAdminLogon feature. 5. Double-click the AutoAdminLogon entry, type 1 in the Value Data box, and then click OK. If there is no AutoAdminLogon entry, create the entry. To do this, follow these steps: a. In Registry Editor, click Edit, click New, and then click String Value. b. Type AutoAdminLogon as the value name, and then press ENTER. c. Double-click the newly created key, and then type 1 in the Value Data box. 6. Quit Registry Editor. 7. Click Start, click Restart, and then click OK. After your computer restarts and Windows XP starts, you can log on automatically. Gadd ikke oversette.. dette fikser du Eller last ned power toys fra Microsoft.. http://www.microsoft.com/windowsxp/Downloa...ppowertoys.mspx hvor du finner muligheten til dette enkelt.. Lenke til kommentar
Tonyman Skrevet 11. september 2008 Forfatter Del Skrevet 11. september 2008 Strålende! Tusen takk! tja.. den tungvinne metoden først 1. Click Start, click Run, type regedit, and then click OK. 2. Locate the following registry key: HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Winlogon 3. Using your account name and password, double-click the DefaultUserName entry, type your user name, and then click OK. 4. Double-click the DefaultPassword entry, type your password under the value data box, and then click OK. If there is no DefaultPassword value, create the value. To do this, follow these steps: a. In Registry Editor, click Edit, click New, and then click String Value. b. Type DefaultPassword as the value name, and then press ENTER. c. Double-click the newly created key, and then type your password in the Value Data box. If no DefaultPassword string is specified, Windows XP automatically changes the value of the AutoAdminLogon registry key from 1 (true) to 0 (false) to turn off the AutoAdminLogon feature. 5. Double-click the AutoAdminLogon entry, type 1 in the Value Data box, and then click OK. If there is no AutoAdminLogon entry, create the entry. To do this, follow these steps: a. In Registry Editor, click Edit, click New, and then click String Value. b. Type AutoAdminLogon as the value name, and then press ENTER. c. Double-click the newly created key, and then type 1 in the Value Data box. 6. Quit Registry Editor. 7. Click Start, click Restart, and then click OK. After your computer restarts and Windows XP starts, you can log on automatically. Gadd ikke oversette.. dette fikser du Eller last ned power toys fra Microsoft.. http://www.microsoft.com/windowsxp/Downloa...ppowertoys.mspx hvor du finner muligheten til dette enkelt.. Lenke til kommentar
