[LØST] Hjelp med mbam og combofix logger
Har ikke noe særlig grei på dette så jeg håper noen kan hjelpe meg og se over mbam og combofix logger...
mbam
Malwarebytes' Anti-Malware 1.27
Database versjon: 1133
Windows 5.1.2600 Service Pack 2
09.09.2008 21:05:02
mbam-log-2008-09-09 (21-05-02).txt
Skanntype: Rask Skann
Objekter skannet: 41471
Tid tilbakelagt: 2 minute(s), 56 second(s)
Minneprosesser infisert: 0
Minnemoduler infisert: 2
Registernøkler infisert: 2
Registerverdier infisert: 0
Registerfiler infisert: 0
Mapper infisert: 0
Filer infisert: 3
(Ingen mistenkelige filer funnet)
C:\WINDOWS\system32\__c00E28CE.dat (Trojan.Agent) -> Delete on reboot.
C:\WINDOWS\system32\__c0084B97.dat (Trojan.Zlob) -> Delete on reboot.
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Winlogon\Notify\__c00e28ce (Trojan.Vundo) -> Delete on reboot.
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Winlogon\Notify\cca44e95382 (Trojan.Agent) -> Quarantined and deleted successfully.
Mapper infisert:
Filer infisert:
C:\WINDOWS\system32\__c00E28CE.dat (Trojan.Vundo) -> Delete on reboot.
C:\WINDOWS\system32\__c0084B97.dat (Trojan.Agent) -> Delete on reboot.
C:\WINDOWS\system32\__c00A6E56.dat (Trojan.Agent) -> Quarantined and deleted successfully.
Combofix
ComboFix 08-09-05.12 - Svein-Erik & Hege 2008-09-09 21:11:16.1 - NTFSx86
Microsoft Windows XP Home Edition 5.1.2600.2.1252.1.1044.18.212 [GMT 2:00]
Running from: C:\Documents and Settings\Svein-Erik & Hege\Skrivebord\ComboFix.exe
* Created a new restore point
WARNING -THIS MACHINE DOES NOT HAVE THE RECOVERY CONSOLE INSTALLED !!
((((((((((((((((((((((((((((((((((((((( Other Deletions )))))))))))))))))))))))))))))))))))))))))))))))))
C:\WINDOWS\system32\_000005_.tmp.dll
((((((((((((((((((((((((( Files Created from 2008-08-09 to 2008-09-09 )))))))))))))))))))))))))))))))
2008-09-09 20:56 . 2008-09-09 20:56 <DIR> d-------- C:\Programfiler\Malwarebytes' Anti-Malware
2008-09-09 20:56 . 2008-09-09 20:56 <DIR> d-------- C:\Documents and Settings\Svein-Erik & Hege\Programdata\Malwarebytes
2008-09-09 20:56 . 2008-09-09 20:56 <DIR> d-------- C:\Documents and Settings\All Users\Programdata\Malwarebytes
2008-09-09 20:56 . 2008-09-08 00:11 38,528 --a------ C:\WINDOWS\system32\drivers\mbamswissarmy.sys
2008-09-09 20:56 . 2008-09-08 00:11 17,200 --a------ C:\WINDOWS\system32\drivers\mbam.sys
2008-09-08 23:37 . 2008-09-08 23:37 <DIR> dr-h----- C:\Documents and Settings\Svein-Erik & Hege\Siste
2008-09-04 20:15 . 2008-09-04 20:15 <DIR> d-------- C:\WINDOWS\ShellNew
2008-09-01 20:05 . 2008-09-01 20:05 <DIR> d-------- C:\Documents and Settings\Svein-Erik & Hege\Programdata\PCF-VLC
2008-08-29 22:17 . 2008-08-29 23:04 <DIR> d-------- C:\Documents and Settings\Svein-Erik & Hege\browser - logitech
2008-08-29 22:16 . 2008-08-29 22:16 <DIR> d-------- C:\Documents and Settings\Svein-Erik & Hege\logitech
2008-08-29 22:14 . 2008-08-29 22:14 <DIR> d----c--- C:\WINDOWS\system32\DRVSTORE
2008-08-29 22:14 . 2008-08-29 22:14 <DIR> d-------- C:\Programfiler\Fellesfiler\Remote Control USB Driver
2008-08-26 14:21 . 2008-08-26 14:21 12,307,651 --------- C:\avg7qt.dat
2008-08-26 13:08 . 2008-09-02 08:34 <DIR> d-------- C:\Programfiler\Spybot - Search & Destroy
2008-08-26 13:08 . 2008-09-01 20:00 <DIR> d-------- C:\Documents and Settings\All Users\Programdata\Spybot - Search & Destroy
2008-08-25 07:22 . 2008-08-26 13:16 <DIR> d-------- C:\WINDOWS\system32\CatRoot_bak
2008-08-13 20:00 . 2008-05-01 16:34 331,776 -----c--- C:\WINDOWS\system32\dllcache\msadce.dll
(((((((((((((((((((((((((((((((((((((((( Find3M Report ))))))))))))))))))))))))))))))))))))))))))))))))))))
2008-09-09 19:14 32,069,664 --sha-w C:\WINDOWS\system32\drivers\fidbox.dat
2008-09-09 19:06 380,444 --sha-w C:\WINDOWS\system32\drivers\fidbox.idx
2008-09-04 18:51 --------- d-----w C:\Documents and Settings\Svein-Erik & Hege\Programdata\AVG7
2008-09-01 15:42 --------- d--h--w C:\Programfiler\InstallShield Installation Information
2008-08-31 06:00 --------- d-----w C:\Documents and Settings\LocalService\Programdata\AVG7
2008-08-09 09:11 --------- d-----w C:\Programfiler\Java
2008-07-18 20:10 94,920 ----a-w C:\WINDOWS\system32\cdm.dll
2008-07-18 20:10 53,448 ----a-w C:\WINDOWS\system32\wuauclt.exe
2008-07-18 20:10 45,768 ----a-w C:\WINDOWS\system32\wups2.dll
2008-07-18 20:10 36,552 ----a-w C:\WINDOWS\system32\wups.dll
2008-07-18 20:09 563,912 ----a-w C:\WINDOWS\system32\wuapi.dll
2008-07-18 20:09 325,832 ----a-w C:\WINDOWS\system32\wucltui.dll
2008-07-18 20:09 205,000 ----a-w C:\WINDOWS\system32\wuweb.dll
2008-07-18 20:09 1,811,656 ----a-w C:\WINDOWS\system32\wuaueng.dll
2008-07-18 20:07 270,880 ----a-w C:\WINDOWS\system32\mucltui.dll
2008-07-18 20:07 210,976 ----a-w C:\WINDOWS\system32\muweb.dll
2008-07-14 18:02 --------- d-----w C:\Programfiler\Zone Labs
2008-07-09 07:05 75,248 ----a-w C:\WINDOWS\zllsputility.exe
2008-07-09 07:05 1,086,952 ----a-w C:\WINDOWS\system32\zpeng24.dll
2008-07-07 20:33 253,952 ----a-w C:\WINDOWS\system32\es.dll
2008-06-24 16:24 74,240 ----a-w C:\WINDOWS\system32\mscms.dll
2008-06-23 16:57 826,368 ----a-w C:\WINDOWS\system32\wininet.dll
2008-06-20 17:43 246,784 ----a-w C:\WINDOWS\system32\mswsock.dll
2008-05-25 10:25 22,616 ----a-w C:\Documents and Settings\Svein-Erik & Hege\Programdata\GDIPFONTCACHEV1.DAT
2008-04-13 21:01 20 ---h--w C:\Documents and Settings\All Users\Programdata\PKP_DLec.DAT
2008-04-13 21:01 20 ---h--w C:\Documents and Settings\All Users\Programdata\PKP_DLds.DAT
((((((((((((((((((((((((((((((((((((( Reg Loading Points ))))))))))))))))))))))))))))))))))))))))))))))))))
*Note* empty entries & legit default entries are not shown
REGEDIT4
[HKEY_CURRENT_USER\SOFTWARE\Microsoft\Windows\CurrentVersion\Run]
"CTFMON.EXE"="C:\WINDOWS\system32\ctfmon.exe" [2004-08-04 15360]
"MSMSGS"="C:\Programfiler\Messenger\msmsgs.exe" [2004-10-13 1694208]
"swg"="C:\Programfiler\Google\GoogleToolbarNotifier\GoogleToolbarNotifier.exe" [2007-06-22 68856]
"NBJ"="C:\Programfiler\Ahead\Nero BackItUp\NBJ.exe" [2005-07-14 1961984]
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Run]
"Norton Ghost 9.0"="D:\Norton Ghost\Programfiler\Agent\GhostTray.exe" [2004-07-29 1122304]
"AVG7_CC"="C:\PROGRA~1\Grisoft\AVGFRE~1\avgcc.exe" [2008-04-21 579584]
"Easy-PrintToolBox"="C:\Programfiler\Canon\Easy-PrintToolBox\BJPSMAIN.EXE" [2004-01-14 409600]
"ATIPTA"="C:\Programfiler\ATI Technologies\ATI Control Panel\atiptaxx.exe" [2003-09-12 335872]
"SsAAD.exe"="C:\PROGRA~1\Sony\SONICS~1\SsAAD.exe" [2005-01-24 81920]
"SunJavaUpdateSched"="C:\Programfiler\Java\jre1.6.0_07\bin\jusched.exe" [2008-06-10 144784]
"NVMixerTray"="C:\Programfiler\NVIDIA Corporation\NvMixer\NVMixerTray.exe" [2004-12-20 131072]
"NeroFilterCheck"="C:\WINDOWS\system32\NeroCheck.exe" [2001-07-09 155648]
"Adobe Reader Speed Launcher"="C:\Programfiler\Adobe\Reader 8.0\Reader\Reader_sl.exe" [2008-01-11 39792]
"ZoneAlarm Client"="C:\Programfiler\Zone Labs\ZoneAlarm\zlclient.exe" [2008-07-09 919016]
"BluetoothAuthenticationAgent"="bthprops.cpl" [2004-08-04 C:\WINDOWS\system32\bthprops.cpl]
"WD Button Manager"="WDBtnMgr.exe" [2007-11-23 C:\WINDOWS\system32\WDBtnMgr.exe]
[HKEY_USERS\.DEFAULT\Software\Microsoft\Windows\CurrentVersion\Run]
"CTFMON.EXE"="C:\WINDOWS\System32\CTFMON.EXE" [2004-08-04 15360]
"AVG7_Run"="C:\PROGRA~1\Grisoft\AVGFRE~1\avgw.exe" [2007-10-25 219136]
C:\Documents and Settings\All Users\Start-meny\Programmer\Oppstart\
Microsoft Office.lnk - C:\Programfiler\Microsoft Office\Office10\OSA.EXE [2001-02-13 83360]
[HKEY_LOCAL_MACHINE\software\microsoft\windows nt\currentversion\drivers32]
"msacm.divxa32"= msaud32_divx.acm
"VIDC.YV12"= yv12vfw.dll
[HKEY_LOCAL_MACHINE\software\microsoft\security center\Monitoring\ZoneLabsFirewall]
"DisableMonitoring"=dword:00000001
[HKLM\~\services\sharedaccess\parameters\firewallpolicy\standardprofile]
"EnableFirewall"= 0 (0x0)
[HKLM\~\services\sharedaccess\parameters\firewallpolicy\standardprofile\AuthorizedApplications\List]
"%windir%\\system32\\sessmgr.exe"=
"C:\\Programfiler\\Grisoft\\AVG Free\\avginet.exe"=
"C:\\Programfiler\\Grisoft\\AVG Free\\avgemc.exe"=
"C:\\Programfiler\\Grisoft\\AVG Free\\avgamsvr.exe"=
"C:\\Programfiler\\Grisoft\\AVG Free\\avgcc.exe"=
"%windir%\\Network Diagnostic\\xpnetdiag.exe"=
"D:\\SveinE filer\\LimeWire\\LimeWire.exe"=
R0 PQV2i;PQV2i;C:\WINDOWS\system32\drivers\PQV2i.sys [2004-07-29 138780]
R0 SI3112r;Silicon Image SiI 3112 SATARaid Controller;C:\WINDOWS\system32\DRIVERS\si3112r.sys [2003-02-24 85265]
R1 PQIMount;PQIMount;C:\WINDOWS\system32\drivers\PQIMount.sys [2004-07-29 46779]
[HKEY_CURRENT_USER\software\microsoft\windows\currentversion\explorer\mountpoints2\{5bf900fe-1cd5-11db-afb3-806d6172696f}]
\Shell\AutoRun\command - F:\Autorun.exe root.ini
[HKEY_CURRENT_USER\software\microsoft\windows\currentversion\explorer\mountpoints2\{c5d7edcf-1cd4-11db-aae9-806d6172696f}]
*Newly Created Service* - PROCEXP90
------- Supplementary Scan -------
R0 -: HKCU-Main,Start Page = hxxp://www.startsiden.no/
O8 -: E&ksporter til Microsoft Excel - C:\PROGRA~1\MICROS~2\Office10\EXCEL.EXE/3000
O16 -: {DEB21AD3-FDA4-42F6-B57D-EE696A675EE8} - hxxp://asp08.photoprintit.de/microsite/5026/defaults/activex/ImageUploader3.cab
C:\WINDOWS\Downloaded Program Files\ImageUploader_3.inf
C:\WINDOWS\Downloaded Program Files\ImageUploader_3.ocx
catchme 0.3.1361 W2K/XP/Vista - rootkit/stealth malware detector by Gmer, http://www.gmer.net
Rootkit scan 2008-09-09 21:13:43
Windows 5.1.2600 Service Pack 2 NTFS
scanning hidden processes ...
scanning hidden autostart entries ...
scanning hidden files ...
scan completed successfully
hidden files: 0
--------------------- DLLs Loaded Under Running Processes ---------------------
PROCESS: C:\WINDOWS\system32\winlogon.exe
-> C:\WINDOWS\system32\Ati2evxx.dll
Completion time: 2008-09-09 21:15:40
ComboFix-quarantined-files.txt 2008-09-09 19:15:36
Pre-Run: 6,499,938,304 byte ledig
Post-Run: 6,483,177,472 byte ledig
139 --- E O F --- 2008-08-26 11:02:57
På forhånd takk.
SEP
Endret av sepersen
